An Investigation of E-M1 Focus Bracketing
Started Aug 30, 2016 | Discussions
Pedagydusz Veteran Member • Posts: 6,026
Re: An Investigation of E-M1 Focus Bracketing - Extension Tubes?
Aucupium wrote:
Thanks Richard for this - quite illuminating!
What happens when we attach extension tubes to the 60mm lens? [...]
I don't know the full answer to your question, but I know that it works very well:
Pen-F, 60 mm + ET (crop, real magn ≈ 1.7x)
f/4.5, 50 steps (step 4)
This was done with a live moth, it would be unthinkable with focussing rails.
 Pedagydusz's gear list:Pedagydusz's gear list
Sony Cyber-shot DSC-F707 Canon EOS 7D Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 +3 more
Aucupium Regular Member • Posts: 280
Nice! Moth species? 50 steps - quite a lot !
I can see I have a lot of trial and error to do over the winter months.
Andrew
 Aucupium's gear list:Aucupium's gear list
Panasonic Lumix DMC-FZ200 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
Andrew
The moth is the Abraxas pantaria, a pest of the common ash tree. That was exactly where it was found, an ash tree near where I live (central Portugal).
The parameters I used were not the result of careful thought, It was just what I had found to be safe to do a very fast job at this scale. Being nocturnal, the moth was very quiet for some intervals, but I never knew when it would star twitching. I think that 30 steps would do, but the difference in total time is very small, better safe!
Good luck with your winter moths, I hope we will see some results.
bbbbbbbbbbb Senior Member • Posts: 2,238
Re: Focus Bracketing Tables
Gary from Seattle wrote:
Richard Turton wrote:
Your interpretation is correct. The total size of the focus bracket is equal to the number from the table multiplied by the focus differential and number of shots settings.
The minimum focusing distance of the 60 mm macro lens is 8 inches. But that is the distance from the subject to the sensor ( manufacturers seem to agree on this definition). But the sensor is 4" behind the front of the lens, so at minimum focus the front of the lens is only 4" from the subject.
Ok, Richard. I read the thread but missed where your distances are to the sensor. This is a great table and I'll be sure to save it. Thanks.
I agree with others that Olympus would be interested and should publish this on their website or send it out by e-mail!
I second that, apart from the inches bit :/
 bbbbbbbbbbb's gear list:bbbbbbbbbbb's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus E-450 +8 more
As one retired ginger beer to another, excellent work buddy! This is exactly the sort of sleuthing we need to counter the marketing shenanigans that goes on in the camera manufacturing industry.
Having said that, I'm almost ashamed to ask you to go just a bit further and take a look at Oly's in-camera focus stacking. I do a lot of in-the-field macros of native flowers. Having the composite result right there on the camera in second is a God send for me and saves heaps of PP. However, again Oly is being mysterious. The stack does not start at the point of focus. It jumps forward two shots then backward 6 shots but I don't know if that is consistent and of course there is the issue of what is a focus differential. One would expect it to be the same as in focus bracketing but is it?
Also, on Oly's focus stacking site http://cameras.olympus.com/stack/en-au/ a landscape scene is shown.  The standard shot has only the foreground in focus.  The stacked shot has everything to infinity in focus despite using focus step 1.  This implies to me that there may be a non-linearity involved.  Of course there is next to no explanation.  The shot was taken at f3.2.  This would be a boon to landscape photographers who might otherwise have to stop down to f16 to get that DOF.
OP Richard Turton Regular Member • Posts: 336
Focus Bracketing with the 12-40 mm f/2.8 Pro lens
6
This is a supplement to the original post that described how E-M1 focus bracketing works with the 60 mm f/2.8 macro lens.  After six years use, my ZD 12-60 mm f/2.8-4 zoom lens started to consistently overexpose because the lens failed to close down to the taking aperture during the exposure.  Instead of getting it repaired, I used the failure as an excuse to replace the lens with the mZD 12-40 mm f/2.8 Pro.  Since this lens also supports focus bracketing/stacking, I have determined it's focus bracketing behaviour using the same procedure as for the 60 mm macro.
