Good Value!
Started Aug 13, 2016 | User reviews
Joed700 Regular Member • Posts: 127
Good Value!
If you are into portrait photography and don't have a huge budget, this is your lens from Canon.  It's sharp even at f/1.8 and has very nice bokeh.  At f/1.8, it is easier to get subjects into focus than if you're shooting a f/1.2 or f/1.4 lens.  You'll definitely get more keepers on this one.  However, it's an older design lens so it has quite a bit purple fringing (CA) on highlight areas, especially if your subject is wearing something white.  Therefore, post-processing is a must.  This lens doesn't get a lot of attention like the 35mm f/2 IS probably because it's not a L series, but it's gem!
 Joed700's gear list:Joed700's gear list
Sony a7R III Sony a7 III Sony FE 55mm F1.8 Sony FE 28mm F2 Sony FE 90mm F2.8 macro +5 more
Canon EF 85mm F1.8 USM
Telephoto prime lens • Canon EF • 2519A003
Announced: Jul 1, 1992
Joed700's score
4.0
Average community score
4.5
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Re: Good Value!
I tend to agree. This lens dates back to the film era when we were desperate to get anything usable under low light conditions. It was widely known in newspaper photographer circles as a key basketball lens.
Wide open the chromatic aberration is pretty fierce on the edges, though the center is satisfactory. Focusing is a bit slower than modern high-end "L" lenses, but the 85mm f/1.8 is a bargain at the price.
I'd sure like Canon to update this old workhorse, though.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Spotted Cow Senior Member • Posts: 1,586
Re: Good Value!
Just a quick clarification...the 35mm f2 IS also not an L lens. I too enjoy using the 85mm f1.8. It's not unusual for me to take only the aforementioned two lenses out.
BlueRay2 Forum Pro • Posts: 14,816
Re: Good Value!
this is the only EF non-"L" lens i have and like it, or else, i wouldn't have it the CA it generates can easily be rectified in PS!
Scott Larson Veteran Member • Posts: 7,505
Re: Good Value!
I still use it for basketball. Why throw away a stop of light with an f2.8 lens?
It's worst when there are bright lights out of focus behind your subject. This will often cause purple to smear into dark areas. It's mostly gone at f2.0 and I've never seen it happen at f2.8. I take about ten thousand photos with it every year.
I haven't noticed any slowness and I've used it next to my 70-200mm f2.8 II.
What would they do? The 85mm f1.2 also has purple fringing. It's somewhat sharper of course but with a ton more glass. I'm guessing that any improvement would require a lot of expensive changes.
I also shoot with the much older FD 85mm f1.8. It's identically sharp and is no better or worse with CA. The basic 85mm f1.8 lens has been working well for decades.
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
