Problems with how the camera is functioning [NX1000]
Started Aug 6, 2016 | Discussions
JillzBOW New Member • Posts: 13
Hello to those who are reading this thread.
I am currently having problems with how the NX1000 is functioning. The problem is that it seems as if it is not working correctly. It's only a couple of years old but the problem lies when I go on auto smart, but the screen flickers to other modes, for example manual, and it switches to other mode without me turning the dial.
I am unsure of what I can do to make it work properly again, or can a camera shop fix this problem? It is difficult if i want to look at the picture as it will just bounce of to another taking mode. Does anyone know how this can be fixed?
Many Thanks!
Jilla
Samsung NX1000
JanMatthys Contributing Member • Posts: 697
Re: Problems with how the camera is functioning [NX1000]
I've read that this is a very common problem with the circuit board of the NX1000 and NX200, you move the dial to P or A or M, but the screen info rotates back & forth as if it can't make up it's mind on which mode to choose and eventually (if you're lucky) it lands on the mode you selected.
Since these cameras were discontinued and now sell for under $100 I doubt that there it is worth it to fix the problem, my suggestion is to just leave the dial on the position you use most frequently and leave it  there permanently.
OP JillzBOW New Member • Posts: 13
Hi JanMatthys!
Thank you for your comment, and I've seen that they are been sold on ebay for quite a small amount then before. So I guess I should just leave it? Do you think it is fixable though if I took it to an expert?
Kinger
Kinger Contributing Member • Posts: 549
If you are invested in multiple lenses you may want to consider buying a used NX300 off EBay. They go pretty cheap and are a significant upgrade. Doesn't help with your camera, but it may be the best solution.
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
Sendeva Regular Member • Posts: 319
Some people have had success useing a can of compressed air on the mode dial.
 Sendeva's gear list:Sendeva's gear list
Samsung NX1000 Samsung NX1 Samsung NX500 Samsung NX 20-50mm F3.5-5.6 ED Samsung NX 50-200mm F4-5.6 OIS +5 more
Thank you very much!
