Upgrading from the S120 to...? Help!
Started Sep 4, 2016 | Discussions
AussieMega
AussieMega Junior Member • Posts: 31
I've had the Canon PowerShot S120 since it came out, and I truly love it...But it's had it's fair share of knocks and bumps over the last few years, and I need to replace/upgrade. The problem is, I just can't figure out what to upgrade to!
The most obvious choices in the range are the G9x or the G7x Mark II. Either of them are superior to the S120 in several ways. However, one of the most important features (to me) is the zoom range...And in that feature, they are both inferior to the S120: The S120 is 24-120, the G7xMii is 24-100, and the G9 is a paltry 28-84. And I KNOW I need and use ever inch (mm of my S120's 24-120.
So...If it's a given that I love the S120 and need the 24-120 range that it offers, is there anything else out there in the Canon range that I'm missing that has at least that range, as well as a similar quality and build as the S120?
Thanks in advance for any/all advice
 AussieMega's gear list:AussieMega's gear list
Canon PowerShot S120 Nikon D800
Canon G9 X Canon PowerShot G7 X Canon PowerShot G9 Canon PowerShot S120
crashpc Veteran Member • Posts: 7,235
Re: Upgrading from the S120 to...? Help!
There is G1X, but it won't really help you much with zoom, and it is bigger.
I believe that both sensor and the lens of the G7X is good enaugh for cropping your image from the original, still giving you the quality you had with your S series, while for focal lenghts 100mm and shorter, you will even gain some. For G9X, it might not be enaugh, and it really migbt be a downgrade in this regard.
 crashpc's gear list:crashpc's gear list
Canon EOS M10 Canon EF-M 15-45mm F3.5-6.3 IS STM
damian5000 Senior Member • Posts: 1,948
G7X as crashpc has said. You might also consider Panasonic TZ100.
 damian5000's gear list:damian5000's gear list
0lf
0lf Senior Member • Posts: 1,284
Keep in mind you can crop from 1" sensor and still get better results than from smaller chips.
  • The s120 has a 1/1.7" 12Mpixel sensor with a 120mm (eq) lens.
  • The G9x use 1/1.4" 10Mpixel sensor area at 120mm equivalent focal length
  • The G7x use 1/1.2" 14Mpixel sensor area at 120mm equivalent focal length
 0lf's gear list:0lf's gear list
Sony RX1 Fujifilm X70 Canon G7 X II Apple iPhone 13 mini
AussieMega
OP AussieMega Junior Member • Posts: 31
Well, yes, that's true...But I use my point a lot, and don't usually want to have to crop/edit the photo I take with it (I use my D800 if I'm shooting something that needs editing).
AussieMega
Yeah, I think I'm pretty locked into the G7x then...Can't do the Panasonic, I'm such a fan of the Canon user interface, I don't think I could bring myself to switch
Didn't think about it that way... I have no idea then...
photo perzon Veteran Member • Posts: 4,653
S120 poor in low light, g7xii is stellar
no comparison, g7x flash tilts does not produce red eye, does not bother eyes.  If you can handle the 3 extra ounces, night and dat
 photo perzon's gear list:photo perzon's gear list
Olympus Stylus 1 Panasonic Lumix DMC-ZS50 Fujifilm X70 Fujifilm X100F Fujifilm X-T100 +1 more
GeraldW Veteran Member • Posts: 8,872
You might consider a G15 or G16.  28-140 mm f/1.8-2.8, and quite good in low light.  Not much bigger or heavier than a G7X II.  Also, if fitted with a neck cord (lanyard) or wrist strap it slips easily into a trousers pocket if they are looser fitting.
But a confession from me.  More and more I'm using an IXUS 255 (ELPH 330HS).  Surprisingly good, covers 24-240 mm, and at wider angles is good in low light.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
