14-42 II R after having the 12-40 2.8?
Started Jul 25, 2016 | Discussions
Alan Smith
Alan Smith Contributing Member • Posts: 797
I have the 12-40 2.8 which I really like on my OMD EM5, but I have to admit it is not a small combo.  (I thought it was tiny when I was moving from my Canon, but that is another story.)
I am considering the 14-42 II R for a walk around.  Any thoughts?  Are there others I should consider?   (I already have the Pany 20mm prime and the Olympus 45mm prime)
(My OMD EM5 came with a 12-50, but I never liked the lens.)
Thanks in advance,
Alan
equipment now in Gear List
 Alan Smith's gear list:Alan Smith's gear list
Panasonic Lumix DMC-FX9 Panasonic Lumix DMC-LX3 Canon EOS D60 Canon EOS 20D Canon EOS 50D +12 more
Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus OM-D E-M5
SpinOne Veteran Member • Posts: 4,059
Re: 14-42 II R after having the 12-40 2.8?
I happen to like that lens. The main disadvantages are that the aperture is not particularly wide, you have to stop down to get similar performance, angle of view is not as wide, and it is not weather-sealed.
None of this should be an issue if you just want a nice light lens for wandering around.
I'm sure someone will suggest the Panasonic 12-32mm, but I for one am not thrilled by that lens. It's got a little too much distortion, and I'm just not thrilled by the way it renders. YMMV.
Glen Barrington
Glen Barrington Forum Pro • Posts: 22,535
I like mine . . .
I think it's a fairly decent lens considering how little it costs. When I'm looking for the max in image quality, I use my 4/3 14-54 DSLR lens or one of my ancient Canon FL series lenses.
But when I'm interested in maintaining an unobtrusive profile or fast operation (or the absolute minimum in size and weight), I don't hesitate to use the OLYMPUS M.14-42mm F3.5-5.6 II R.
Robin Wong wrote an article on how to get the most out of your kit lens HERE.  Now he used the EZ version as an example, but the IIR is at least as good.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
BruceRH Veteran Member • Posts: 3,087
The Panasonic 12-32 f3.5-5.6 is well regarded but I did not like the way it extends, but that's just me. I like the Olympus 14-42 EZ. Get the Olympus LC-37C lens cap which automatically opens and closes with power up of the lens. Another great option is the Olympus 14-150 ii, it is lite weight and excellent quality and is about the same size as the 12-40 Pro but lighter.
 BruceRH's gear list:BruceRH's gear list
Sony RX100 III Ricoh GR III Leica Q2 Olympus TG-6 Olympus PEN-F +44 more
Alex Ethridge
Alex Ethridge Veteran Member • Posts: 5,424
Thanks in advance,
Alan
I have those same lenses among several others and the 14-42 sees little use.  Yes, it's lighter and smaller but sometimes not wide enough.  That's the most-encountered problem.  Then there is the lack of low-light capability which is sometimes a problem.
Add to the above that there is a slight IQ advantage with the 12-40mm and that leaves very little reason for the 14-42.
 Alex Ethridge's gear list:Alex Ethridge's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-G1 Panasonic GH5 Sony a7 III Nikon AF Micro-Nikkor 60mm f/2.8D +10 more
Here is a size comparison between the 14-150 and the 12-40, taken with the 14-42 EZ.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Plus one.
Thanks in advance,
Alan
Exactly the same here.
The range 12mm to 14mm would be sorely missed by me in a lens considered to be the normal zoom. If they would/could make a lesser aperture 12-40mm in the collapsing style or a small fixed size then I would buy that as a little kit lens and push the 14-42mm back further in the drawer of odds and ends.
If I had to buy a smaller aperture 12-?? lens then I would head for the Pana 12-60mm though there's not much saving in size over the 12-40/2.8
For me at least then 12mm is a must for a kit lens. So I stick with the chunky but o-so-nice 12-40/2.8 as my always there kit lens.
Regards....... Guy
cptobvious Contributing Member • Posts: 850
I have the 12-40, 20, and 45 as well, and the 14-42 II R is only $100 or less new right now, but I won't buy it because I know I'll never use it.  When I owned it I was often wishing I had something sharper and faster on my camera. It's a never-ending cycle of indecisiveness between size/weight, speed, and optical quality. Really the two primes should cover most situations when small is desired.
NZ Scott
NZ Scott Veteran Member • Posts: 5,201
12-32 vs 12-42 and 12-35
Thanks in advance,
Alan
I have three "normal" zooms - Olympus's 12-42 IIR and Panasonic's 12-32 and 12-35 f/2.8.
Of those, the 12-32 gets the most use as it's tiny (much smaller even than the 12-42 IIR) and plenty sharp.
The main disadvantage with the 12-32 is that it distorts at 12mm, but this is easily corrected in post.
You also have to "extend" the lens prior to use, but this is also the case with the 12-42 IIR.
The 12-35 f/2.8 is undoubtedly the best of the bunch but, almost as much as your 12-40, is large and heavy enough that I usually prefer to leave it at home.
S
 NZ Scott's gear list:NZ Scott's gear list
Sony RX100 VII Olympus PEN E-P3 Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH +14 more
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Re: 12-32 vs 12-42 and 12-35
Thanks in advance,
Alan
I'm a 12-32 lad also for general around and about, switching to the 12-35 for "serious" stuff (and to look substantial enough to impress clients! :)).
BUT since reading a test of the Panasonic 14-42 II which recorded really stellar performance throughout the zoom range, I have a sneaking feeling I would like to have that lens in hand too. It is small and unlike the Oly counterpart, non-extending.
In reality, this is true GAS. I have always loved a good tool, and the Panny 14-42 II looks like an extra good tool. I do not know how much use I would have for it (when I was working in wood, my collection of chisels was far beyond my needs or skills).
The lens I really would use is the 12-60 -- but I am not seeing the kind of performance I want at 60 in the two reviews I have seen so far.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,949
Only a pancake makes sense after the 12-40 2.8?
Way back when the Panasonic 14-42X pancake lens was the only pancake zoom lens I got that and my E-M5 with 14-42X is always in my carry-everywhere backpack. When I'm expecting to take photos that matter I bring the 12-40, but when I just want the smallest and lightest setup a pancake zoom lens is the way to go. Whether to get the 12-32, the Oly 14-42EZ or the Pana 14-42X is mostly a matter of taste.
I have the "X-Cap" automatic lens cap to turn the combo into a veritable point and shoot.
Enjoying the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus E-M5 II Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
enossified Regular Member • Posts: 440
I never understood the love for the Pana 12-32 (other than size) because 32mm is just too short for me.
The thing I dislike most about the R-II is the max aperture.  I only reach for my primes when shooting in low light where 2-3 stops faster makes or breaks being able to shoot.
It would be nice if it zoomed out to 50mm, but I've learned to live with it. A bonus is that at 42mm it focuses much closer than the 45mm, good enough for some flower shots.
Disclaimer: bundled with the E-M10 body, the R II only cost me $50...well worth it. I wouldn't have paid full price for it.
