Review: One month with the Sigma SD Quattro
Started Aug 17, 2016 | User reviews
Jan Rietsema Contributing Member • Posts: 509
Re: Review: One month with the Sigma SD Quattro
dsteiner wrote:
Enjoy! The 18-35mm lens is stunning.
One problem with this lens: A lot of CA in the corners, ok, no problem with SPP, but in jpg iy doesn't look good. Will post some examples soon.
kreislauf
kreislauf Regular Member • Posts: 228
mkowalski21 wrote:
jrdigitalart wrote:
You might want to go to your bathroom, look in the mirror and witness (at least part) of your problem regarding shooting with your Sigma camera in a studio with strobes.
With a Nikon or other traditional DSLR you can manually focus in near pitch dark lighting through the viewfinder in a second. But thanks, I'll go look in the mirror.
relax. you both have a point.
1st we all could do better and learning to deal with a specific camera - as if it would be our only one - would help to be in control even under tricky conditions.
2nd focussing through the lens on a OVF has to be better (unless your sensor has high iso capabilities like a sony 7s). This is a limitation for the Sigmas, no one denies this.
But unless you figure out a way to focus (eg. have a spot on the subject and swith it on briefly), you will have a hard time, no doubt. I have problems focussing with my DP2M and especially with DP3M, but slowing down (both the lens! and my shooting style) I usually get the depth of field that I intended to have. And in my opinion, the pictures are well worth it. I just love my small wonderboxes!
 kreislauf's gear list:kreislauf's gear list
Ricoh GR III +1 more
PCummins Regular Member • Posts: 209
Jan Rietsema wrote:
Need a good strap now for my new combo, I will post asap.
I ended up using a Peak Design Slide Lite for my SD Quattro, you just screw in the base plate into the tripod mount, then you can clip on/off the strap itself. I found the Sigma side mounted straps to be less versatile, but with the Peak Design you get 4 clips so you can quickly switch from side mount, side + base, or both base mount clips depending on how you prefer to carry/use the SD Quattro.
Carlos Taylhardat
Carlos Taylhardat Junior Member • Posts: 48
I have always been curious towards the Faveon Sensor technology which isn't easy to find in Canada, but have also been surprised that Sigma is the only camera using this sensor - why wouldn't they share it or why wouldn't other manufacturers add it to their models.
artofheadshots.com
You're beautiful Energy
 Carlos Taylhardat's gear list:Carlos Taylhardat's gear list
Canon EOS 5D Canon EOS 6D Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Sigma 85mm F1.4 EX DG HSM +2 more
D Cox Forum Pro • Posts: 32,979
Mainly I think because of the limited ISO range, which is like that of colour film rather than recent digital sensors.
No problem for those who have long experience of film, but not good for those who want to shoot sports or active kids.
Sigma fp
mmr Contributing Member • Posts: 878
This myth always frustrates me, that you can't shoot kids or sports with the quattros.  Sure you _can_, it's just harder and requires a bit of skill (and burst mode).  As in:
Kids with sports?
Is swimming a sport?
How about being on a swing?
What about biking?
Yes, shooting with my om-d em-1 in any kind of low-light conditions makes things much easier, or if I want to use a 75mm lens.  But shooting kids/sports is not impossible when you're in the conditions where the sigma cameras work.
 mmr's gear list:mmr's gear list
Sigma DP2s Sigma DP2 Merrill Sigma dp2 Quattro Nikon D300 Olympus E-M1
Kids with sports?
What about biking?
I didn't mean that it was impossible. People shot pictures like this on film. But it isn't easy and foolproof.
"When you're in the conditions where the sigma cameras work.". People often want to photograph kids in other conditions. The sun isn't always shining.
Sigma fp
Oh, no doubt.  Don't get me wrong, I've had my share of frustrations shooting like this with the sigmas.  I just dislike the idea that because it's hard to shoot kids in the dark, that it's impossible to shoot kids or sports period.
I'll shoot some 500 shots of a basketball game with the olympus, and end up with only about 20-30 keepers.  I just can't shoot at that level of frequency, with a high enough iso, at the focal length that makes the shots interesting-- for that use case, sigma clearly falls flat.
richard stone Veteran Member • Posts: 3,472
I've got some beautiful images, some with my kids, taken with my SD10. People make it sound so difficult. I'm not sure why. It's almost like someone wants it to be difficult. You hold the camera still and do your best. It doesn't always work out. But nothing works all the time. On the other hand, lots of cameras give you mediocre shots every time you use them. I'm not so sure that's a better outcome, over-all.
 richard stone's gear list:richard stone's gear list
Sigma SD10 Sigma sd Quattro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 30mm F1.4 DC HSM Art
ELSELS Senior Member • Posts: 2,026
dsteiner wrote:
I haven't tried the time lapse feature yet, so can't comment on it's performance.
I can't find reference to this feature, in the PDF manual..?
Are you referring to it being provided by Sigma, built-in to the camera (menu)?
Ed
Camera Equipment, Computer Gear and more
MrImprovement Regular Member • Posts: 278
Ed
The interval shooting feature, I think, is what is being referred to.  On my dp2Q it is under Drive Mode, on the first menu panel that comes up when I press the Menu button.
Note: if doing a timelapse, you can conserve battery/storage by not shooting bigger than you need. 1080p is 1920x1080, 4K is either 3840x2160 or slightly higher (there are a few 4K standards).
Ed
Thanks for your comments and I checked the Sigma SD Quattro (PDF) owner's manual - and looking under: "Interval Timer" (page 66) - I did find the description, which would "equate" to being considered Time-Lapse capability.
Ed
Ed
Ed
Also, you can use ShotCut (free) or Photoshop CS6 or later (maybe even earlier versions) to turn the many time-lapse images into a video format.
Innocentius Senior Member • Posts: 1,009
Indoor sports like basketball are a niche in the niche of sports photography.
The flickering of the fluorescent tubes wreak havoc if you shoot at shutter times like 1/250. Some are light, others are dark and it is a pain to shoot.
The newer camera's with anti-flicker option surpass this problem, highly recommended.
 Innocentius's gear list:Innocentius's gear list
Olympus Stylus Tough 6010 Sigma DP1x Fujifilm FinePix X100 Canon PowerShot A1200 Sigma DP3 Merrill +10 more
