How commonly is focus trapping used in macro photography?
Started Jul 4, 2016 | Polls
Photogrrr Regular Member • Posts: 369
Assuming one is photographing moving subjects of course, how commonly do folks employ focus trapping in macro photography?
I've just recently tried exploring a bit of macro (bugs, bees, and other moving things), and I'm curious whether focus trapping is useful or practical in this context.
 Photogrrr's gear list:Photogrrr's gear list
Nikon D750 Nikon AF-S Nikkor 50mm F1.8G Nikon AF-S Nikkor 70-200mm F4G ED VR Nikon AF-S Nikkor 20mm f/1.8G ED
POLL
I use focus trapping all the time, and it works well for me.
23.1% 3  votes
I've tried focus trapping, and not found it useful for macro.
7.7% 1  vote
What's focus trapping?
38.5% 5  votes
I haven't tried focus trapping because it doesn't work for macro subjects.
15.4% 2  votes
I've tried focus trapping, but wasn't happy with the results.
7.7% 1  vote
I shoot macro using full-time servo AF.
0.0% 0  votes
I get better results using other focusing techniques.
7.7% 1  vote
  Show results
BBbuilder467 Veteran Member • Posts: 7,057
Re: How commonly is focus trapping used in macro photography?
I'm not sure what you mean. With trap focus, as in sports, you can pre-focus and wait for the subject to come into the frame. With macro, you're already in manual focus and might have a fraction of a millimeter that's in/out of focus. I can barely "trap" a flower in a slight breeze. The slight delay from a TTL flash can be a problem if I or the subject moves.
That might work for hummingbirds or butterflies with a long telephoto lens, but that's not macro.
OP Photogrrr Regular Member • Posts: 369
Yes, it would seem that the depth of focus is not sufficient for such an approach to be feasible in macro work, which is what I suspected.
There are two sorts of people in this world; those who can extrapolate from data
gardenersassistant Veteran Member • Posts: 9,656
Not necessarily. I use autofocus almost all of the time.
I occasionally (by accident) get something like focus trap when photographing something that is on a leaf that is being blown around. I press the shutter button but the subject has moved before the focus has locked on but the focusing mechanism remains engaged and a little later (perhaps as long as a second, perhaps even longer) focus locks and an image is captured, with the subject in focus. It's rare though, and so not something I could use as a routine technique, and the centre of focus probably isn't exactly where I wanted it anyway (I have never checked).
Macromeds
Macromeds Veteran Member • Posts: 3,986
An exercise in futility 99.999% of the time.
petrochemist Veteran Member • Posts: 3,615
I very rarely use it but there have been a couple of occasions where I couldn't see through the viewfinder & I used it with much better results than I'd have acheived otherwise.
I think focus trapping is fairly rarely used in any field of photography!
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
