Question about EM10 Mark ii display & lens
Started Sep 4, 2016 | Discussions
jeffal23 Forum Member • Posts: 64
i wonder how to set it's lcd display to get the same as photo result
i take a photo on dark area , on lcd it seems bright , but after take a shot , it's very dark
how to set to , what i see is what i get ?
and about lens , i am looking for olympus and 17 mm f1.8 and panasonic 20mm f1.7 mark ii . i know it has been discussed a lot in this forum , i use search button too , but most thread is from 2014 , what i really want to know , is it really difference between that two regard from sharpness ? and about uv problem , can it damage olympus body sensor ?
i need below 20mm focal lenght , but i do not know that to buy , i try 25mm and do not like it
thanks
 jeffal23's gear list:jeffal23's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +3 more
Olympus M.Zuiko Digital 17mm F1.8 Olympus OM-D E-M10 II Panasonic 20mm F1.7 II
carlgorski Contributing Member • Posts: 861
Re: Question about EM10 Mark ii display & lens
read manual there is a setting for that.
Martian Flatcat
Martian Flatcat Regular Member • Posts: 457
A couple of ways to get that behavior. Look for live view boost, and turn it off. Also, you can assign  depth of field preview to a button, and stop down the aperture.
Or, you can assign simulated optical viewfinder to a button or the multifunction button.
On lens choice, look for the "lovely 17mm" thread just in the last day or so.
--Flatcat
 Martian Flatcat's gear list:Martian Flatcat's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G 14mm F2.5 ASPH +7 more
TyphoonTW
TyphoonTW Senior Member • Posts: 1,484
No idea about those lenses, but I had the same "issue" with my E-M10mkII that had live view boost on by default. Somewhere in the menu it's possible to turn it off.
This is where I write stuff: http://randomibis.wordpress.com/
This is where I upload stuff: http://www.flickr.com/photos/107755637@N06/
 TyphoonTW's gear list:TyphoonTW's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +2 more
OP jeffal23 Forum Member • Posts: 64
Thank you , it's live boost , i just turn it off and everything as it should be
liveboost is located in gear icon - D display paragraph , go down 1 paget , voila , live view boost
