Soft image from 70-200 f4 IS
Started Jul 10, 2016 | Discussions
Marc dbr
Marc dbr Regular Member • Posts: 365
Hey everyone in the forum,
I'm currently in holland where beautiful fields of flowers are a joy to photograph.
I took this picture with a 450D + 70-200 f4 IS L lens , I shot RAW, (then exported them unedited from LR), and focussed with the center AF point, at f8, where the lens should be the sharpest.
The picture isn't really sharp even in the middle where I focussed. Can't micro adjust any lenses on the 450D, but I don't think that is the problem. I'm planning to upgrade to a 6D this summer so I hope the lens is fine. Is this the best image quality I can expect with this setup? Will a Full Frame upgrade provide me better IQ for landscape photography?
Thank you for your help,
Marc
Here another example
 Marc dbr's gear list:Marc dbr's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EOS R5 Canon EF 135mm F2L USM Canon EF 16-35mm F4L IS USM +6 more
Canon EF 70-200mm F4L IS USM Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2)
stratobill Senior Member • Posts: 2,081
Re: Soft image from 70-200 f4 IS
With that lens I don't think you should expect enough depth of field to get all of that pic in focus.
Having said that, I would expect the center to be really sharp, sharper than what I see there.
Best to do a test on a tripod, IS on and off, etc to really tell.
For instance, this was taken with the 70-200 F4L IS and the XSI:
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
hotdog321
hotdog321 Forum Pro • Posts: 21,141
Hmm, that really isn't very sharp. I was all prepared to blame it on camera handing or aerial haze or shooting against that terrible white sky (which may be making the problem worse), but it quite possibly is a lens problem.
I would retest on a tripod, wide open at f/4 under nice contrasty light. I'd try shooting using the autofocus, then try a manual focus shot. If it still looks soft, it might be time to send it into the shop.
Also, testing it on another camera body would be ideal, but might not be possible.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +3 more
Mike Contributing Member • Posts: 783
A couple of things -
1. Be prepared to shoot using the aperture in the F-8 or so range.  This is just a matter of fact with most zoom lenses.  Leave the shutter speed and ISO set to automatic.  Try it it works..!
2. I own three "L" lenses.  They are ALL soft when mounted to an APS-C (small sensor) camera.  BUT...they all three work VERY nicely, sharpness wise, when mounted to my full frame (larger sensor) 6D.  Like two different lenses.  I bought a 28-300L lens and was very disappointed with the lens as mounted to my...SL1, my 40D and my 50D bodies.  But when I bought the 6D...it and my other two "L" lenses magically got remarkably sharp.  Still not "prime" lens sharp, but MUCH better than when mounted to the small sensor cameras.
Mike
Steve Balcombe Forum Pro • Posts: 15,582
No, the 70-200/4L IS is sharp at f/4. We're not talking about a consumer grade zoom here.
Auto ISO is also a bad suggestion for testing, because the additional noise of a higher ISO speed takes the edge off sharpness and also reduces contrast which has an effect on subjective sharpness. Set a low ISO speed and test in good light so the shutter speed will be high enough. Ideally use a tripod unless you are very confident that there is no camera shake, and choose a static subject, not one which is fluttering in the wind for example.
I have several Ls (including as it happens the 70-200/4L IS, but also other primes and zooms), used exclusively on crop cameras and they are perfectly sharp.
RS_RS Senior Member • Posts: 1,788
This is in principle an outstandingly sharp lens under almost all circumstances, although it is a bit weak at 200mm MFD. All the reviews that I have seen agree on this, and it has certainly been my own experience with my copy. However, my son bought one s/h that was disappointing, but Canon at Elstree (UK) sorted it out and it is now fine – we think there may have been an internal misalignment.
So, the fist thing to do is to test your lens properly – apart from anything else, DoF issues make it hard to draw any conclusions from the images you have posted. Use Live View to obtain accurate focus on a detailed flat subject perpendicular to the lens axis, like a building with plenty of fine architectural features. That will tell you whether the problem is with your lens. If it is, send it to Canon in the hope that they can sort it out.
AJB123 Junior Member • Posts: 47
This thread is the only issue I've heard of with that lens.
For what it's worth I've got the same lens and a 450D, and it is sharp even at f4.  So either there's something you were doing (eg handheld with IS off), or there's maybe something up with your lens.
As others have said, perhaps try some more scientific test shots.
Mike - Senior Member • Posts: 1,068
Steve B., my answer stands.
Sorry, my answer stands..!
This is from real world use of various cameras and lenses.  NOT JUST....TESTING.  Actually taking photos...then...checking what you have.  Again, not just taking pictures of a piece of news print on a wall...I'm talking "real" photos..!
An "L" lens on an APS-C body WILL NOT...provide the best that it can on a full frame body...period.  Same goes for Nikons I've got.
When using APS-C cameras, stick with the non-L lenses, you get sharper pictures...if that's what you are looking for.  Many like the softer image...and that's fine, I don't.
Mike
 Mike -'s gear list:Mike -'s gear list
Sony a6300
RedFox88 Forum Pro • Posts: 30,738
Its not the senor size that affects the sharpness but the size of the pixels. For instance the 5Ds has very small pixels too.
Mike
Re: Steve B., my answer stands.
As was my comment about the 70-200 f4 IS being sharp on my 450D. I've never "tested" it; I just use it and love using it.
It won't provide the best that that lens can; the same lens on a full frame body would be sharper. But I don't have a full frame body...
But, I'm not aware of an EF-S zoom with a similar range that's as sharp, let alone any sharper. And even if there is, I love the build and feel of my 70-200 and it's plenty sharp enough for me.
So what lens should I be using in your opinion?
John Sheehy Forum Pro • Posts: 26,698
Mike wrote:
  1. I own three "L" lenses. They are ALL soft when mounted to an APS-C (small sensor) camera. BUT...they all three work VERY nicely, sharpness wise, when mounted to my full frame (larger sensor) 6D.
It is a given that the maximum 100% view pixel sharpness with the same lens and f-number will be higher with bigger pixels with the same relative AA filter strength. All lenses are very, very soft with small enough pixels, as it should be.
In this case, however, the OP's camera has a pixel size that is very close to that of the 6D. I have an APS-C camera that has pixels much larger than those in the 6D.
Dave
Dave Veteran Member • Posts: 6,231
So what are recommended non-L substitutes for various popular "L" lenses such as 100-400mm, 35mm f/1.4, and 100 IS macro?
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
Schnapper Contributing Member • Posts: 995
Mike
Uh, I believe that this statement is incorrect.  You might get "more sharpness per dollar spent", but typically the L lenses are more sharp than non-L lenses (not in all cases, but typically).
Marc dbr
OP Marc dbr Regular Member • Posts: 365
I can also test sharpness on a full frame 5DIII and see if it provides enough sharpness...
You can but the 70-200 F4IS should be really sharp on crop as well. Speaking from experience!
