Saturn--FZ70
Started Jul 7, 2016 | Discussions
Dan W Veteran Member • Posts: 3,426
Saturn--FZ70
I pointed the FZ70 at Saturn tonight and this is what I got. This was a RAW image, imported into Photos on my Mac, then PS13. I did not use a tripod so the IS was very effective.
Dan
 Dan W's gear list:Dan W's gear list
Canon PowerShot D10 Panasonic Lumix DMC-LF1 Panasonic Lumix DMC-FZ70 Panasonic Lumix DMC-FZ300 Nikon D7000 +2 more
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 22,120
Re: Saturn--FZ70
Impressive.
Rings and all.
When I saw "Saturn" in your title, I assumed that the image would have been taken, by the FZ70, through a telescope. Not so - really good and such amazing OIS!!!
"Measure wealth not by things you have but by things for which you would not take money"
www.flickr.com/ohlsonmh/ ohlsonmh@yahoo.com
Jack Brandt217
Jack Brandt217 Forum Pro • Posts: 12,826
Re: Saturn--FZ70
Wow Dan, that's an amazing shot considering it is handheld and without a telescope.
Jack
MarioV Veteran Member • Posts: 6,785
Re: Saturn--FZ70
a good start, Dan.  Try using Spot or Centre weighted metering so you're not exposing for the whole sky.  Dont be afraid to use jpg instead and some digital zoom on planets.
 MarioV's gear list:MarioV's gear list
Nikon Coolpix P900 Canon G3 X Panasonic ZS100 Nikon D5200 Canon EOS M100 +1 more
OP Dan W Veteran Member • Posts: 3,426
Saturn
Thanks everyone, for your comments.
Mario, I've experimented with different exposures, amount and types of zoom etc. This is the best I've gotten, so far. But I'm sure there's room for improvement.
Dan
Jon_T
Jon_T Veteran Member • Posts: 5,111
Re: Saturn
Dan W wrote:
...I've experimented with different exposures, amount and types of zoom etc. This is the best I've gotten, so far. But I'm sure there's room for improvement.
Very good results considering the handheld 1/30th at 35mm equiv. 1260mm; even with the IS you held the camera very steady to get shot.
Probably the item that would help the most is to use a tripod to be able use the FZ70's base ISO setting (hence slower shutter speed) to keep image noise to lowest level possible.
Jon
 Jon_T's gear list:Jon_T's gear list
Panasonic FZ1000 Panasonic ZS100 Panasonic Lumix DMC-FZ200 Canon PowerShot SX50 HS Canon PowerShot S110 +15 more
Re: Saturn
Thanks, Jon.
Dan
Re: Saturn
Jon
Completely agree.  I use a cheap Slik F740 tripod which does the trick.
salbano
salbano Contributing Member • Posts: 615
Re: Saturn--FZ70
A surprisingly good result, I'm impressed, especially considering how you achieved this shot!
Yes, you can put your camera on a tripod, and lower the ISO which will result in a slower shutter speed.  If planets are anything like stars you'll need to be careful about too long of a shutter speed because of the earth's rotation.  Stars go from points of light to oblong blobs, the same may happen to planets.
I'm going to need to try this with my RX100 and 8" telescope!
 salbano's gear list:salbano's gear list
Panasonic FZ1000 Panasonic Lumix DMC-FZ300 Nikon D7200 Nikon 10-20mm F4.5-5.6 VR Nikon AP-F 70-300mm F4.5-5.6E
Re: Saturn--FZ70
Thanks. Yes, I've experienced those oblong blobs with long shutter speeds!
Dan
Re: Saturn--FZ70
Faint stars and nebula are the reason for long exposures which cause trails without a tracking mount. The brighter planets dont warrant such exposures so trails arent an issue. Stacking is a better way to improve signal/noise without overexposure.
Great idea! I completely forgot to try my TZ100 with my 8" scope..and its winter now.
In the mean time, here is a single shot of Saturn with my P900. 1.4x digital zoom and cropped. At 8 o'clock, you can see Saturn's shadow cast on the ring behind it.
old jim
old jim Veteran Member • Posts: 4,907
Re: Saturn--FZ70
Great capture Dan!! Congratulations:-).
Warmest regards,
DP Review - Where else?
Old Jim
 old jim's gear list:old jim's gear list
Panasonic Lumix DMC-FZ300 Panasonic LX100 Panasonic Lumix DMC-GH2
Re: Saturn--FZ70
That's very nice. I tried again last night, using a tripod and various settings. I wasn't happy with my digital zoom results but here's a jpeg without digital zoom that was better than my RAW photo from the night before.
Dan
Re: Saturn--FZ70
Thanks, Jim!
Dan
edhume
edhume Contributing Member • Posts: 816
Re: Saturn--FZ70
And it stands up to pixel-peeping. The surrounding stars come out when you look at the original in the original size. Nice steady hands.
 edhume's gear list:edhume's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-LF1 Silkypix Developer Studio Pro Corel Aftershot Pro +8 more
Re: Saturn--FZ70
Thank you, Ed.
Dan
Akkerman54
Akkerman54 Regular Member • Posts: 116
Re: Saturn--FZ70
Dan
Hi Dan,
impressive shot.
If you have a teleconverter, try to take some shots with the FZ70 + TC and then stack the images using a stacking software like registax6.
Back in May 2015 I took some saturn-shots with my FZ200 and 3 (!) TCs on it. After registax6 and PSE-adjustments , this turned out:
Kind regards,
Akkerman54
 Akkerman54's gear list:Akkerman54's gear list
Panasonic Lumix DMC-FZ200 Panasonic FZ1000
Re: Saturn--FZ70
That's a great shot. I don't have a TC but I'll look for one now.
Thanks.
Dan
wboeck New Member • Posts: 2
Re: Saturn--FZ70
Dan
Dan,
What settings and mode did you use for this? Did you use manual focus?
Wayne
Re: Saturn--FZ70
Hi Wayne,
I did this a year ago so I don't recall the settings. I may have used manual focus and pushed the focus button to achieve a focus. That can work well.
I was probably in manual mode so I could get the shutter speed that I wanted although shutter priority would have done the same thing.
Dan
