Macro ext ring MCEX-11?
Started Sep 3, 2016 | Questions
Lettermanian
Lettermanian Senior Member • Posts: 2,389
Hello all, just wondering if anyone has an opinion on using the Fuji brand MCEX-11 macro tube ring? In particular, I would like to know if there is any IQ difference between using this and the Raynox DCR-150 (which I already have). I may be able to get the MCEX-11 for a fairly low price, so any opinions would be helpful. I have the X-T10 with the 18-55 and the 50-230 II.
"Turn my eyes from looking at worthless things;
and give me life in your ways." - Psalm 119:37
 Lettermanian's gear list:Lettermanian's gear list
Fujifilm X-T3 Carl Zeiss Touit 2.8/12 Tamron 17-70 F2.8 Di III-A VC RXD Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Fujifilm 50-230mm II Fujifilm X-T10 Nikon AF-P 18-55mm F3.5-5.6G VR
technotic Contributing Member • Posts: 792
Re: Macro ext ring MCEX-11?
I have it but have rarely used it. A macro lens would be better for me. I very much doubt there would be any quality difference between them as they have no optics in them. They are just empty tubes. But the Fuji one has contacts so you get info going between lens and body.
M4cr0s
M4cr0s Senior Member • Posts: 1,204
Anything that push a lens beyond its design will degrade IQ. Be it extension tubes, a filter/close-up lens or a TC. The degradation need not be so large that you notice it though.
Mac
www.falkphoto.no
Vic Chapman Forum Pro • Posts: 10,694
I have a set of Pixco 10mm + 16mm ext tubes both work well with full automation with lenses, 6omm f2.4 macro, 55-200mm and best of all with 90mm f2 which already has a decent close focus range. In the field I mostly use the 55-200mm for butterflies, dragonflies, plants. There may be some slight chance of a weak connection using these plastic Pixco tubes attached to 55-200 when mounted on a tripod and thus with the lens unsupported. I haven't used both tubes together though and I've recently been looking at the Raynox 150/250 myself. This page with a calculator might be of some help to you: http://extreme-macro.co.uk/raynox-adapter-techniques/
My feeling is that the Raynox and their Canon equivalent closeup lens/filters are very good and while theoretically any glass in front of the lens will decrease IQ, I don't think anyone could say which setup had been used in most cases.
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
