E-M1 vs. A7II Thoughts
Started Jul 28, 2016 | Discussions
Zephir 750 Senior Member • Posts: 2,039
Re: E-M1 vs. A7II Thoughts
Like you, I put to a similar comparison test the E-M1 and the A7II in February 2016 and, all in all, my conclusions were about the same as yours.
Besides, having owned the E-M1 for nearly a year, I can add that I did not find this camera very reliable and, to me, its build quality left much to be desired (but this is no news),  for I ended up selling it alongwith the relevant MFT lenses. Am now waiting for the E-M1 Mk II, though - to be honest - I do not place much faith in Olympus anymore.
Thanks for posting your thread and best regards,
Joseph
 Zephir 750's gear list:Zephir 750's gear list
Canon EOS 50D Leica M8.2 Olympus E-1 Olympus E-3 Leica M9-P +19 more
zxaar Veteran Member • Posts: 4,541
Re: I am shocked
deednets wrote:
zxaar wrote:
deednets wrote:
Is this Udaipur??
Yep
Thank you. There is a hotel here that is one of my favourite place to sit down.
I hope you had good time.
::> I make spelling mistakes. May Dog forgive me for this.
Dennis12345 Regular Member • Posts: 293
  • I hated how when reviewing an image and placing your eye to the EVF the camera exits playback mode. Perhaps there is a setting I missed for this.
On this, I certainly agree. When I went from Nikon to EM1, I couldn't understand why the EM1 was set up that way. And the reverse is true-when previewing an image in the EVF, when you move your eye away, it should display the image on the screen for the remainder of the preview period but instead switches to live view. There should be an option to do it this way.
That said, I think the point of M4/3 is size and weight-not just the camera body but the body and lens together. A FF is almost always going to produce "better" images, all things being equal. As you suggest, perhaps the new EM1 will close the gap  bit.
 Dennis12345's gear list:Dennis12345's gear list
Ricoh GR Digital II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro
olyflyer
olyflyer Forum Pro • Posts: 28,730
Re: DR & HDR
Jacques Cornell wrote:
The larger sensor's DR advantage applies only with moving subjects.
That's a bit of a simplification.... a joke which shows that you don't know what you are talking about. DR advantages are ALWAYS advantages. Period.
That's a bit of a simplification... a joke which shows that you don't know what you are talking about.
DR advantages are ALWAYS advantages. Period. If you don't see that then you really don't know what you are talking about.
I get more DR from a 5-frame bracket with MFT than you get from a single capture with a 35mm sensor.
Did I say anything else? I never claimed this NOT being the case, but to claim that "DR advantage applies only with moving subjects" is simply nonsense.
Results are results. The infinitesimally small amount of additional work I have to do to get these results 1) is no burden at all, and 2) saves me thousands of dollars and several pounds of weight by letting me use a smaller, cheaper kit.
Fine. It may suit YOUR needs but that's all. To claim a generic statement based on YOUR needs is really a simplification. Yes, perhaps you save money but is that the goal? Yes, you save weight, but you also offer something for that saving and you pay the price of the saving elsewhere. Never the less, of course, if it suits your needs... fine.
If you need to take 5 images and create pseudo DR through PP (or in camera) just to get similar DR to a large sensor camera then apart from wasting time you waste memory and need to have a pretty complex work flow and special software.
Complex, ha! Select, hit control-H, wait 60 seconds, done. If that's too much work for you, I suggest you just shoot JPEGs and do no post.
Compared to an image in a fraction of a second, yes 60 seconds is EXTREMELY long time. Honestly, I thought it was faster than that.
"Special" software? Really? You consider Lightroom "special"? It's what 90% of pros and enthusiasts use.
Stitching images is not the same as NOT having to do that to get the same result. It is extra work, regardless how easy you regard it to do or what software you are using. Also remember that most people actually don't use any commercial software but stick to the one coming free of charge and most of those who do use commercial software don't use LR. For those people it is indeed a special software, but of course, LR is not only one which can create HDR and stitch images. Personally I use Adobe CS5 and Nikon Capture NX2, both commercial and CS5 can manage stitching pretty well. Yes, I know they are old but I am very happy with them and they work fine with my cameras and scanners together.
If you take those images hand held then you will definitely not get the same quality as you would from a single image, no matter what kind of IBIS you are using.
Wrong. There is no loss of sharpness or detail from merging an exposure bracket.
