G9X display in bright sunlight?
Started Jul 30, 2016 | Discussions
keith1200rs Senior Member • Posts: 1,944
I am looking for a compact camera to compliment my m4/3 system but worry about using a camera without a viewfinder. Is the G9X usable in bright sunlight?
Thanks in advance.
Keith.
Canon G9 X Canon PowerShot G9
boogisha
boogisha Senior Member • Posts: 2,858
Re: G9X display in bright sunlight?
I`m afraid that`s a rather subjective topic, and it certainly won`t be as convenient as a viewfinder (especially if you`re used to one).
That said, for me (owning G7 X), LCD is pretty much usable in almost all bright-light conditions - yet for G7 X it helps tilting a screen a bit from time to time, something that G9 X isn`t capable of. But you can always use the other hand for making some shade, if absolutely needed, might be even using touch-shutter alongside it for even more convenience
A very neat thing (G9 X included) is that you can temporarily bump screen brightness to maximum by simply holding the bottom ("DISP.") part of the back control ring, something that I think we all use, being really helpful, especially if you otherwise prefer low LCD brightness for regular use.
If you`re not a grumpy one, but willing to adapt and accept some compromises in favor of gain in other departments, you should be fine Size/pocketability is G9 X`s main selling point, yet the quality coming with it is pretty impressive, too (having in mind the package they squeezed it in).
 boogisha's gear list:boogisha's gear list
Canon PowerShot A75 Canon ELPH 300 HS Canon PowerShot S120 Canon PowerShot G7 X Fujifilm X-E1 +15 more
OP keith1200rs Senior Member • Posts: 1,944
Thanks for the reply. I had noticed the one button boost to screen brightness - I had a similar feature on my Panasonic LX2 which I used a lot while my kit was heavy Nikon DSLR. Now I have switched to m4/3 I need something smaller than the LX2 which I haven't used for a while. The LX2 is barely smaller than the m4/3 with 14-42EZ lens.
The G9X appeals because of its small size and 1" sensor. Slightly concerned about the touch screen dependency but more concerned by lack of viewfinder. Choices with a viewfinder are very limited though. They are either small sensor superzooms or fatter than the G9X so not much difference to the m4/3.
Keith.
gossamer88
gossamer88 Contributing Member • Posts: 769
Did not know that...cool!
 gossamer88's gear list:gossamer88's gear list
Canon EOS R7 Canon RF 100-400mm F5.6-8 IS USM Canon EOS R5 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 +5 more
rdsatkaycee Regular Member • Posts: 347
'barely' Keith, but I don't take too many in bright sunlight.  Bumping the brightness helps slightly....
 rdsatkaycee's gear list:rdsatkaycee's gear list
Canon PowerShot SX50 HS Nikon Coolpix P610 Canon G9 X Panasonic ZS200 Nikon Coolpix P1000
Thanks for the useful comments.  My G9X arrived today. Looks good so far - proper test this weekend. I couldn't bring myself to go for a small sensor superzoom just to get a viewfinder.
Keith
