NX300 Black Screen Issue
Started Jul 22, 2016 | Questions
cg9916 New Member • Posts: 1
A curiosity if anyone has dealt with this – I’ve been lurking a long time but finally found an issue that hadn’t been covered here (successfully). And perhaps my band-aid can be helpful.
The camera came on with a black screen in capture but the menu overlays showed and playback was functional, and so I went through everything to get it working – swapped lenses, batteries, reset, re-installed firmware. Shutter didn’t appear to be down. Nothing. Then I read elsewhere that someone dropped it while working on it and the image returned. So I gave it a moderate slap on the side – worked. The image came back. This has happened three times in maybe a few months now – and the camera has been almost wholly unused in that time. Each time, the slap worked. I know slapping high-end electronics isn’t an ideal fix, but it has worked and spits out perfect images.
My question is basically, is this a failing sensor? Or could it be a loose internal piece? It strikes me as more mechanical, but I’m very far from an expert and I’m not sure if this is how a sensor would begin to fail, or if there's more going on with the shutter than I'm noticing. I’m not adverse to opening it up to take a peek.
I know a sensor is a costly fix, if it can even be done anymore, but I was going to be in the market for an upgrade anyway, and was likely moving on from Samsung, but I was really hoping to wait awhile. I'm perfectly happy with it for now otherwise since I tend to prefer film.
Samsung NX300
ttbek Veteran Member • Posts: 4,869
Re: NX300 Black Screen Issue
This seems most likely, but, I have those exact symptoms minus the tap on the side fixing it and it occurs exactly and only when the 50-150 S lens is mounted.  When that lens is placed on the camera each time the screen goes black exactly like that.  The other S lens works no problem.  My NX300 is not on the newest firmware though, it's on the one just before that, so perhaps support for the 50-150 wasn't added yet.  Even though we have similar symptoms we have different triggering conditions and treatments, yours being much more chaotic while mine is completely predictable.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
