My old K-50 comparison of DAL55-300 and HD55-300 PLM RE Lens
Started Sep 6, 2016 | Discussions
Ab Jim Forum Member • Posts: 57
2016.08.30 K-50 DAL55-300 Vs. HD55-300 PLM Lens DNG
Centre area 600x600 pixel crop:
Pentax K-50
OP Ab Jim Forum Member • Posts: 57
Re: My old K-50 comparison of DAL55-300 and HD55-300 PLM RE Lens
Live view focus´╝Ü
indoor
GordonBGood Veteran Member • Posts: 6,307
Ab Jim wrote:
indoor
Jim, you stated for some of the images in this thread that you used raw (DNG). Please confirm that you used raw for all, and what you used for white balance (auto settings?) I would suggest that you use a fixed same white balance for both images per pair.
My general observations without knowing the white balance used and assuming any adjustments related to brightness were the same is that the newer lens is perhaps slightly brighter.
However, differences in white balance sort of spoil the comparison, as sometimes one is bluer than the other and sometimes the same lens is less blue, perhaps depending on slight differences in framing.
I would try to set each to a constant white balance as to colour temperature and tint if possible, and if not would try a manual white balance using one of the lenses with the same manual white balance setting used for the other lens.
Regards, GordonBGood
