Olympus Pen F autofocus
Started Jul 27, 2016 | Discussions
zikman Junior Member • Posts: 47
Hi to all!
guys I need your help to investigate a problem that I have with the autofocus of Pen F .
i own this body 4 months now and the problem of autofocus at lower lighting conditions .. I am using the 12-40 f2.8 and the 40-150 f2.8 and it cannot autofocus at incadesense lighting 80% of the times ..in good lighting it can af fast and reliably but not in lower lighting conditions ...I had the e-p5 body the previous year and this thing was autofocusing fast and reliable ...however I have sold it before I acquired the pen f so I could not compare them side by side...However today I came across the e-p5 to a friend and I tested them side by side...and guess what...
the p5 can autofocus Fast while at the same lighting conditions (indoors medium to low light ) the pen F is haunting and struggles...so it was not my imagination..I also tried the lenses today with the gx85 which also auto focuses fast even at lower lighting conditions...
i have contacted Olympus and told me that I could send it to the OLympus service and test it but it will take around 2 months!
can anyone confirm this ...?is it because of a faulty body ? Or a faulty body would always struggle to autofocus which my body definitely does auto focuses in good lighting conditions .. Or is it because of a firmware bug which will be solved in the future with a firmware update from Olympus?
thank you very much for your help!
i really appreciate !
P.S.
Trying with the f1.8 primes the pen F autofocuses faster and more reliable than the zooms f2.8 but again it cannot be compared with e-p5 which is a LOT faster and reliable !
 zikman's gear list:zikman's gear list
Olympus PEN-F Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
Olympus 40-150mm F2.8 Pro Olympus PEN E-P5 Olympus PEN-F Panasonic Lumix DMC-GX85
HaoAndHui Contributing Member • Posts: 539
Re: Olympus Pen F autofocus
zikman wrote:
Hi to all!
P.S.
when you say " it cannot autofocus at incadesense lighting 80% of the times", can you describe what kind of lighting is that, I thought the light ranges for AF is from 0EV for OMD, but -4 EV for Panasonic, and from my experience OMD does struggle to AF in low light.
Blog: huiimy.ninja
Flickr: flickr.com/photos/huiimy
Instagram: instagram.com/huiimy
 HaoAndHui's gear list:HaoAndHui's gear list
Fujifilm X-Pro2 Panasonic Lumix DC-GX9 Panasonic Leica Summilux DG 25mm F1.4 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R +3 more
OP zikman Junior Member • Posts: 47
I mean indoors lighting...Ceiling lamp
the f2.8 and the shutter speed 1/20 at iso of 400 and the metering shows 0.
And it struggles ..
DrWu
DrWu Contributing Member • Posts: 658
I have owned E-P5 like you and now have Pen-F and  Zuiko 12-40 mm as well. My combination focuses absolutely fine indoors in low or dim light. I think you have faulty camera and should send it to Olympus for repair. Pekka
 DrWu's gear list:DrWu's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Olympus E-M1 II OM-1 Voigtlander Nokton 25mm F0.95 +5 more
Ouch..!
It seems strange that it can focus very good at good lighting conditions!
JDLaing
JDLaing Veteran Member • Posts: 6,426
zikman wrote:
Ouch..!
Not at all. Olympus has always been like that. If there is more contrast in the elements of the frame it will focus faster. It takes a little getting used to.
 JDLaing's gear list:JDLaing's gear list
Leica D-Lux (Typ 109) Leica M8.2 Olympus OM-D E-M5 Leica M Typ 240 Sony a7 II +17 more
Otto
Otto Senior Member • Posts: 1,283
This my not help, but at times I notice that I can't get focus in lower light due to the CDAF. If I look for something close by where I'm trying to focus that has a more definite edge to focus on, I can get focus, and just reframe the shot. You might give that a try to see if it might help...
 Otto's gear list:Otto's gear list
Olympus XZ-2 iHS Panasonic LX100 Nikon Coolpix P900 Panasonic Lumix DMC-ZS60 Canon Pixma Pro-100
so ..what to suppose ? is the body faulty or not?
Trying this morning with P5 i could focus fast picking an edge at low light conditions but not with my Pen F!
Beru Roniki - AKA Grzzl
Beru Roniki - AKA Grzzl Regular Member • Posts: 428
It is not as good as focusing my E-M10 (original). In low light it is slightly more hunting, but not that bad as you describe. Most of the time i use single spot focussing an search for an high contrast area.
It helps when you switch off the facial recognition.
