Canon Rebel Auto Focus turned off..
Started Aug 5, 2016 | Questions
lukah New Member • Posts: 2
A colleague of mine borrowed my Canon EOS Rebel T3 and upon its return I notice now it does not autofocus.  Usually before I took a photo red indicator lights would flash in the view finder and the lens would autofocus until it found the right focus and would take the photo.
Now it just takes the photo regardless of how blurry it is.
I'm thinking this person may have turned a feature off but no matter what I try I can't get it back to this original setting
please help!
sleibson Regular Member • Posts: 444
Re: Canon Rebel Auto Focus turned off..
AF is controlled by a switch on the lens, not the camera. Did you check that?
Steve Leibson
www.sleibson.com
Shooting with Canons for 40 years
 sleibson's gear list:sleibson's gear list
Canon PowerShot G12 Canon EOS 20D Canon EOS 60D Canon EOS Rebel SL1 Canon EF 50mm F1.8 II +10 more
Mr Jam Regular Member • Posts: 370
Two possibilities
1- Check the AF/MF switch position on the lens.
2- Check custom function settings for exposure and focusing to the shutter release button.  It is under Custom functions "Operation/others".  Under "Shutter/AE Lock button" it should be set to 0, meaning assigning both the exposure and focus to the shutter release button.
 Mr Jam's gear list:Mr Jam's gear list
Canon EOS RP Canon EOS R10 Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F4L IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM +3 more
karl mohr Senior Member • Posts: 1,678
Mr Jam wrote:
Two possibilities
Good suggestions,
and if you haven't checked, make sure the camera in not set in the 'M' mode and make sure AI servo hasn't been turned on.  I don't think the camera has to achieve focus to release the shutter in these modes.
 karl mohr's gear list:karl mohr's gear list
Canon 6D Mark II Canon EOS 60D Canon EOS 80D Canon EF 17-40mm f/4.0L USM Canon EF-S 55-250mm f/4-5.6 IS +3 more
OP lukah New Member • Posts: 2
Mr Jam wrote:
Two possibilities
This was the solution!
Thank you so much
