Maximum 1600 ISO in iAuto mode?
Started Jul 22, 2016 | Questions
mg36 New Member • Posts: 5
Generally, I am very happy with this camera, but I have bumped into a very annoying limitation. In iAuto mode the maximal ISO is 1600. In P/A/S/M mode it can easily go higher, because I have set under the option "ISO Auto Set" the "High Limit" to 6400. Is there any way to solve this in iAuto, too?
 mg36's gear list:mg36's gear list
Olympus PEN E-PL6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
Re: Maximum 1600 ISO in iAuto mode?
I would not use iauto mode or equiv , however nor would I dream of shooting m43 over 1600ISO
The rose of all the world is not for me. I want for my part
Only the little white rose of Scotland
That smells sharp and sweet—and breaks the heart.
:Hugh MacDiarmid
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
apathyman Veteran Member • Posts: 4,151
I'm pretty sure that ISO 1600 max is a built-in limitation of iAuto mode.  It certainly seems that way on my E-M10.
If you want to hand over control of exposure to the camera and use a higher ISO, you'll need to use P mode.
Cheers
Brian
alcelc
alcelc Forum Pro • Posts: 19,003
If you use Pany camera, iAuto could be selected by the camera to a upper limited of ISO3200 (flash=ISO1600). It is the same for GF7, GX7, GX85, GX8 etc.
Albert
OP mg36 New Member • Posts: 5
Thank you for your replies. Otherwise, I usually use P mode, but when I take photos in the garden, family etc... (not serious subjects) iAuto is helpful that I don't even have to set the ISO.
By the way the camera is an Olympus E-PL6...