Of course there is loss of detail, that is the case every time you have the slightest movement between one and another image, even if you have the worlds most magical IBIS or use the sturdiest tripod. Try a landscape or a macro image and you will (should) see that even in a seemingly perfect, windless day leaves are moving, air is vibrating, birds or insects turn up from nowhere and so on. You need to be in 100% control of the environment to avoid risks for issues.
Now, imagine having to do that for a few hundred images and you should see the advantages of having a camera with larger sensor and more DR. You can never really get the same kind of image by stacking images compared to a single image. HDR is not the same as sensor DR.
Wrong again. See above.
Yes, see above. Especially where you said it takes 60 seconds per image. Now, 100 times 60 seconds is 6000 seconds and that is about 1 hour and 40 minutes. I call that an awful lot of time compared to no time.
You know, I might have been willing to concede a minor point, but your attitude is so rude and hostile that I won't give you the satisfaction.
My attitude is neither rude nor hostile. On the other hand, you made a pretty blanket statement saying that "DR advantage applies only with moving subjects" which is totally wrong and you should know that. It is very strange that you claim to be a professional photographer with loads of experience, even teaching photography, yet you make this statement.
A single image with more DR is always better than having to take 5 images in a row and stitch those, even if you have the best camera ever produced on this earth. More sensor based DR can NEVER be a disadvantage. That's all I am saying, yet you interpreted that as something rude and hostile.
 olyflyer's gear list:olyflyer's gear list
Nikon Z7
olyflyer
Re: DR & HDR
Exposure bracketing and stitching do not eliminate the advantages of larger sensors.
Amen to that. Quite a different statement compared to "DR advantage applies only with moving subjects."
But they expand my toolbox sufficiently that I can accomplish what I want to just as well with MFT most of the time with minimal effort. YMMV.
Again, that's totally different to what you have said before.
Also remember that nothing prevents a user of a larger sensor camera with more sensor DR to use exposure bracketing and HDR if he/she wishes to do so.
Nikon Z7
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
Re: DR & HDR
No, it's not. You act as if there is no cost associated with your "better" solution. There is no good reason why I should sink thousands of dollars and carry a larger heavier kit when I can achieve results that are just as good with a minimum of effort. You keep saying the same old boring thing - "better is always better" - as if it's some kind of self-evident universal truth. If you can't see the difference, and the "better" solution carries higher costs, it's not better. Say it a million times, you'll never convince me to switch. because I've already weighed the compromises and found MFT the superior solution for me.
Whatever. My point was simply that you often can accomplish the same things with MFT as with larger sensors, and because of this the latter offer no benefit to me with static subjects. I made it clear that I was speaking from my experience, and I illustrated the applicable conditions and methods. My intention was to let folks know that larger sensors are often unnecessary to realize the benefits of greater rez and DR. Your niggling over semantics is boring. You can go back to insisting that larger sensors are always better for everybody. Heard it a million times in this forum. Snore.
The way to make a friend is to act like one.
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
olyflyer
Re: DR & HDR
As I already said, what suits YOUR needs is fine and I am not questioning that.
I NEVER insisted that larger sensors are better for everyone and everyone should have one, please don't twist my words, that is really rude.  I said that more DR is ALWAYS an advantage, which is pretty different from your (mis)interpretation. If you need more DR, want it or can afford it is a totally different subject. For most people a cell phone is more than enough, but even so, there is no question about the fact that if that cell phone could produce the same DR as a larger sensor can it would be even better than those existing today and if your camera could get the same DR as it can get through the 5 frame HDR. it would be even better. Wouldn't it? After all, the target is not exposure bracketing but to take the actual image. Isn't it?
Nikon Z7
Jacques Cornell
Re: DR & HDR
Funny how every time I post about ways that MFT can be used to accomplish professional caliber work, someone here pipes up here to insist that it's "not enough" or "not the best" and "more is better". The negativity is boring. Booooooooring boring boring.
Snore. Zzzzzzzzzzzzzzzzzz.
howardfuhrman Veteran Member • Posts: 4,153
I have a GX8 and Sony RX1 (24mm FF). Bottom line is that the RX1 produces higher IQ images than any M43 camera that I have ever owned. If I had a FF camera with equivalent lenses to what I have with my GX8, they would be far heavier and costlier. The IQ difference between M43 and FF in bright light is not significant providing I am not view the images blown up to be very large. At higher ISO's the IQ difference widens. While I have faster M43 lenses and IS narrow the IQ differences, they do not eliminate them.
