K1XH
Contributing Member
Re: D500 Grip and battery/charger questions
I have has very good luck with 3rd-party EN-EL18a batteries as well as the 3rd-party dual charger for those batteries. They work as well as the Nikon charger for my D4 (now sold) and the batteries work in several different cameras, D4, D5, D810, D500 as long as you have the proper end-cap for the battery. Since I no longer have the D4 I cannot compare battery levels between that camera, but I will try with the D810 after I return home from work. Either way, I get thousands of shots per battery, and end up re-charging the battery long before it is depleted, just to have a full one.
I do, however, use the Nikon grips on all my cameras, when I went to purchase the EN-EL18a batteries they were unavailable so I got a couple really inexpensive ones from eBay. About $40 each. They worked SO well that I got the generic 2-slot charger, which looks and acts the same as the Nikon charger. I believe the charger was around $50. I cannot compare them as I no longer have the Nikon charger, I sold it with the D4.
I couldn't be happier, these 3rd-party Li-On batteries work great. I read about everyone whining about the dismal performance of the EN-EL15 and I sit back with a big grin on my face as I enjoy literally thousands of shots per charge, even with the longest of lenses. The EN-EL15 is best left in the body as you use something else more powerful in the grip.
I can understand wanting to keep it light, but it makes no sense whatsoever to put on a 500-600mm lens with a single EN-EL15 in the camera under the guise of 'keeping it light'. The grip and battery balance the camera well, even with the smaller 70-200/2.8 lenses. I admit, the combination with a long lens is NOT something you wanna sling around your neck for a day of shooting, I use Manfrotto tripods and monopods for the stuff I shoot with longer lenses and that certainly saves my back and allows me to shoot much longer (as I get older and slower...).
In my opinion you can't argue with the performance of the grip and battery, but I agree it is up to you whether you choose Nikon branded stuff or not. I have had excellent luck and performance for years now with a combination of both.
