EF lenses and the Mirrorless future
Started Sep 15, 2016 | Polls
Jura S Senior Member • Posts: 1,980
Re: A year later - have attitudes changed ?
rrccad wrote:
Le Kilt wrote:
Messier Object wrote:
with rumours of a Canon FF mirrorless under development what’s the future for EF lenses - what do you want from Canon?
Peter
Where's the problem, with the straight-through adapter, EF lenses work perfectly on M bodies.
while that's somewhat true, as an example a 60mm EF-S does not work perfectly on an M5.
What's wrong with it?
(unknown member) Forum Pro • Posts: 11,521
Jura S wrote:
Peter
has an extreme amount of difficulty focusing under around .7:1, even in adequate light.  just refuses to focus.
dgumshu
dgumshu Veteran Member • Posts: 4,623
Re: EF lenses and the Mirrorless future
gavin wrote:
I agree, but I also think the mirrorless will be the norm in say 4-5 years. Not quite there yet for me at this point but getting closer every year.
The norm?
Perhaps for a Still Stills shooter.  As an action shooter, I'd hate to give up my OVF DSLR.  I don't particularly care for the EVF on my Fuji.  EVF is like looking at an iPhone.  Differnt strokes.
I think that Canikon will produce mirrorless in addition to DSLR's.  The D850 is so popular, that Nikon can't keep up with demand... for now.   I don't think they are going away anytime soon, or in my life time.
 dgumshu's gear list:dgumshu's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R5 OM-1 +52 more
rrccad wrote:
Jura S wrote:
Peter
I don't understand. Are you too close or what?
OP Messier Object Forum Pro • Posts: 12,711
Peter
adapters add movement and flex. have you ever seen how much movement there is when you stack a 2x extender with an adapter ?
A FF M will have an M mount and an EF-adapter and the EF lenses will work just as well as the M lenses.
I would like to see some L quality pancake M lenses from Canon
P.S. More mirrorless may appear, but DSLRs will be around for a long time yet.
 Messier Object's gear list:Messier Object's gear list
Nikon Coolpix 990 Olympus C-5050 Zoom Olympus E-300 Olympus E-330 Olympus E-30 +31 more
Peter
mirrorless can easily use EF and EF-S lens
yes, I'm sure they can. But if you were a sports/wildlife shooter and found that your 500mm f/4 II didn't AF as quickly on the  brand new FF mirrorless - would you be happy?
The question is not whether they work, but how well they work, and whether needing to use an adapter is good for you
RDKirk Forum Pro • Posts: 16,547
I'd make a couple of points about that.
For one, a 2x extender will most often suggest a rig that works better with a full-sized camera anyway.  I suspect that for a number of reasons, mirrorless 1-digit and 2-digit Canon cameras using EF lenses will always be "full sized."
Moreover, if the adapter is made to be semi-permanent--removable only with tools or maybe even requiring professional service--it can be perfectly solid.
RDKirk
'TANSTAAFL: The only unbreakable rule in photography.'
 RDKirk's gear list:RDKirk's gear list
Canon EOS 5D Mark II Canon EOS 70D Canon EOS 5DS R Canon EOS 80D Canon EF 24mm f/2.8 +7 more
Le Kilt Senior Member • Posts: 2,528
Peter
I haven't tried the EOS M adapter, but have never found using extenders or extention rings a problem.  I often use the 1.4x TC on the 100-400, sometimes the 2x, and sometimes both, and have even added a third Kenko one.  No problem.  Same with adding extention rings for closer focusing, with or without extenders.
Was a bit of flexing your only concern?
 Le Kilt's gear list:Le Kilt's gear list
Canon EF 16-35mm F2.8L II USM
2 years since this poll
I wonder if attitudes have changed now that we’ve seen the first mirrorless FF from Canon and it doesn’t have an EF mount
Peter
StefanD Contributing Member • Posts: 577
Re: 2 years since this poll
Peter
In https://www.dpreview.com/forums/post/58348916 I wrote:
"Canon will release a full frame mirrorless with a short flange distance and a simple extension tube to allow EF lenses to be used to their full potential.
A new line of EF lenses will be released to take advantage of the short flange distance."
I guess I can stick to that. We now know that this new line of EF lenses is called RF.
Ed Rizk Veteran Member • Posts: 3,898
Peter
Mine did.
I was a big content DSLR luddite.   Several factors about the R convinced me to add it.
Better AF with my existing lenses.
AF in even lower light.
Insane lens designs, not for ones I wanted, but they showed the potential.
The control ring on the lenses and an adapter.
Complaints that it was too big for a mirror less.   I like big.   That's why I had planned to stay with DSLR.
Once I got it, I really liked EVF for less than ideal lighting conditions.    OVF is better in ideal lighting conditions.   I liked the customization options.    And I liked the touch screen for AF point selection.  It's a good camera.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 6D Canon EOS R Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +4 more
Bob Atwell Regular Member • Posts: 213
I think that we are seeing the best possible outcome for the transition from an SLR dominated world to a mirrorless world.  It is obvious from the technology of the more expensive R lenses that have been released that Canon has been working on the R mount and mirrorless technology for a long time.  I suspect that mirrorless technology has a significant impact upon Canon's video camera line and its lucrative sales there.
That being said, I think that we have seen an interesting but imperfect first full frame offering from Canon in the EOS R body.  My problem with the body has to do with its lack of certain professional features that Sony has implemented so well in its similarly priced A7III.  I am quite satisfied with having to use an adapter on my existing Canon EF mount L lenses on either a Canon R mount or Sony E mount.  Right now the Sony seems to outperform Canon in mirrorless bodies.  I am hoping that Canon will release over the next 12-15 months a professional body has the same functionality in a mirrorless body that we are used to in our XD series of SLRs.  If that happens I will return to being solely a Canon shooter.  If not then I will begin to migrate to the more professional next generation of Sony professional bodies.   I really would like a global shutter in my next mirrorless body.  I don't need 20+ frames per second but 10 should be achievable.  I also want something in the 30+ megapixel range.   So I am still on the fence.
 Bob Atwell's gear list:Bob Atwell's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS 5D Mark IV Sony a7 III Canon EF 24mm f/1.4L II USM +27 more
Dave
Dave Veteran Member • Posts: 6,231
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
