5D Mark IV initial specs?
Started Aug 9, 2016 | Discussions
(unknown member) Forum Pro • Posts: 11,521
first sign that the Japanese wall which is Canon preventing leaks has been breached? perhaps?
30MP
compact flash
24/30fps @ 4k
120fps 1080
240fps 720
USB 3.0
cable release, more touchscreen UI, ergonomic changes..
http://www.canonrumors.com/canon-eos-5d-mark-iv-specifications-and-image/
there was an image, it was pulled .. however it certainly showed a unique Canon camera pentaprism housing.
30MP makes alot of sense IMO
the rest of the specs are no brainers.
now what did they put into that pentaprism housing to make it that much bigger?
MayaTlab0
MayaTlab0 Senior Member • Posts: 2,759
Re: 5D Mark IV initial specs?
The 1DXII's (or D3/D4/D5) AF points illumination system requires an additional prism and LCD screen. Maybe the 5DIV features a similar arrangement and that's why it's bigger.
OP (unknown member) Forum Pro • Posts: 11,521
oh that's a good call.
I'm still hoping for hybrid EVF/OVF
Jonneymendoza2 Senior Member • Posts: 1,006
following this thread closely.
did they mention fps?
MayaTlab0
Well I'm just waiting for an EVF full stop :D. But I can see how an hybrid would be exciting to a lot of people - although I'm pretty sure Canon wouldn't exploit it to the max, as usual with camera manufacturers (for example, I wonder if it would be able to display in the OVF a superimposed rendering of overexposed areas - basically, like zebras in live view, but with an OVF ?).
As far as I'm concerned I'm just hoping to see something at least moderately exciting from a controls / user interface / operational qualities point of view, but that's unlikely.
the patent showed both overlay and total EVF modes.
in other words, you could switch on liveview and use the EVF, you could take regular pictures and have zebra, level, histogram,etc overlays,etc.
looked pretty comprehensive.
but I wouldn't expect anything drastic from a control point of view ... on any camera canon considers "professional" the changes always seem to be slight
MayaTlab0
Well let's hope that for once an exciting patent will actually show up in an actual product in full form and not in a half-realised deflated way.
Which is unfortunate as there are plenty of issues with Canon's cameras from a professional point of view (for example, the inability to save and share settings across cameras other than with the 1D series).
PhotoKhan Forum Pro • Posts: 10,937
That would definitely fall under what has been hinted about a function that would be a first in DSLRS.
PK
“Loose praise may feed my ego but constructive criticism advances my skills”
http://www.humbertoborgesfotografia.com/
http://www.pbase.com/photokhan
(PBase Supporter)
PK
it would be the bees knees for sure.
at the very least I'm looking for the same hotshoe as what exists in the M3 .. to allow the EVF to be attached.
Rick Knepper
Rick Knepper Forum Pro • Posts: 17,136
IMO, anything less than 36 MPs...
is a marketing mistake. This isn't a camera I will buy anyway but I want to see Canon having a successful launch so they can get that 120 MP camera out the door.
I am sure it will be popular among hardcore Canon fans especially if they get the DR right.
30MP
compact flash
24/30fps @ 4k
120fps 1080
240fps 720
USB 3.0
Once you've done fifty, everything else is iffy.
 Rick Knepper's gear list:Rick Knepper's gear list
Pentax 645Z Canon EOS 5DS R Fujifilm GFX 50S Fujifilm GF 23mm F4 Fujifilm GF 32-64mm F4 +9 more
jayphotoworks Regular Member • Posts: 134
Re: IMO, anything less than 36 MPs...
30MP
compact flash
24/30fps @ 4k
120fps 1080
240fps 720
USB 3.0
This camera is way underspecced if the initial specs are as listed. Canon's 5 series cameras should have superior video specs and performance to their 1 series. Not having CFast and 4K 60P is probably one strike, not having CLOG will be another. The A7III will wipe them out entirely during the next upgrade cycle given that the 5D4 won't be refreshed for 3 years if this is the case in both Megapixel and feature counts.
jayphotoworks photography
robonrome
robonrome Senior Member • Posts: 2,317
PK
that could draw me back from a7rii back into the canon fold. being able to use the camera with full info in the viewfinder means I could use the DSLR without reading glasses...it's the main reason I went all mirrorless.
 robonrome's gear list:robonrome's gear list
Sony a7R II Panasonic Lumix DMC-GX85 Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +14 more
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,720
Agree
I can see where you're coming from
Ok
Whoa! When did you hitch a ride on the hyperbole train?