This first plot shows the size of the focus step as a function of the focus distance for a focus differential setting of 1.  Using a log-log scale instead of a linear scale makes the data a little easier to read for short distances.
The second plot shows the theoretical depth of field as a function of focus distance, calculated using the usual CoC of 0.015 mm for a Four Thirds sensor.
The third plot shows the ratio of depth of field to focus step as a function of focus distance.  Similar to the 60 mm macro, the depth of field is roughly constant at 3.3  times the focus step for close-up distances.
The following three plots show the same information with the distances rescaled to inches.
Skeeterbytes Forum Pro • Posts: 23,148
Re: Focus Bracketing with the 12-40 mm f/2.8 Pro lens
Super follow-up, thank you! (The 12-40 is a gem, isn't it?)
Rick
Rick
The 12-40 is the best lens I have ever owned.  As soon as I started using it I noticed that it was extremely sharp, but when I got around to doing some MTF measurements I was amazed at how good the results were.  It is significantly better than the already good 12-60, and unlike most zoom lenses the performance is nearly constant over the whole focal length range.
Focusing is also much faster and more consistent than the older lens, although that may be due to it using CDAF instead of PDAF.
Again, brilliant work Richard. I like the log-log plots.
Hey Olympus, whatever you payed Kazuo Unno for that mediocre article on focus stacking/bracketing, you should pay Richard Turton double.
Richard, there is a wealth of data in these graphs but it's really hard to get one's brain around it.  In the field, once having composed, one then decides what continuous DOF is needed.  I use the 8 step in-camera focus stacking.  For me using the 60mm macro, knowing the focus distance, I need to determine what combination of focus differential and aperture will do the job.  At the moment it's just hit an miss and Olympus are no help at all.  Can you give some thought into what sort of field chart would do the job... then patent it.  I'll pre-order one.
BTW, I like your use of metric units.  No photographer should have difficulty with metres and mm's.
I too have switched from the 12-60 to the 12-40mm. It's way more compact and like the 12-60 it allows focusing almost to the surface of the lens. Most of all I like that they seem to have removed the annoying handlebar distortion that the 12-60 exhibited at 12mm.  The 12-40 still has some barrel distortion at 12mm but that's easier to correct in PP.
When I started this project I thought it would solve all my focus stacking problems, but it hasn't turned out that way.  As you say, the information is very difficult to use in the field.  It is not really practical to measure or estimate the near and far focus points and then do a bunch of mental arithmetic to figure out the right settings. I tried using some precalculated charts instead of graphs but that didn't work very well either.  The most useful thing I learned was that is not a good idea to use a focus differential greater than 3.  After some experimenting I have settled on 8 shots (maybe Olympus knows something?) at f/5.6 (the sharpest aperture of the 60mm macro) with a focus differential of 2.  I could have determined these settings more easily using trial and error.
For an 8 shot sequence it makes sense to use the built-in focus stacking instead of focus bracketing.  The reasons I don't are first, the in camera stacking does not do a good job of aligning the frames, and second, it is difficult to determine the correct focus point, other than "slightly behind the closest point of interest".
I need to come up with a method of presenting the focus bracketing information that is practical to use in the field.
lester11
lester11 Contributing Member • Posts: 596
Hi Richard
I've been trying to do the same for in-camera focus stacking, it is a non-trivial challenge indeed (smile).  Looking forward to your results....
Lester
 lester11's gear list:lester11's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 12-100mm F4.0 Olympus 25mm F1.2 +7 more
What you say makes a lot of sense. Actually I've more or less settled on a focus differential of 5 with an aperture of f5.6 but I'll give your 2 at f5.6 at try. Someone suggested that matching the focus differential number with the f-stop number seems to work. That may be a good starting point but I notice that Kazuo Unno's shots do not follow this pattern. If only we could get into his head.
I don't know how Oly's focus stacking compares to others but it is certainly very susceptible to motion. Hand held shots make for some fun images but for quality. a tripod and a motionless subject are essential. I no longer attempt to photograph wild flowers if there is even a breeze about. Forget about moving insects. The subject will be sharp so the software is aligning quite well but the motion artifacts around it are too distracting.