I am not surprised the OP found that cameras with FF sensors have greater DR and higher IQ than m43 especially when shooting at ISO's. If one wants superior IQ and they have the budget and willingness to lug a heavier outfit, buy a MF or FF digital camera. If one wants a camera with good to VG IQ, which is relatively light weight, buy a M43 camera Life is full of compromises and cameras are no exception.
olyflyer
Re: DR & HDR
You seem to have some kind of a problem or agenda. I never said it is not enough to accomplish professional calibre work, did I? Again, READ and UNDERSTAND my words, and stop misinterpreting what I am writing. Facts are not negativity. Facts are facts, boring or not. As long as you get paid for what you do, who cares about which camera you use? I don't think your clients ask you "Which camera are you using"? and they definitely don't say "Oh, I see, It's an Olympus, then I don't want to buy your work." They look at the pictures, if good they don't care if you have used a cell phone or a Hassy.
Fact is also that I am seriously considering dumping my nice Nikon FF kit in favour of the Oly MFT system, in spite of the DR disadvantages and smaller sensor. So you can relax. Never the less, fact is fact, having more DR is ALWAYS an advantage, not only with moving subjects. Also a fact that Olympus and every other manufacturer managed to improve and increase the DR in their newer cameras over time, so my hope is that the next gen Oly MFT will be even better. I don't care about HDR, so that feature I can live without.
Nikon Z7
Jan Itor
Jan Itor Forum Member • Posts: 94
MatsP wrote:
My conclusion from your comparison is that the EM-1 is superior from most aspects except for resolution and high ISO performance. That's an amazingly good result, remembering that you compare a 16 MP and a 42 MP camera. The only advantages of the A7II are directly related to the sensor resolution and size and not much else. The negative things you list seems to me being mostly related to only a short experience of the EM-1 which of course is very understandable. It takes some time to learn how to set and use an Olympus camera. What many refer to as a complicated menu reflects that the possibilities to individual settings are enormous and it's easy to get wrong if you don't take your time diving into it. Have fun!
Well the Sony 42 Mpix sensor is the best sensor out there
I which I could have it in my Nikon
As for m43 (and I have six m43 cameras) the sensors are slipping behind
Jacques Cornell
That honor probably belongs to the sensor in the Pentax 645Z.
Actually, MFT has the per-area equivalent of 80MP on a 35mm sensor, so in a sense the larger sensors are just catching up.
OzRay
OzRay Forum Pro • Posts: 19,428
Sensors don't slip behind, just the photographers.
Thoughts, Musings, Ideas and Images from South Gippsland
http://australianimage.com.au/wordpress/
(unknown member) Forum Pro • Posts: 47,805
Just my 2 cents.
Just my two cents.
You are not going to find the EM2 "the perfect" or "almost perfect" camera. The new sensor isn't as good as you are already expecting- it will be a bit better at best than the PenF's/GX8 and that won't come close to the FF performance you are seeing.
The new EM2 will have the hand held super resolution mode apparently, which in some cases will give it quite the capability for high quality but it still won't match DR and ultimate ISO.
In fact, there is, and never pretty much will be a "perfect camera" - it's up to you and your needs and wants.  I love what Fuji is doing. I think they have the best JPEG engine and the image quality is quite superb- but the whole system was a bit bigger than I wanted, so I went m43rds even though I still love Fuji.
Is M43rds perfect? Perfect for who? Is Fuji perfect? For who? Are both perfect? Does that even exist?
It all depends on our priorities. I can tell you I will never touch a full frame A7 Sony as nice as its sensor is because I want to carry small.
Also having had the Sony RX100MKIV for a bit, I can't agree you found the sensor of it performing about the same at high ISO. Though it does perform quite remarkable for what it is.
Which comes to another important point.  In the end, me thinks-i you are interested in photography, you have to put a clear line knowing that buying different cameras, and doing things with them is not photography. That's just gear ownership, gear exploring, gear puzzle solving.
Nothing wrong with that if you have the means financially without skipping on food/retirement and all that (my opinion of course).  But it's so easy to mix both things and they are not the same.
Buy more stuff to play with. To make convenience. To expand capability in a domain. Never buy thinking because "it will make your photographs better."  It won't.
I only say this because in part of what you wrote, though you strike me as quite close to be able to see the difference if you don't already do.
Thanks for sharing your findings. I agree with you Olympus really needs to re-vamp those menus.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
Aberaeron Forum Pro • Posts: 10,184
My thought is that I'm well on the way to winning a small bet I had with myself.
OzRay
I like working with imperfect systems, it makes me work harder to produce imperfect results.
