Sony A7RII Buffer speed shooting raw, Single shot, once per second.. can't keep up??
Started Jul 25, 2016 | Discussions
Jonneymendoza2 Senior Member • Posts: 1,048
Re: All equipment has limitations ... learn what they are and work-around them.
I did a shoot with a model and at an average took around 1 frame a second or every 1 and half second as the model did various poses on the fly and the a7r2 with the fastest sd card i have could not keep up.
After maybe the 10th frame, i could no longer take anymore shots until some of the buffer was clear..
sportyaccordy Forum Pro • Posts: 18,300
Re: Sony A7RII Buffer speed shooting raw, Single shot, once per second.. can't keep up??
Do you really need 42mp? Sounds like a DSLR would be a better fit. What are you shooting?
 sportyaccordy's gear list:sportyaccordy's gear list
Canon EOS R Canon EF 135mm F2.8 SF Sigma 50mm F1.4 EX DG HSM Sigma 50mm F1.4 DG HSM | A Canon RF 35mm F1.8 IS STM Macro +1 more
Of course for portrait work and landscape!
Why not a 5DS/R? Those are reliably more responsive.
Poor dynamic range for landscape work. I have a 5d3
Memory is cheap and landscapes don't move. Bracket!
Plus from what I hear Magic Lantern helps a good bit with DR.
Uncompressed 42MP may be a bridge too far. Sony needs to match that sensor with a body/processor that can handle it.
l_d_allan
l_d_allan Veteran Member • Posts: 5,093
The ML devs don't have a version for the 5DS[s] ... bummer.
Dual-ISO helps quite a bit with my 6D, but I'd guesstimate that the 6d (and 5d2 and 5d3) are about two generations behind the a7Rii in sensor technology ... circa 2008 tech.
 l_d_allan's gear list:l_d_allan's gear list
Panasonic Lumix DMC-TZ3 Panasonic Lumix DMC-FZ47 Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 600D +27 more
Viramati Senior Member • Posts: 1,373
So I just tested on fw 3.3
compressed RAW 30 shots in 30 seconds and 20 seconds to clear buffer.No lock up
Uncompressed RAW 12 shots in 12 secs then about a shot every 2-3 seconds. about 40 seconds to clear buffer
Uncompressed RAW + low rez jpeg 11 shots in 11 secs then about a shot every 2-3 seconds. about 40 seconds to clear buffer
compressed RAW low speed continuous 25 shots till lock up
compressed RAW high speed 23 until lock up
Question why do you really need to shoot uncompressed? I would only do this in some critical landscape work where I would want to max out the DR but to be honest the benefits are really minor
 Viramati's gear list:Viramati's gear list
Sony RX100 III Sony RX100 VII Fujifilm X100V Sony a9 Sony a7R III +10 more
