So this is another review by me. As some of you who already read my earlier reviews, I am not a professional photographer, so please treat this review accordingly.
Anyway, I got this lens when I started shooting Micro Four Thirds in 2014. This was not my first lens, but it was on my wish list for quite some time. The only factor that caused me not to purchase this lens is the high price, especially here where I live.
Before I bought this lens, I use the 14-140mm bolted on my GX7 most of the time, and use it for anything. It was a very solid lens, but as you know, f/5.6 isn't really that flexible in low light. I tried going to prime lens route, but it's not really convenient because I have to change multiple lenses of different focal lengths a lot (17 to 45, back and forth). And 17 is not wide enough for indoor event shooting.
Therefore, I took the plunge and bought this lens at the end of 2014. And this lens probably is my most used lens ever since. It's now bolted on to my GX8 full time, and I use my GX7 for other lenses like 35-100 f/4-5.6, 75 f/1.8, 7-14 f/4.0, or 9-18 f/4-5.6.
Let's talk about some things that I love about this lens:
It's sharp enough for my needs. It has f/2.8 which is more than enough for my needs, even for low light. It also has Power OIS, which helps me to get sharp handheld shots at low shutter speed, especially with Dual IS on the GX8.
It's weather sealed, so it can take a bit of splash together with the weather sealed GX8. And it actually survived a 15 minute heavy rain last year without any protection with the GX8! To be fair, I guess I must be lucky enough that time that nothing got damaged, so don't try to test the weather sealing ability of this lens on purpose.
The focal length is very useful to capture most of my photographic needs. About 75% of my photos are taken with this focal length. It's my number one lens that I always reach when I'm about to photograph in general.
The size of the lens is similar with my 14-140mm, and it shares the same filter diameter, which is awesome!
AF is instantaneous. It's one of the fastest AF lens on MFT! And bonus point for somewhat close minimum focusing distance. That means that this lens can help with quick emergency macro shots.
The Power OIS is quite good too. Without Dual IS on the GX8 or the GX80/85/7mkII, it can comfortably deliver sharp handheld shot at 1/20s at 35mm. Using the IS for video helps to reduce motion shakes without too many little quick jerks. I don't find any problem with the IS.
What I don't like from this lens?
The lens hood! It comes off way too easily. Already a few times I saw a very strong vignette at 12mm, only to find out that the hood wasn't properly locked on to the lens and caused the vignette.
Sharpness of the lens is very good and more than enough for what I do, but when I tried to compare the lens with the 14-140mm that I have, it doesn't show significant sharpness improvement. I guess I underestimated the 14-140mm more than I should.
How do I use this lens?
This is my always-carry lens when I'm traveling. Also this is my main event photography lens. I've also done street photography with this lens so many times, and it definitely can do it with no problem.
This could be the only lens you need when you travel. I know, 35 isn't tele enough, but if you don't plan to capture wild-life, it is more than long enough to capture some interesting distance objects during travel.
The 12mm is enough for cityscape, non-serious landscape, wide-street photography, wide environmental portrait, and so many other things. Zoom to between 17 and 25mm, and this lens will give you a good focal length for street photography, half body portrait, food photography, and tighter landscape. Zoom in to 35mm for emergency portrait, emergency macro, or emergency bokeh portrait.
Some of my best photographs came from this lens. I really recommend this lens if you need the f/2.8 aperture for low light. If you don't need large aperture, definitely check out the 14-140mm because that lens will provide you with a more generous focal length options, at the cost of smaller aperture.
I really like it! Really, almost no flaw with this lens. The 12-40mm from Oly is said to be sharper and has better built, but I have no desire to switch to the Oly lens, since I am shooting with Pan body and I need IS on lens. So, it's a 5 star lens on my book.
Hope my review helps!
Landscape
Macro/Bokeh
Product Photography
Portrait-ish
Cityscape
Environmental Portrait
Street Photography
Another Environmental Portrait