From all the things i have lost, i miss my mind the most
http://flickr.com/beruroniki
 Beru Roniki - AKA Grzzl's gear list:Beru Roniki - AKA Grzzl's gear list
Olympus PEN E-PL3 Olympus OM-D E-M10 Sony a7 II Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Helen
Helen Veteran Member • Posts: 7,606
Don't worry that your camera is faulty - this is (unfortunately) normal for the Pen-F, at least at present. The issue doesn't show with a large aperture lens in my tests (i.e. f1.8 17mm) , and never in daylight with any lens, but happens in slightly subdued artificial light, particularly with a relatively slow maximum aperture (I don't have your f2.8 lenses, so I'm referring to slower ones than those) and (apparently) objects at the orange/red end of the spectrum in particular, and it will struggle to lock focus when a 16 MP Olympus won't, with the same lens. I've tested them side by side (and tested another Pen-F to be absolutely sure it's not an isolated issue). I assume there is something about the 20 MP sensor that struggles in these situations, at least using Olympus AF algorithms. I am hopeful they might adjust something in due course via firmware that helps with the issue.
I suppose it may also be related to the C-AF issues that were mentioned in the Camera Store test on YouTube.
Olympus Europe just told  me to send the unit to them in order to test it...
I just again compared to the 16Mp sensor from Pen e-P5 and the GX85 and with the artificial light the difference is TREMENDOUS...!
It just struggles to focus and 70% of the time it fails only in artificial medium to low lighting ...!
I will send them tomorrow morning...
Helen
I'd be surprised if they find anything wrong, but if it makes you feel better about it, then go ahead (I prefer avoiding sending cameras in if I can) - obviously the manufacturer has to offer this rather than to leave you with no offer of customer care.  The two I have checked were exactly like this, and they were built over a month apart (different colours too) so I doubt it was a batch issue.
I don't want to send it too ...since I need it...however a user above said that he has the p5 and the pen f and cannot actually see a difference ..for me the difference is HUGE ..the thing struggles to focus at artificial lighting even pointing a face or a surface ..the motor of the lens is sounding and the subject stays blur after some tries ...if yours pen F has the same behavior at artificial lighting then of course I don't want to send it too..of course outdoors behaves very very fast as the p5 ..
waiting for your response in order to act !
thx !
Helen
thx !
Yes, your description matches mine when they are presented with the "wrong" light and have a lens slower than f1.8 fitted - basically, quite often it hunts a lot and can't settle on a focus point in subdued artificial light - especially if the subject is red, orange or yellow.  As you say, in natural light it seems as fast and decisive as the earlier models.
whumber
whumber Veteran Member • Posts: 4,371
And it struggles ..
I just did a super quick test and mine focuses very confidently with both the 12-40 Pro and 40-150 Pro under incandescent lighting with f/2.8 | 2" | ISO 200 (+1 EV) on a dark target. Your lighting scenario is at +5 EV which the camera should be able to handle very easily. Sounds like something is amiss with the camera.
EDIT: I will add though that while the Pen-F is decent, the E-M1 definitely focuses better in lower lighting conditions.
 whumber's gear list:whumber's gear list
Fujifilm X-T1 Olympus OM-D E-M1X Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
can you try to focus at something red or yellow at artificial lighting at an environment with f2.8 speed 1/20 iso 400 resulting at around 1 -0.7 EV and post the result?
the target is not dark when i am trying to focus...
Its also weird that Helen above sees the same behaviour with mine while you say that everything is perfect...
thx again!
dv312
dv312 Veteran Member • Posts: 9,215
Interesting findings even though I have not experienced it
I no longer have the 12-40mm but I tested with the Leica 15mm at f2.8 ISO 200 at speeds of less than 1/5 s and have had no issues with AF
Of course at f1.7 wide open the AF was slightly more responsive but it by no way struggled at f2.8 (fraction of a second)
If you said the E-P5 focuses faster in the same conditions then I'd like to think it's a body defect
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
of course the p5 focuses MUCH MUCH FASTER!!!
sending it todayo to olympus
LeeS Contributing Member • Posts: 889
You do realize that with the PL 15 mm f/1.7 lens set on f/2.8, the camera autofocuses through the wide open aperture then stops down to f/2.8 at the time of the exposure. There should be no difference in focusing speed regardless of the aperture selected and your test has no bearing on the focusing speed of a lens with a smaller maximum aperture.
If that were not the case we would have no need for a DOF preview button.
Peace
Lee
 LeeS's gear list:LeeS's gear list
Olympus PEN-F OM-1
(unknown member) Forum Pro • Posts: 19,317
And it struggles ..
My em5i sigma 30 set at your settings and low light focuses instantly with no hesitation.
Cheers don
Olympus xz1, e-pL5 , EM5 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9.
