Olympus 14-150mm almost doubles in length at full zoom: any problems?
Started Jul 8, 2016 | Discussions
Dostoy Contributing Member • Posts: 556
Based on a number of factors (including DPReview recommendations), I recently got an Olympus M.Zuiko 14-150mm F4-5.6 II lens. For those who haven't seen this lens extended, it is a true "trombone" of a lens! Not counting the mount, the un-extended lens is about 83mm long. But at maximum zoom, the lens extends a further 60mm, almost doubling its length to over 140mm.
My concern is not with the length per se, but with the sturdiness of the lens. It almost looks like the lens is "planking"! One would think that such a long extension would make the lens weaker. So my question is simple: is this lens a "tough trombone"?
I'd be interested to hear if any owners/users of this lens have had any problems due to its exaggerated extension, such as excessive lens wobble developing, or even some kind of breakage. Likewise, were there any problems with lens sturdiness in Mk I that have now been resolved in Mk II? Or, to take the "planking" analogy a bit further, does this lens just have good core strength, due to the lens equivalent of "solid abs"?
(Interestingly, the Panasonic 14-140mm F3.5-5.6 II is more compact, and extends considerably less, despite having almost as much reach as the Olympus.)
Dostoy, from Oz
(Oz = Australia)
 Dostoy's gear list:Dostoy's gear list
Olympus E-M1 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +3 more
Olympus 14-150 F4-5.6 II
Peter Del Veteran Member • Posts: 7,988
I use one all the time without any problems
 Peter Del's gear list:Peter Del's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +5 more
Digital Dick Senior Member • Posts: 2,379
Re: Olympus 14-150mm almost doubles in length at full zoom: any problems?
Been using mine every day for five years with no problems.
My old Konica Minolta A200 has a floppy zoom lens. It wiggles several degrees and droops when fully extended. It's a great lens and still takes excellent images.
Dick
 Digital Dick's gear list:Digital Dick's gear list
Olympus OM-D E-M5 Olympus E-M5 II
stateit
stateit Senior Member • Posts: 1,741
Dick
So: Is that a good endorsement or a bad one?
mikereport Regular Member • Posts: 145
The 14-150mm is my secret weapon: I have it glued to my EM-10. No drooping or wobbling!
Two 2015 Sierra hike photos: http://mikereport.blogspot.com/2015/09/dayhike-to-shadow-lake-2.html
Mike Mundy
Obviously a good endorsement. It's the image quality that counts not how or what you used to get it.
Dick
atomgr Forum Member • Posts: 90
I've used it in extreme conditions.
Cold, hot, sandstorm, rain. Down to tunnels, up to cranes, not a glitch.
Glass is clean,  nothing inside, zoom works as new.
I Don't know if my 24-70 can take that much.
 atomgr's gear list:atomgr's gear list
Canon EOS 5D Mark III Olympus E-PL7 Panasonic Lumix DMC-GF7 Olympus E-M5 II Canon EF 70-200mm F2.8L IS II USM +9 more
OP Dostoy Contributing Member • Posts: 556
Thanks for the info! You have certainly experienced the "highs and lows" of photography!  I now have full confidence in my 14-150mm!
Dostoy, from Oz
(Oz = Australia)