Yes, choosing the right focus point for focus stacking is a bit of an art.  The software seem to have some smarts built in to decide on how many shots it needs to take in front of the focus point.  I'm going on the assumption that it is using the 1/3 in front 2/3 behind rule but it would be nice to know.
New Focus Stacking Tables
7
The previously posted Focus Bracketing table has been reworked for the Focus Stacking function of the E-M1. The differences between Focus Stacking and Focus bracketing are:
1. With Focus Stacking the final output is produced in camera as a JPEG. With Focus Bracketing the shots have to be combined later using third party software.
2. The Number of Shots is fixed at 8 and not adjustable.
3. The initial focus point is located part way through the sequence instead of at the beginning.  For Focus Stacking the step sequence is 0, -2, -1, 1, 2. 3. 4. 5 where 0 is the initial focus point.  For Focus Bracketing the step sequence is 0, 1, 2, 3, 4, 5, 6, 7.
Separate tables are provided for each aperture.  The total depth of focus for 8 shots is shown as a function of Focus Distance (runs vertically) and Focus Differential (runs horizontally).  If the Focus Differential is greater than 3 there is a risk that the depth of field may be less than the focus step.  Depth of field is not considered here.  The original document is in PDF, which has been converted to JPEG so that it can be embedded here.  It should fit on a single letter size sheet.
TwoMetreBill Senior Member • Posts: 1,992
Jeff,
Based on your use of a Panasonic lens on your Olympus body there seems to be only two rules for selecting a lens for focus bracketing:
1. M43 mount
2. AF
Is this correct?
Thanks,
Bill
 TwoMetreBill's gear list:TwoMetreBill's gear list
Fujifilm X-T3 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +2 more
daddyo Forum Pro • Posts: 12,670
Re: New Focus Stacking Tables
Thanks a lot for this very informative post. This Chart answers a lot of questions. For what it's worth, in most macro/close up shooting situations, I find the using the #3 interval and aperture of f5.6 works very well.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Good stuff! Now to design, manufacture and market a circular slide rule of this data. One would have thought that Oly could build this into the menu. Better still, a total DOF slider in the VF. The camera knows the focus distance, the CoC, the chosen total DOF, it can then adjust the aperture and focus differential, then shutter speed.
BTW, I normally use a cable release for focus stacking. Today I tried the Wi-Fi release but got just one exposure. Couldn't find mention of this in the manual. Perhaps it's a bug.
I tried focus differential of 3 at f5.6 but couldn't quite get the depth I needed for wild flowers so I went back to focus differential 5.  I'm not seeing any OOF banding, at least not on the screen.  I could go to f8 but then the background blur will not be as good.
gary0319
gary0319 Forum Pro • Posts: 10,522
Great job Richard, thanks. For sharing. Your example here confirms my meager attempts at decifering the optimum step/differential  for my type of shooting, which is flowers. I have been using 5 steps, differential  3 as my default. Shot below is a 5/3 handheld.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
Nice!  You must have hands of steel.
gary0319
Actually, at a burst rate of 10 fps, the 5 frames in the bracket set happens pretty quickly, and the IBIS of the E-M5 II is pretty amazing. Halicon Focus does a great job of aligning the shots, and a slight movement left or right of the initial focus point can be accommodated. But..........if you move forward or back, the size of the subject changes and your stack will turn to mush.
If I were to use to many more than 5 frames in the set, it would be more difficult to hand hold.
lester11
Hi Richard
I've measured actual depths of field in an Oly focus stack, and, except for the 0.2 m distance, the table seems a good approximation (I've only measured for distances of 200, 250, 330, 500, and 1000 mm to subject).  For some reason, the DoF in my near 1:1 focus stacks is only around one third of that predicted by the table (I measured at apertures 2.8, 4, 5.6, 8):
At greater subject distances, the actual stack DoF seems to agree within fairly broad measurement error, for example, at 1 m:
Lester