Actually, probably 4 years. Maybe longer.
Rexgig0
Rexgig0 Veteran Member • Posts: 6,089
Did you click on the link provided by the OP?
Actually, I looked at the Canonrumers site today before I visited this DPR site. I was not looking for 5D IV information, but for news on the refurbished lens prices, anyway, but the 5D IV information was at the top of the column. Do keep in mind these are rumors, not established facts.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +44 more
Rexgig0
Interesting; this could be a welcome addition to my "team" of 7D Mark II and 5Ds R cameras. I like the way that the 7D Mark II and 5Ds R complement each other, and a really good general-purpose 36x24 body could make for a quite complete set.
CF, rather than CFast, suits me. I have never handled a CFast card, but have read that it is possible to jam a CF card into a CFast slot, and/or vice-versa. (I am not sure whether that would damage anything.) Especially with the night/low-light/pre-sunrise shooting I do, I can foresee myself making such a mistake.
rafalvonbur Forum Member • Posts: 53
well, give it 3 more weeks and we will see it !! cant wait but still trying to decide mark 3, 5ds or new mark 4.
Just sold my mark 2 and waiting for an upgrade patiently...
 rafalvonbur's gear list:rafalvonbur's gear list
Canon EOS 5D Mark II Olympus PEN-F Olympus E-M5 II Canon EOS 5D Mark IV Canon EF 35mm F1.4L II USM +3 more
PWPhotography Senior Member • Posts: 7,518
30MP
compact flash
24/30fps @ 4k
120fps 1080
240fps 720
USB 3.0
No CFast? I want virtually unlimited RAWs in burst shooting. The spec missing critical burst rate, how many fps? Hope at least 8fps.
A7 III is a complete vaporware. I'd think rumored A9 with bigger body and much stronger battery with possible XQD card will be Sony's effort into sport camera market. A7-series will still keep compact body.  But regardless 5D IV is still my choice in wildlife and action photos, partially on the Canon tele lenses I have already owned.
 PWPhotography's gear list:PWPhotography's gear list
Canon EOS-1D Mark III Sony a9 Sony a7R III Canon TS-E 17mm f/4L Canon EF 24-70mm F2.8L II USM +15 more
To be honest the rumor was submitted with the image.
It's probably pretty legit, there's no other canon 5D series body that has that pentaprism housing.
We know the 5d does not have canons higher end video codec though because of the lack of CFAST.
so it either has 4K @ 30p MJPEG, or another consumer h.265 low bit rate (100mbs) codec.
chironNYC Senior Member • Posts: 2,409
Sounds very lovely to me! I'm gonna get one.
Actually, I like the sound of what I am hearing. It appears that, despite the rumors, Canon kept the 5d4 as primarily a stills camera, with adjunctive video. The reports had been that the camera was going to lean video, which would have been an abrupt departure from the market and the traditions of this body.
Also, I can live happily with 30mpix. Standards have moved upward in the last few years, and Canon has very strong IS technology, which they have been putting out in lens after lens, which will help with handholding in the appcliactions for which this camera is most used. If anyone wants more than 30, there is the 5ds.
If the sensor is notched up a bit on high ISO, and AF in low light is strengthened, and they get close to 8fps, along with whatever else they have stitched into the electronics, this could be a very lovely camera to possess and shoot with. And the changes above sort of have to be there to keep the 5d4 separated from the 6d, which is also a very lovely camera, and which competes effectively against the 5d3 for many users and applications.
Canon makes cameras to make pictures with, not to read the spec sheets on, and their cameras are always very lovely to actually use. I'm gonna get this one, as soon as I am sure the bugs have been eliminated.
 chironNYC's gear list:chironNYC's gear list
Sony a7R III Sony a7 III Sony FE 50mm F1.4 ZA Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +11 more
30MP
compact flash
24/30fps @ 4k
120fps 1080
240fps 720
USB 3.0
oh pleaseee..
right now there's only one camera in the world that shoots 4K at 60p.
considering that 8k is out before 2020, it probably doesn't matter that the 5D only has 4k/30p
and .. it's not a video camera. Canon's 5 series cameras were first and foremost a still camera.
