EF-M 22mm vs 11-22mm blind test
Started Jul 5, 2016 | Polls
OzarkAggie Senior Member • Posts: 2,153
Re: More Fodder
Persizi wrote:
Dareshooter wrote:
Persizi wrote:
I've tested 3 copies of EF-M 11-22mm and all of them was 99% the same quality.
Why did you need to test three ?
Because I thought that might be a difference in the copies and I wanted the best.
So what vendor gives you 3 lenses so you can pick the best one for yourself and then puts the 2 you rejected back on the shelf for the next customer?
Who does that? Because I want to make sure that I never buy anything from them.
So where did you get the lenses?
 OzarkAggie's gear list:OzarkAggie's gear list
Canon PowerShot A590 IS Canon PowerShot G1 Canon PowerShot Pro1 Canon EOS 10D Canon EOS M +11 more
Persizi
Persizi Regular Member • Posts: 100
Re: More Fodder
Who said that the "rejected" lenses are back on the shelf.
In UK every big re seller accept the product back in a reasonable time if you are not happy. I believe in US and any other civilised country is the same, so you can try to avoid all of them
 Persizi's gear list:Persizi's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 32mm F1.4
Dareshooter Veteran Member • Posts: 5,842
Re: More Fodder
Wow,you kept all three ?
Persizi
Re: More Fodder
No. I sold 2 of them.
Re: More Fodder
Hope you didn't make a loss.
Persizi
Re: More Fodder
Guys, cut the crap, please. My point is that in my experience variations of 11-22mm is practically no existing and yet my copy of EF-M 22mm F2 is touch better than 11-22mm in most of the cases. May be there is variation of the 22mm F2, but the only copy that I have is good.
And yes, I did make loss.
Re: More Fodder
Take it easy Persizi.I don't know why you're reacting to me like that as I've not been critical of you in any shape or form.
Papa48
Papa48 Senior Member • Posts: 4,839
Re: More Fodder
highlyunfocused wrote:
nnowak wrote:
I just shot a couple more quick photos for further comparison. All image were run through DPP 4 with the only adjustment being DLO. No exposure, contrast or sharpening changes were made. Images were exported as quality 10 jpegs
11-22mm f8 with DLO
22mm f8 with DLO
22mm f4 with DLO
All are fairly close in the center, but if you compare the peripheries of the frame, the 11-22mm starts to clearly fall behind.
My 22mm at f2 can get pretty vignetted. At least, when I apply DLO in DPP, the Peripheral Illumination setting blasts away tons of shadows. I actually like the vignetting and disable the Peripheral Illumination. I suppose it's better to have no vignetting OOC and to let the user decide on how much vignetting is desirable rather than having an obligatory vignette. My 50mm f1.8 doesn't seem to have as much vignetting...not sure why.
Wide angle lenses are more prone to vignetting by optical design.
 Papa48's gear list:Papa48's gear list
Sony Cyber-shot DSC-RX10
Re: More Fodder
My fault for asking the obvious question.
Answer 1: UK vendors allow returns.
Answer 2: I sold the other lenses at a loss.
Personally I just drop by The-Digital-Picture.com, Chris Frost's channel, maybe some others, and then check out Canon Refurbished. My thinking is that the refurbs didn't make it through QA the first time so it had to be certified by a tech.
But then it's not my job to test lenses.
Papa48
Re: More Fodder
So does that mean refurbished lenses or any equipment for that matter are likely better, or worse than the average sample? I’ve seen arguments for both, but am still undecided whether to consider refurbs with future purchases.
Microprism Contributing Member • Posts: 865
Re: More Fodder
Is equipment off the Canon assembly line individually qc'd or spot checked? Refurbs need to be individually checked to see if they are up to spec, right?
 Microprism's gear list:Microprism's gear list
Canon EOS 5D Canon EOS 7D Canon EOS M6 Canon EOS M6 II Canon EF 50mm F1.4 USM +22 more
Papa48
Re: More Fodder
True, though a piece may be a refurb because someone previously returned it for its sub-par performance. Does a manufacturer correct all deficiencies before returning products as refurbished? That would be admirable, but also cut into profits.
Re: More Fodder
In manufacturing QA pulls samples to test tolerances and/or function. They also use machines. But a refurb is tested individually. Doesn't mean they are better. But they won't be worse. Very often the issue is cosmetic.
I'm not an early adopter either.
Larawanista
Larawanista Veteran Member • Posts: 4,736
Re: A = 11-22mm B = 22mm
nnowak wrote:
Center sharpness is pretty close between the two, but the perimeter looks much better on the EF-M 22mm. It is especially obvious in the yellow wildflowers on the left edge of the frame.
Not sure if it matters, but both of my lenses were purchased almost immediately after initial release. My 22mm is almost 4 years old and has dents and scratches from lots of use and abuse. My 11-22mm is in almost pristine condition.
FYI for those new to shooting landscapes.... pretty much everything in these photos is in focus even though it was shot at f5.6. When shooting with a crop sensor, you don't need to stop down to f11 or f13 to get good depth of field. If you do stop down that much, you will actually make your entire image softer.
Stepping down an f2.0 lens is expected to deliver better results, IMO. Hence whenever I have a choice between using a 24 f2.8 and a 24 f4 I choose the former.
"Photography is therapeutic."
http://www.pbase.com/joshcruzphotos
 Larawanista's gear list:Larawanista's gear list
Canon EOS M3 Canon EOS R Canon EOS RP Canon EOS R6 Canon EF 100-400mm f/4.5-5.6L IS USM +10 more
