Best pancake lens for NX1100?
Started Aug 26, 2016 | Discussions
Caleb PM New Member • Posts: 5
Unless I'm mistaken, a "pancake" lens is a fixed focal-length lens that is fairly compact (right?).
I have a Samsung NX1100, which I think is a pretty good camera, but I have always found the images to be somewhat soft. I'm thinking that a fixed-length lens (25mm to 45mm, although 35mm would be ideal) would give me sharper images. Can anyone recommend a sharp lens that is not too expensive?
Let me add that I would use this lens for pleasure photography (outdoors).  Can I also use a prime lens for macro shots?  My macro shots are never very close -- always about 18 to 24 inches away.
Thanks.
Samsung NX1100
Kisaha Senior Member • Posts: 2,300
Re: Best pancake lens for NX1100?
30mm/2f. 45mm in 35 equiv.
For macro, there are some cheap macro extension tubes, that transform every NX lens to macro.
Thanks.
ttbek Veteran Member • Posts: 4,869
The 30mm is excellent in all but focus speed.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Valentin G Contributing Member • Posts: 934
Another vote for the 30mm lens. It makes a great little kit for general street shooting and especially for parties - perfect focal lenght for small group portraits and fast enough to use without flash indoors.
 Valentin G's gear list:Valentin G's gear list
Olympus Stylus 1 Panasonic Lumix DMC-ZS50 Panasonic FZ80/FZ82 Sony SLT-A57 Panasonic Lumix DMC-G7 +10 more
TJL LTFF
TJL LTFF Senior Member • Posts: 1,728
There are 3 NX pancakes: 16mm, 20mm and 30mm. I enjoy all three, but use the 30mm the most. The 45mm is really good but it is twice+ the size of the other 3.
Don't know what expensive might mean to you, but the 30mm is the sharpest of the 3.
I use my 30mm a lot for the outdoor shots - it has excellent resolution corner to corner from f/4 and narrower. I leave mine at f/5 or f/5.6 for almost all outdoor shots. And if I need wider, and don't have the 16 or 20mm with me, I will shoot 2 or more overlapping photos and stitch them together in post-processing.
Not by itself; there are adapters that can turn it into an ok quasi-macro.
 TJL LTFF's gear list:TJL LTFF's gear list
Sony RX1R II Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS +10 more
That's true, actually, with the 30 couldn't you get to just about 1:1 true macro with the tubes? But the working distance would be.... unworkable and focusing would be a giant pain. But I don't think he's looking for a true macro, "My macro shots are never very close -- always about 18 to 24 inches away." The minimum focus distance of the 30mm is "Minimum Focus Distance, 9.84" (24.99 cm)."  according to B&H, so the actual distance shouldn't be an issue for him.  The magnification ratio though might be much less than he expects, but to get a better magnification ratio at the same distance he would need a longer focal length and in the NX lens case be giving up the compactness of the pancake design.
OP: Maybe you could post a few photos showing how much macro you're looking to get, let us also know the distance and which lens you used.
OP Caleb PM New Member • Posts: 5
Thank you for the advice.  I assume I can find the model numbers for these lenses on the Samsung site.
A little about my photography skills:  I've been using cameras for years, but mostly on automatic settings.  I don't have a clear understanding of F-stops, etc.  My macro photography is of products:  I put jewelry components on a plate on my desk, stand over them and shoot (in aperature-priority mode, F5.6, which I found gives me the sharpest shots).  I hold the camera about 20-22 inches above the desk surface.  I am zoomed out when I do it.
This brings me to another topic:  The camera settings for macro photography have always confused me.  My kit lens is always in the wide position when I photograph, but I have read that some experts recomment zooming in.  As you know, the NX1100 doesn't have a macro mode, so the camera does the focussing for me.  So if I'm using my kit lens in wide mode to do my macro photography, why can't I use a prime lens for macro photography, since the prime lens is always in wide mode?
Of course, with the camera at least 20 inches above the jewelry components, some might consider my jewelry shots to be more portrait than macro.
By the way, the 30mm lens is 30mm on the camera, or is there a conversion factor?
Thanks!
Thanks!
In my reply just above, "45mm equiv." .
More precisely it is 1.54Xwhatever number.
You have mixed up some concepts and techniques. You do not do macro photography that way.
If you have a 20-50, then "wide" is 20, which is close to 32mm equiv. (to 35mm photography, that is). The key here is "focal length". Prime lenses have a fixed focal length and zoom lenses have variable focal lengths. "Wide" and "Tele" are indications on zoom lenses (or compact/bridge cameras) to show you what way to turn the zoom ring.
You should read the latest NX camera's manual, the first chapters are very good describing basic photographic concepts and variables.
The cheapest way to experiment is to buy the afforementioned macro tubes (they go something between 30-50$, I think they are all the same, so the cheaper you find are keepers!). The only real macro lens is the 60mm macro, which is manufactured with macro photography in mind.
Thanks!
