16-35 4L IS vs 16-35 2.8L II?
Started Aug 10, 2016 | Questions
Ahnaf Akeef
Ahnaf Akeef Regular Member • Posts: 276
Everything I've read so far says that the 4L is sharper - both at bigger apertures and in the corners.
1. Which one is sharper at f 8,11,16?
2. Excuse the amateur question, but what reasons could possibly make me want the 2.8L II over the 4L?
My primary intention here is landscapes. Astro isn't of any concern.
Thank you.
 Ahnaf Akeef's gear list:Ahnaf Akeef's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +2 more
David Parsons Forum Member • Posts: 76
Re: 16-35 4L IS vs 16-35 2.8L II?
For landscapes - no reason - you do not need f2.8..
I have the f4L and think it's fabulous. Have never used the 2.8 but all comments I've seen say f4 better unless you really need f2.8....
 David Parsons's gear list:David Parsons's gear list
Canon PowerShot Pro1 Olympus TG-5 Canon EOS 400D Canon EOS 7D Canon EOS 6D +8 more
lighthunter80
lighthunter80 Contributing Member • Posts: 990
Thank you.
I've sold my 2.8 for the 4.0 IS a while ago and am super happy with the switch.
The main difference even at smaller apertures  (f8+) is corner sharpness, corner sharpness, corner sharpness...
 lighthunter80's gear list:lighthunter80's gear list
Canon EOS R Canon EF 70-200mm F2.8L IS II USM Sigma 35mm F1.4 DG HSM Art Sigma 50mm F1.4 DG HSM | A Canon EF 16-35mm F4L IS USM
arty H Senior Member • Posts: 1,546
I use the 17-40L, so my comments should be taken with a grain of salt. If I didn't like my lens so much, I would be looking at the 16-35F4IS. All reviews have it as an excellent lens. The only reason to get the F2.8 lens would be for shooting events using an ultrawide. The larger aperture would help keep shutter speeds high, and you need that for people photos. For anything else, the 16-35 F4 IS would be my choice. It has IS, and that can be handy in very low light, like the interiors of museums, cathedrals, and a variety of travel locations.
If I used the ultrawide more, I would be in the market for an upgrade to the 16-35F4 IS. As it is, I use the 17-40L for travel, or occasionally on a crop body.
Nick5
Nick5 Senior Member • Posts: 1,664
Sorry Arty.
You may or may not want to hear this.
Your summation of the f/4 L IS is the exact reason I upgraded from the 17-40 f/4 L to the 16-35 f/4 L IS. A trip to Rome last summer was the exact reason I bought it.
"It has IS, can be handy in low light, like the interiors of museums, cathedrals, and a variety of travel locations"
Walking all day I'm the heat and not having enough water in your system leads to dehydration, which for me leads to the "Yips". Is not only assists in the reasons for IS, but delivers sharp images at 1/10" hand held as tripods are not permitted.
Needless to say I use the 16-35 f/4 L IS so much more than the 17-40 f/4 L. Since selling as used, the prices are low for the 17-40 f/4 L, I am keeping it as a great backup, which is more valuable to me than the cash currently.
 Nick5's gear list:Nick5's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon TS-E 24mm f/3.5L II +8 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Thank you.
Very sensible question--I've heavily used both for years:
When stopped down to, say, f/8 the 16-35 f/2.8 and the 16-35 f/4L IS are about equally sharp. But at f/4, the edges and corners of the 16-35 f/2.8 is pretty awful and the f/4 IS version blows it out of the water. Center sharpness is about equal even at f/4, though.
Photographers bought the f/2.8 lens for years because they needed the f/2.8 speed. For instance, for photojournalism or night sky photography. But these days the f/4L IS is so superior that most opt to use it instead.
For your purposes the choice is crystal clear: buy the 16-35 f/4L IS.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
cpharm86 Senior Member • Posts: 2,742
Maybe if the rumored 16-35mm f/2.8 iii makes an appearance this may be a different story with the comparible sharpness. Then one has to decide if they want to pay the price and how valuable the 2.8 will be.
I bought the f/4 this year but have not really put it thru the test. I will be in Mammoth Lakes, Ca. this weekend and will no doubt use it quite a bit along with the Canon 100-400mm ii that I bought at the same time.
hotdog321
The rumored 16-35 f/2.8L III is sure to be significantly more expensive and heavy in comparison to the 16-35 f/4L IS, though I'm sure Canon will make significant improvements in sharpness compared to the current f/2.8 versions.
You're going to love your new 16-35 f/4L IS. Post pics!
Yes, the price will probably be a little south of your 11-24.
I've seen some nice stuff you posted with your 11-24. I considered it but it would not be that useful for me from the 11-15 mm focal range.
I'll plan on posting some pics on this thread next week when I return. I'll be using the 5Dmiii.  I have the 1Dx ( the original- the obsolete one now!! just kidding!) but won't be taking it with me.
hotdog321
Thanks! The 11-24 f/4L is very unusual and most photographers really do not need or want that bad boy. The cost, weight and extreme wide angle makes it a real specialty item. Most would be much happier with the 16-35 f/4L IS.
For me, I still stand in slack-jawed amazement that such a critter was even possible. It's the first lens i grab when I have an architecture assignment.
Landscapeforfun Contributing Member • Posts: 739
The 16-35 f/2.8 III is supposed to be announced in like 2 weeks as well. So might want to wait if you are torn. But I'm all honesty if you are just doing landscape then the 16-35 f/4 is probably the better bet either way.
 Landscapeforfun's gear list:Landscapeforfun's gear list
Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Rokinon 14mm F2.8 IF ED MC Rokinon 24mm F1.4 Aspherical Canon EF 16-35mm F4L IS USM +1 more
ed rader Veteran Member • Posts: 9,068
except....
it's not sharp @ f2.8 but is soft in the corners at all apertures.
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
clager Contributing Member • Posts: 824
I have both and used them on assignments and stock photography, the f4 version is far better at the wider ends, no question about that. None is 100% perfect, no superwide ever is. You find that at. 16 mil focal range even the f4 version will give very slight CA at the corners.
However, the f4 have superb corner to corner sharpness at the widest ends, the f.2.8 dont.
 clager's gear list:clager's gear list
Leica S2 Canon EOS-1D X Canon EOS 5D Mark III +1 more
Nick5
When travelling, I usually go out with one lens for the day. I will either use a fast prime for indoor shots at a museum, or a zoom like the 17-40 when I expect to need to go very wide, like some places in London or Rome. Wide lenses are handy in Rome.
Unfortunately, sometimes it is a help to have IS on a wide zoom for those interior shots. I wound up running ISOs higher than I wanted. While I can hold at lower shutter speeds with short focal lengths, it would be nice to be able to stop down and shoot at lower ISOs and smaller apertures. You are right, I have been putting off the purchase. Perhaps my next trip to Rome???
Ahnaf Akeef
OP Ahnaf Akeef Regular Member • Posts: 276
Thank you for all your responses, everyone. I've ordered the f4L IS version.
This is going to be my first lens that allows anything that is wider than 24mm, so I'm pretty excited.
As for newer lenses coming out, it's alright really. If I really get into wide angle photography, I'll just hold out for the 11-24 Mark II, whenever that comes out.
hotdog321
I doubt we'll ever see an 11-24 f/4L II. Canon pretty much made a major breakthrough with this lens and I don't see how it can be realistically improved. It is just that good.
Here are some photos with the 16-35 f/4L IS. I don't think I did the lens justice with my outdoor landscape skills. I have not shot any landscape in a long time I'm usually more involved in events and weddings.
This was handheld at 1/25th sec.
