Ex2F : when F1.8 just wont cut it
Started Jul 30, 2016 | Discussions
jacketpotato Senior Member • Posts: 2,244
Just delivered by Postie
Usual low light test.
Ex2F @ 24mm <> ISO100 1/125th F1.4
Apsc @ 16mm <> ISO1600 1/125th F4
(24mm equivalent typical F value 16mm Apsc lens).
I really can't see myself lugging Giant 16mm F1.4
Ex1 F1.8 quite possibly my favourite night camera, replaced by Young Turk Ex2F.
Samsung EX2F Samsung TL500 (EX1)
OP jacketpotato Senior Member • Posts: 2,244
Re: Ex2F : when F1.8 just wont cut it
From
24mm : F1.4
x1.1 : F1.6
x1.2 : F1.9
x1.3 : F1.9
x1.4 : F2.0
x1.5 : F2.1
x1.7 : F2.1
x1.9 : F2.2
x2.0 : F2.2
x2.2 : F2.3
x2.4 : F2.4
x2.6 : F2.4
x2.8 : F2.5
x2.9 : F2.6
x3.1 : F2.6
x3.3 : F2.7
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
I don't follow your equivalence.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
norman shearer Senior Member • Posts: 1,418
That last post is just the max aperture of the EX2F as you zoom out.
 norman shearer's gear list:norman shearer's gear list
Samsung EX2F Nikon Coolpix A Sony RX1R Canon EOS 5D Canon EOS 5D Mark II +10 more
tecnoworld
oh ok.
But in the first?
tecnoworld wrote:
oh ok.
But in the first?
I'm not sure about the first post. The EX2F is 7.60 x 5.70mm vs APS-C which is 23.60 x 15.60mm. That's closer to 3 stops than 4. So F2.8 rather than F4 is the equivalent?
I'm not sure if equivalency is all about sensor size though? Doesn't sensor efficiency and megapixels also play a part?
tecnoworld
I think 5.2mm f1.4 on 1/1.7 sensor should be 16mm f4.5 on nx.
Kinger
Kinger Contributing Member • Posts: 549
Would it be approximately correct to say that the Ex2f at f1.4 would give a DOF equal to f4.5 when compared to NX? Noise at low light would then be greater as well because of less available light. However, required ISO and shutter speeds would be based on the f1.4 rather than the f4.5 equivalent? So you could use a faster shutter speed in low light as compared to a NX with same ISO setting with aperture set at f4.5 on a 16mm focal length?The advantage of this f1.4 would be less motion blur and the disadvantage would be more noise and a greater DOF?
 Kinger's gear list:Kinger's gear list
Canon EOS M5 Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 10-18mm F4.5–5.6 IS STM +3 more
norman shearer wrote:
tecnoworld wrote:
oh ok.
But in the first?
Just a basic thing I tested when I had Ex1, I tested with Ex2F and my Apsc.
Semi Darkened room (toilet ):
Ex2F enables 1/125th ISO100 at F1.4 24mm, whereas my Apsc with lens F4  required ISO1600 for 1/125th (typical 16mm or 18mm lens usually starts at F3.5) .
Much more comfortable for me to carry Ex2F than a Giant £700 F1.4 16mm apsc lens
tecnoworld
Now when you compare with, say, a nx200-300 and a 16mm f2.4 pancake
ttbek Veteran Member • Posts: 4,869
Not in the equivalence calculation, no. That's kind of the point, that for sensors of roughly the same tech level we can make good estimates. They're quite valid things to consider when buying a camera, but they're not a part of equivalence for good reasons.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
If you're using the same iso, then yes, but nothing says you have to use the same iso and they won't be equivalent photos if you are.
tecnoworld wrote:
oh ok.
But in the first?
That doesn't follow from that at all. You're getting confused.
Ah please ..... C'mon now
How is testing ISO performance of two cameras with different sensor sizes with different lense in low light confusing?
Lower light : 1/125th
Apsc 16mm lens typically F3.5 or F4 requires ISO1600 (my Fuji X-Pro1 actually says ISO3200 however this is really ISO1600).
1/1.7" 24mm lens F1.4 requires ISO100 (Ex2F).
(Performing similar test shall clarify for yourself for others).