The kit zoom lens is 20mm-50mm, and I set it at 20mm when I take my macro shots.  Is that the wrong thing to do?
The word "tube" is new to me.  I know what a lens is, but not a tube.
If the 30mm pancake lens is 45mm equivalent, that's pretty narrow isn't it, or do you find that a flexible width for street photography?
Thanks!
It is not wrong, it just ain't macro!
Macro photography is the very close focusing (a bee on a flower) and the reproduction of 1:1 life size ratio images. There are dedicated lenses for such a job, the NX one is the 60mm macro (go check the Samsung website about it, they explain thongs too!).
You can achieve similar results with cheap adapters, which called the macro tubes. What they do, is simply move your lens further from the sensor, but that increases lens magnification of the said lens.
Search on ebay "Fotga macro extension tube for Samsung NX mount", they go from around 20$. Pretty cheap and they can be very exciting if you are not familiat with real macro lenses.
There is another thing you can do now (and maybe zoom in, is better than wide shots) and that is Crop. Because the NX500 has the biggest megapixel count in its segment, you can take a picture, and crop it further, and still have a perfect usable high quality picture. And you can do that for free!
30 is tiny small, 2f apperture, very sharp and you can find for really cheap. It is like a standard lens (the well known 50mm lenses that are so common, that called "the standard") but a bit wider (closer to what the human eye sees, something like that). I believe it is a  very good lens for general photography and I use it like this. Sometimes I use the 45mm, which is excellent and fast focusing (30mm is not very fast focusing, and its main disadvantage) but it is 77mm equiv (around there 1.54X45mm= do the math!) so more of a short tele portraite lens, still I do use it for street photography, 30mm is wider. These two lenses are among the NX highlights, cheap, very good performers.
Thanks!
Let me try to put things in perspective, for focal lengths. Samsung NX cameras use APS-C size sensors, so there is a 1.54x crop factor relative to "Full Frame" 35mm sensor cameras (e.g. Canon 5D).
Samsung Focal Length 35mm Equiv. Length (approx.) Category/Common Use
12-24 18-36 Ultrawide zoom, landscape, architecture
16 24 Wide prime (note: pancake)
20 30 Wide prime (note: pancake)
30 45 Normal prime, general shooting, environmental portrait
45 67.5 Short Telephoto, half length portrait
60 90 Short Telephoto, happens to be a macro lens
85 127.5 Short Telephoto, portrait (headshot)
18-200 27-350 Wide to Telephoto Zoom, anything you think it's sharp enough for (this lens in not sharp T.T)
50-200 75-350 Short Telephoto to Telephoto Zoom outdoor football match
50-150 75-225 Short Telephoto to Telephoto Zoom
etc..... There are of course more properties of the lenses to consider, but maybe that gives an idea of the focal lengths.
For macro, "true macro" will refer to a 1:1 magnification ratio, where the size of the image projected on the sensor is the same size as the object in real life. This is achievable for these lenses only at their closest focus distance. For almost all zoom lenses the highest magnification ratio will occur when at the longest focal length and closest focus distance (e.g. on your 20-50 things will be most magnified at 50mm, set to manual focus and moved to the closest focus and then move the camera to focus). There are occasionally lenses that will focus closer than 1:1, like the Laowa 60mm that goes to 2:1 (double life size) and is the only lens to do with while still being able to focus on far away objects. There is also the Canon MPE65 that allows up to 5:1 magnification (practically a microscope) and does not allow focusing on far objects. Then there are a group of lenses that may be advertised as macro or close up lenses but do not achieve at least a 1:1 magnification ratio, these are often longish zooms and might reach a magnification ratio of 1:4, 1:3, or 1:2 in a really good case.
The jewelry shots as you describe them would I guess be product photography, I don't think many people would use portrait for shots of inanimate objects and they also wouldn't use macro for a shot with such a low magnification ratio. The 30mm will be able to handle such shots just fine.
"So if I'm using my kit lens in wide mode to do my macro photography, why can't I use a prime lens for macro photography, since the prime lens is always in wide mode?"
Ah, I think this misconception comes from using some non-interchangeable lens cameras with a macro mode. In this mode the lens often seems to be zooms out the most, but they move internal elements of the lens to allow very close focusing, a normal zoom lens for an ILC is not designed to be able to do that (though 1 exception does come to mind). So, there's two ways to get a better magnification ratio, either a longer focal length, or a shorter minimum focusing distance. These use the later method and to get the highest magnification your objects needs to be extremely close to the lens, sometimes even right on the lens' surface (like in the case of my SX10IS). This is obviously a problem is you want to shoot closeups of insects that aren't happy being that close. A macro doesn't need to be any particular focal length but the lens needs to be designed for it, the NX 30mm is not but the 60mm is. You can find macro lenses in a variety of focal lengths though, Canon has one as long as 180mm (means you can get 1:1 magnification while being further away) and Laowa has one as short as 15mm, for which you need to be practically touching the lens to the subject for full 1:1 magnification (similar to the non interchangeable lens cameras).
