Samsung 50-150
Started Jul 25, 2016 | Discussions
JQuonDo Regular Member • Posts: 214
Samsung 50-150
Hello community,
I've purchased a used 50-150 and it should be arriving in a few days.  I'm looking for 50-150 owners who are very familiar with the lens to give me some tips on testing and what to look for (first time buying used)
From research it looks like I should be checking 2 things with this particular lens (outside of checking the glass)
1.  Zoom ring noise when zooming
2.  Mounting issues when the lens is mounted
Also...
a)  Does anyone know where I can buy the tripod extension for the lens?  Google hasn't been helpful and it doesn't look like samsungparts.com is still carrying it.
b) I've read you can change the focus distance to improve focusing?  How do I go about doing this?
c) There also seems to be a switch (full, custom..) under the AF/MF that I'm unfamiliar with on the lens.
Thanks!
 JQuonDo's gear list:JQuonDo's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Tugela Contributing Member • Posts: 755
Re: Samsung 50-150
JQuonDo wrote:
Hello community,
Also...
Thanks!
The tripod attachment should come with the lens.
 Tugela's gear list:Tugela's gear list
Nikon Coolpix P900 Sony RX100 V Nikon Coolpix P1000 Samsung NX1
OP JQuonDo Regular Member • Posts: 214
Re: Samsung 50-150
He must have lost because he said he doesn't have it.
Re: Samsung 50-150
Oh yeah...last question.  Is the serial number inscribed anywhere on the actual lens?
Kisaha Senior Member • Posts: 2,300
Re: Samsung 50-150
JQuonDo wrote:
Hello community,
Also...
Thanks!
It may be a SamsungParts lens, how much did you pay for it? This is an answer to the people wondering about the NX system, there are incredible offers happening throughout this system, unparallaled to any other.
ttbek Veteran Member • Posts: 4,869
Re: Samsung 50-150
The Australian parts supplier may still have it:
http://www.sparepartsmarket.com.au/Samsung/ad97-24486a-samsung-assy-frame-tripod-mount-collarxl1406-p-61732.html
Pretty pricey at 76 though. I'm not sure if that's USD or Aussie dollars.
Edit: Also, they had this to say about international shipping:
"International Shipping
We do not ship to any locations outside of Australia. However, if you have a very special request, then please contact us and we will see if we can help, however please be aware that international shipping from Australia is very expensive and would probably cost you at least AU$100 just for shipping."
So you may find it useful to use a service like Aramex Shop and Ship, I give this only as an example, they probably don't serve your area, but there is likely a similar company that does.
https://www.shopandship.com/en/home
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Re: Samsung 50-150
Yes, it is on the mount side of the silver ring just by the red dot.
Re: Samsung 50-150
JQuonDo wrote:
Hello community,
Also...
See my other reply.  Really need to search by the parts number to get anything at all and when you do all you get is samsungparts and the Australian site I linked.
You can limit the focus range which ensures it spends no time looking for focus outside of that range.
This is exactly your answer to part b).  "Full" is normal lens operation, if you set the switch to "set" you can set a range of focus on the screen (though I wish it were a bit more fine grained), putting the switch to "custom" makes the lens limit the possible focus distances to the range you set in "set" mode.
Thanks!
Re: Samsung 50-150
Thanks for the info ttbek.
Re: Samsung 50-150
For the 50-150 they also have a diagram for what all the parts are:
http://www.sparepartsmarket.com.au/Samsung/manuals/EX-ZS50150ABEP_0000.pdf
bpjod Contributing Member • Posts: 870
Re: Samsung 50-150
One bit of wisdom I've acquired the hard way. If your camera looks like it should be able to take a photo, but is unresponsive and you cannot figure out what the problem is ... check that this slider is not accidentally knocked to the SET position. Don't ask how I know. Or how many times I've done this before I finally learned to stop panicking and just flip the switch...
 bpjod's gear list:bpjod's gear list
Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-40mm F2.8 Pro +19 more
Re: Samsung 50-150
haha....thank you for the advice.  I will keep that in mind.
