35mm 1.4 vs 35mm 2.0 parallax correction when using OVF
Started Jul 5, 2016 | Discussions
El Chubasco
El Chubasco Contributing Member • Posts: 845
6
While testing both lenses, 35mm 1.4 & 2.0, I realized that there is a very important difference that makes the 2.0 a much better choice for those using X-Pro2 and XPro1. In addition to the AF speed advantage of the 2.0, the frame indicating parallax correction when focusing an object at minimum focusing distance is much more precise in the 2.0 lens.
35mm 2.0 + XPro2
35mm 1.4  + XPro2
As can be seen in previous images, the square indicating the focus center when focusing a minimum distance is much closer to the center at infinitum in the 1.4 than it is in 2.0. Both lenses are about the same length and, of course, the focal length is identical.
The results are obvious. The 2.0 is much more precise when trying to place an object in the center of the frame. When using the 1.4 the center is inaccurate and the object ends up at the upper left corner of the frame. See the following images.
Object at the center of the frame using parallax correction offered by 35mm 2.0
Object at the upper left corner due to imprecise indication of the parallax correction with the 35mm 1.4
This lack of precision is a limitation in the 1.4 that the new lens has improved substantially, especially for those using the OVF with this lens. This is perhaps a very good reason to update the 35mm 1.4 with the 2.0.
 El Chubasco's gear list:El Chubasco's gear list
Fujifilm XF1 Fujifilm XP120 Panasonic LX100 II Fujifilm X-Pro2 Fujifilm X-H1 +11 more
Fujifilm XF 35mm F2 R WR Fujifilm X-Pro1 Fujifilm X-Pro2
El Chubasco
OP El Chubasco Contributing Member • Posts: 845
Re: 35mm 1.4 vs 35mm 2.0 parallax correction when using OVF
Ah! And just FYI. The same is true for the XPRo1 when using both lenses, the 35mm 1.4 and 2.0. See images below.
35mm 2.0 + XPro1
35mm 1.4 + XPro 1
