TriElmar 28 > 35> 50 + > 75
Started Sep 10, 2016 | Discussions
Dr. Ulrich Rohde Senior Member • Posts: 2,332
Most zoom lenses tend to cover 28 to 75 mm, The SL Vario somehow got 24 to 90 and my still all time favorite is the R 28 >90 lens, with now about $ 6000 on e-bay, it got a little pricey . So here is a test of an experimental lens , I did not find any internal reflections and a good contrast. At this time of the day the sun is brutal and I wanted to see how this Vario lens would do , and yes, it did  very well
This lens does not have a 6 bit coating the camera recognizes, and it a very fine peace of perfected design. We had 90 + deg, so a pool is always a good destination
 Dr. Ulrich Rohde's gear list:Dr. Ulrich Rohde's gear list
Leica X Vario Leica Q Canon EOS-1D Mark III Leica M8 Leica M9 +13 more
Irakly Shanidze
Irakly Shanidze Veteran Member • Posts: 6,519
Re: TriElmar 28 > 35> 50 + > 75
Excellent example of an excellent lens performing on a top level. I truly wish the 24-90 SL were at least a half of that!
Irakly Shanidze
www.shanidze.com/en
www.artphotoacademy.com
 Irakly Shanidze's gear list:Irakly Shanidze's gear list
Leica M9 Leica S2 Leica SL (Typ 601) Leica M10 Panasonic S1 +17 more
Fazal Majid
Fazal Majid Senior Member • Posts: 2,072
Is it a continuously variable zoom lens or like the Tri-Elmar a lens with discrete focal lengths?
Fazal Majid (www.majid.info)
 Fazal Majid's gear list:Fazal Majid's gear list
Ricoh GR III Leica M10 Nikon Z7 Leica APO-Summicron-M 50mm f/2 ASPH Nikkor AF-S 300mm f/4E PF ED VR +31 more
OP Dr. Ulrich Rohde Senior Member • Posts: 2,332
This test lens is continuous like a zoom.
Re: TriElmar 28 > 35> 50 + > 75 with the SL.
Many of us use either R or M lenses on the SL. Most have great success. R lenses on the T has been less interesting but T lenses on the SL works quite well, even if only a smaller part of the sensor is now used .
I was asked yesterday to put the M Vario on the SL . This experimental lens behaves like a zoom and I find it extremely well designed. The Leica group with Peter Karbe in command has lately produced really stunning results. The full set of T (TL) lenses is a good prove and the new SL 50mm/1.4 is also clinically sharp. Simply amazing . These AF lenses are getting fairly large and Zeiss lenses (not AF) too.
First are the 28 mm to 75 mm Leica M Vario, f =4, the M 240  camera does not know the lens
Next   are in sequence of 28mm-35mm-50mm and 75mm the SL pool pictures. A figure of merit is always the clarity and resolution of the door knob . With a very hot day again  today, the water is more relevant ...
The following 4 pictures are taken with the Vario Elmarit 24 >90mm for the SL, again in
28 >35 > 50 > 75 (77) mm settings in AF mode and P while the previous  M pictures were in A ( aperture mode), f=4
The color and the transmission (loss) for the lens is different, the exposure measurements seems to make the picture brighter.
I also thing the focal length must have a different meanings as  for  the same settings  part of the picture looks slightly  different
Irakly Shanidze
Ulrich, it is hard to see the difference at this picture size. could you post 100% crops? Also, it would be very interesting to see how this lens behaves against the light , where 24-90 fails.
Irakly Shanidze
www.shanidze.com/en
