Samsung EX2F vs Samsung NX mini + 9mm
Started Jul 12, 2016 | Discussions
jacketpotato Senior Member • Posts: 2,244
Re: I've been considering this also...
norman shearer wrote:
I was lucky to get mine from CEX - they seem to amass a lot of photography gear and regularly undercut Ebay. The particular model I got was graded 'B'. I expected 'B' to mean some marks/scuffs to body and maybe screen but it's immaculate. It's the white model I got and I now think it was graded 'B' because it wasn't a complete kit in original box.
Norman I think you got the one I returned to Cex just about two weeks ago (14day return online purchases). This was the only NxMini grade B on CeX. Two 2 years warranty from Cex.
https://www.dpreview.com/forums/thread/4023528
Ex1 I had iso100 F1.8 lower light required iso400 F4 Apsc. Thus Ex2 F1.4 should do even better with regard to higher shutter lower iso in lower light. However I'm unaware of F values as the lens zooms, sensor on Ex1 was noisy at iso400.
Thus
NXMini+ 9mm (24mm) F3.5 street, faster subjects, landscape
Ex2f 24-80mm F1.4-F2.8 low light, still life, architecture, potrature, macro.
Alternatively NXMini 9-27mm F3.5-5.6 (24-70mm equivalent) £120 new, whilst selling pancake 9mm would fetch £120.
OP norman shearer Senior Member • Posts: 1,418
It could be. I'm certainly more than pleased with its condition.
Thus
Just got my half case and strap today so will be taking the mini for a test soon. Looks easy to set up for street and zone focus. Lack of external controls is not as bad as it first appears because the GUI is good and the touchscreen makes accessing settings a breeze. Shutter button position and feel is good for shooting from the chest. My NX500 shutter button is a bit of a stretch for my thumb and it's a little less discrete as a result.
I have a few weeks to test the mini out then I'm loaning the camera to a friend who is off on holiday to Portugal for a few weeks.  The mini looks to be the easiest camera for a beginner that I have and the flip up selfie screen is quite good fun.
The EX2F is continuing to impress me. I took it on a shoot to Leicester City along with the NX500 which I paired with my 20mm pancake for a change. Despite the huge difference in sensors the EX2F still acquits itself rather well. You have to take more care with exposure but other than that it is so simple to use and the huge DOF it gives means you can opt for shutter priority and let the camera choose the aperture. I'll stick to this mode for a while and get a feel for what apertures work best.
 norman shearer's gear list:norman shearer's gear list
Samsung EX2F Nikon Coolpix A Sony RX1R Canon EOS 5D Canon EOS 5D Mark II +10 more
Heck of a cute camera NxMini. Doddle to use. Shame Samsung camera division buckled. A 30-100mm + existing 9-27mm would covered ground for me.
Ex1 easy to blow highlights. Still took neat captures. Possibly my favourite night camera.
Autumn winter nights soon upon us I may well look into Ex2f. What are the F numbers 35mm, 50mm, 70mm Ex2f.
When you zoom in the display gives you a multiplication factor rather than mm but you can work it out.
x1.2 = F2
x2= F2.2
x3.3 = F2.7
Ex2f Re: I've been considering this also...
x1.2 = F2
x2= F2.2
x3.3 = F2.7
Last night out with Apsc and 50mm F1.8 i realised usefulness 24mm F1.4.
£700 apsc 16mm (24m equivalent) F1.4 large. Therefore this morning purchased Ex2f from online CeX.
Re: Samsung EX2F vs Samsung NX mini + 9mm
Well I've finally got my half case for the NX mini and taken it out for a few sessions. Both were quite brief but they highlighted some problems.
I was not so impressed by the shutter feel when the camera is mounted in a half case and being pressed by my thumb. It was just a bit too sensitive for my thumb and I found myself regularly groping for the button and half pressing it just so I knew my thumb was in the right place. I suppose that is the downside to a flush shutter button. I can remedy that by sticking a bit of rubber on top.
Worried about the settings being changed accidentally, I turned off the touch screen only to then realize doing so removes the function menu thus I had no way of quickly adjusting exposure compensation. I need quick access to exposure comp so I'll have to leave the touch screen on and hope my chest does not change any settings inadvertently!
Biggest con however is the 9mm pancake lens. It performs quite horrendously when shooting into the sun. I know that is a challenge for all lenses but if you are gonna produce a pancake lens that cannot take filters or hoods you'd better give it some nice coatings to reduce lens flare. Sadly this is not the case with this pancake.
The above image is untouched other than reducing the highlights a bit to stop them blowing out. As well as that halo/softening effect caused by flare the colors go way out and contrast is reduced giving a washed out look. In camera RAW the histogram clearly shows a lack of black. Correcting this in post was challenging..
The lens is a good performer with the sun behind or to the side.
All shots taken at F5 so stopping down does little to help the flare issue.
The Samsung EX2F on the other hand. In similar conditions it struggled also but flare was much better controlled and contrast and blacks were showing up much stronger on opening the files in camera raw. Colors tended to over-saturate and look a bit unreal but you could get usable images from the files albeit you might have to stick to b&w to do so. I've only really used the zoom lens at 24mm so cannot comment on its performance at other focal ranges.
So for my purposes the EX2F is staying and I'll eventually sell on the NX mini. Maybe the 17mm lens has no issues with flare but that is not a focal length that suits my style unfortunately. I doubt the 9-27mm zoom is any better? I'm not prepared to fork out the moolah to find out!
Not knocking the NX mini. It was never designed as a street camera so it's hardly surprising it didn't work for me. I'm sure it'll be a fine street camera for some though. I should also add that in the right conditions the 9mm lens can produce some remarkably detailed images. The sensor is great and could no doubt challenge many m43 cameras. Touchscreen and GUI are both good.
From my first shoot with the NX mini
However, for me, the EX2F is king. It's the best small sensor camera I've had to date and I've been through a few - LX5, GRD 3, GRD 4, Nikon J1 etc. I'm curious about the Nikon J5 and may get one in the future if the price is right. Otherwise it's a wait for the Nikon DL series to arrive. In the meantime I'll enjoy the EX2F. I'll end with some images from that camera.
