Mac alternative to DSS?
Started Aug 8, 2016 | Discussions
swartzfeger
swartzfeger Regular Member • Posts: 360
Hi all,
I went to download DSS only to discover that there is no OS X client. Is there a Mac alternative to DSS? I have Helicon Focus, but I (think) it's mostly for macro focus stacking, etc.
Thanks...
 swartzfeger's gear list:swartzfeger's gear list
Nikon Z7 II Nikon Z 24-70mm F4 Nikon Z 70-200 F2.8 VR +1 more
Fivel Junior Member • Posts: 33
Re: Mac alternative to DSS?
Hello. You can get Lynkeos for free. I have used it for several years. It is fairly easy to use and has some decent post processing tools as well. The help file (online) are fairly good and there may be some online tutorials available.
I also installed Parallels Desktop to have Windows run on my iMac. It gives me access to all the Windows apps. I am using Windows 7. I still prefer the OSX apps.
Good luck and enjoy the Perseids this weekend, if visible where you live.
Fivel.
Marcster Forum Member • Posts: 53
Nebulosity
http://www.stark-labs.com/nebulosity.html
Marcster
swartzfeger
OP swartzfeger Regular Member • Posts: 360
You guys are awesome, thanks so much!
Robin Lee New Member • Posts: 3
Alternatively, you can also use DeepSkyStacker in OSX.
Here is a guide which is still relevant today. If you have any difficulty, I could also share the compiled version for OSX Yosemite.
http://blog.tom-goetz.org/2013/01/running-deepskystacker-for-windows-on.html
 Robin Lee's gear list:Robin Lee's gear list
Fujifilm X-E2 +2 more
W5JCK
W5JCK Veteran Member • Posts: 3,873
I use Nebulosity too, but it costs $$$ and it is not automatic like DSS. I also use Boot Camp on my Mac Mini with Windows 10 installed so I can run Windows apps. But mostly I use Nebulosity on my MacBook Pro.
Jack Swinden
W5JCK, amateur radio operator
An astrophotography hobbyist and amateur radio instructor and examiner. Sony a7 and Sony a6000. https://www.flickr.com/photos/jackswinden/albums
 W5JCK's gear list:W5JCK's gear list
Sony RX100 III Sony a7 Sony a6000 Canon EF 400mm f/5.6L USM Sony E 50mm F1.8 OSS +11 more
swartzfeger
Well, after reading Tom's blog post, I downloaded Wine, DSS, etc... it appears that OS X El Capitan is incompatible with Wineskin. There are a few workarounds, like running rootless, updating the Wrapper version (I downloaded the latest) and I'm still unable to install DSS.
I downloaded Nebulosity and based on the UI (and the price), I won't be touching it. Maybe I'm too spoiled by Helicon Focus -- drag subs onto window, click render, done.
Lynkeos... almost nearly as obtuse as Nebulosity, and seemingly only deals with (or specializes in) planetary and eclipse imaging. Still, I went ahead, gave the quick guide a read, added images to the list, aligned, then processed a stack -- et voila, don't know how I did it, but I ended up with a stacked image! And it looks good!
I'll definitely need to play with Lynkeos more, the various options etc. Still, it looks like a temporary to permanent solution.
Thanks again for everyone's input.
mac01
mac01 Contributing Member • Posts: 733
Pixinsight is what I use on OSX. Well supported and lots of tutorials. Excellent image processing software.
https://pixinsight.com
chris
 mac01's gear list:mac01's gear list
Olympus E-620 Olympus PEN E-PL5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 14-42mm 1:3.5-5.6 Panasonic Lumix G 20mm F1.7 ASPH +5 more
swartzfeger
chris
I will definitely need to dig into the tutorials on this one. Seems to be a very, very deep program!
kurja Contributing Member • Posts: 813
Regim should also work on macs.
ml6 Regular Member • Posts: 213
I was just about to suggest the same.   I only discovered regim last night, looks very promising.  It is pure Java so should run everywhere you find a Java VM.
Hi swartzfeger,
If you could pm me your email address, I could send you a pre-compiled DSS 3.3.4 with Wineskin. I compiled it under El Capitan and it works on Sierra too.
Robin.