You'll notice that at 15mm there is often does not have the high 1:1 magnification of the subject because it is difficult to get them that close to the lens, e.g.: https://www.flickr.com/photos/eulfab/25495506543/in/photolist-EQX8R2-zQtwnj-JoV7tY-JEBehj-BGXPLe-GDEae5-JGQ5Xz-JPEMFk-HCGPqh-JPEKie-JGPYt2-JEB9WW-JEBdwS-uzu81f-GnQKQJ-JooTXC-EGbQZ-H1e4Lp-JepRFZ-7TvQUf-7TszVT-a5Su97-5ghyn-4JHQ1p-8GKRz5-8YFVQz-8NjJ6D-p4dAd4-4JN5tN-9N8aPz-7TsACr-5pwSwv-4JHPGB-8YG17x-8EyX59-4JHPEZ-4JN4fo-7Tszap-7TvRuj-E4hH7-4JHPKc-4JHP7t-7TvQXm-7sktP1-4JHP5H-7HJBDG-7TvRim-8YFNoc-7TvQC9-nswAdM
https://www.flickr.com/photos/nickadel/18756920570/in/photolist-uzu81f-GnQKQJ-JooTXC-EGbQZ-H1e4Lp-JepRFZ-7TvQUf-7TszVT-a5Su97-5ghyn-4JHQ1p-8GKRz5-8YFVQz-8NjJ6D-p4dAd4-4JN5tN-9N8aPz-7TsACr-5pwSwv-4JHPGB-8YG17x-8EyX59-4JHPEZ-4JN4fo-7Tszap-7TvRuj-E4hH7-4JHPKc-4JHP7t-7TvQXm-7sktP1-4JHP5H-7HJBDG-7TvRim-8YFNoc-7TvQC9-nswAdM-4JN3Tj-4JHPQP-8No5MC-nbjAtA-5Auags-7FwvEF-4JN523-7TvQz9-4JN47N-7TsAyF-6booWq-4JN4rq-4JHP3R
It's actually kind of difficult to find a 1:1 macro shot taken with it. Looking at 180mm shots: https://www.flickr.com/search/?advanced=1&tags=Canon%20180%20macro you'll notice some differences, the much narrower field of view shows much less background and what it does show is much more blurry. Shots that look equally magnified are actually taken from much further away with the 180mm. Common macro focal lengths include 60, 90, and 100. 60 often being for APS-C cameras that will be equivalent around 90 or 100 since their crops are about 1.6x for Canon APS-C and about 1.5x for everyone else.
Finally, macro tubes, they look like this: https://www.google.com/search?q=fotga+extension+tubes&safe=off&client=ubuntu&hs=FTf&channel=fs&biw=1535&bih=711&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiLzb340eHOAhUIAxoKHdk-AM8Q_AUICCgD#safe=off&channel=fs&tbm=isch&q=fotga+NX+extension+tubes
They often come as a set of two and are really just spacers between the lens and the camera with pass through connections for the electronics.  The effect of putting in spacers like that is that you can't focus on far away things anymore but it makes the minimum focus distance smaller.  How much of a difference they make depends on the focal length of the lens you're using them with, the small the more difference they make, but the more your chance of ending up with an unusable combo.  For instance, a 20mm lens with 30mm of extension tubes added will have it's closest focus distance inside the lens, and probably it's farthest focus as well.... rendering the combo totally useless.  50mm with 26mm of extension tubes (the total for the two in the commonly available set for NX cameras) is still quite usable for macro but would be totally useless for shots of things at the distances you're shooting.
I put the extension tubes to use with the 18-55mm kit lens at 55mm here:
I think that you've answered all my questions.  Thank you very much.  I'll get the 30mm lens.  The price of $250 to $300 is almost as much as I paid for the camera, but it will be worth it if it gives me sharper shots.  I'll try the lens by itself for my macro shots (which really are more like portrait shots than macro shots).  If the images aren't good, I'll get a tube.
I have indeed been cropping all of my shots.
One of the reasons I got the NX1100 is that the color accuracy was better than average (according to one review site).  I didn't know this at first, but camera manufacturers purposely tweak the color reproduction to make it more pleasing, but that's bad if you are shooting colorful products (like the beads that I sell), and you want the colors to be accurate.
Thanks again for all your help.  I'm very grateful.
ttbek, thank you for all the information.  It was more than I actually needed, but some of it will be very useful.  I'm very grateful.
I've decided to buy the 30mm pancake lens and a tube, if the tube is needed.
No problem!
250-300$ is too much thought, most of us here get it for definitely less than 250$. I got mine used from ebay. Even thought lenses tend to be more expensive than cheap camera bodies (just check the 2 S lenses, the best native NX lenses one can buy, you wouldn't be able to count how many 1100 cameras can you buy with the money the 2 S lenses cost!), they really worth it.
The macro tubes can be found for very cheap, you should try them, they are good fun! There are a couple of threads here about them with more information.
Good luck and good pictures taking!
