90/2 compatibility with TC 1.4
Started Jul 3, 2016 | Questions
Styp Junior Member • Posts: 35
Hi,
I am curious if the 90mm prime is compatible with the 1.4x teleconverter.
Officially there is no statment on this - but has anyone tried it?
Cheers!
XF 90mm
persco
persco Regular Member • Posts: 189
Re: 90/2 compatibility with TC 1.4
As far as I know, the TC 1.4X and the TC 2.0X only work with the 50-140mm and the 100-400mm.
 persco's gear list:persco's gear list
Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR Fujifilm X30 Fujifilm X-T2 +4 more
57LowRider Veteran Member • Posts: 4,240
Some have claimed that the 1.4 TC works with lenses like the 55-200; I haven't seen confirmation though.
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +11 more
jayboo Senior Member • Posts: 2,366
Styp wrote:
Hi,
Cheers!
Simple answer No.  I believe only the 50-140 and 100-400.  As you can see, the front protrudes and would imagine damage any other lens you tried to fit it to.
 jayboo's gear list:jayboo's gear list
Leica CL Canon EOS R6 Leica M10-R Canon EOS R7 Leica Elmar-M 24mm f/3.8 ASPH +11 more
OP Styp Junior Member • Posts: 35
jayboo wrote:
Styp wrote:
Hi,
Cheers!
Awesome, thanks for the insight!
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Re: 55-200mm compatibility with TC 1.4 ?
There's a "hole" in the 55-200mm lens in the rear, which gets deeper as you zoom the lens in toward longer focal lengths. As to whether the cavity is large enough to fit the TC, I have no idea. Seems like someone who owns both can try it out carefully and let us know. Maybe the inner cylinder of the TC fits, but you need to make sure to keep the lens above a certain focal length and not zoom out past a certain mark.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
That's the reason why I was asking - the rear element is about 1cm inside the barrel...
Correction to my previous post: I looked carefully and found that I had missed a static rear-most element that does not protrude farther in as you zoom the 55-200mm lens. So anyway, if that rear element is not recessed far enough for the TC, it won't work. If it is, it might work.
Yes, as you have seen, the rear most glass does not move in the 55-200 and the length of the TC is too long for a fit, also for the 90mm.
celestialemissary
celestialemissary Contributing Member • Posts: 795
Rear element of 90mm is about 0.9cm inside the lens.
 celestialemissary's gear list:celestialemissary's gear list
Ricoh GR Digital IV +1 more
jackyu9801 New Member • Posts: 4
Just wondering, what if we can put a MCEX11 between the teleconverter and the lens? It might lose focus at infinity, but I hope this setup can still be usable in some cases (e.g. macro). I can't afford a 2x converter just for this experiment, so I'll be very happy if someone can give it a try.
 jackyu9801's gear list:jackyu9801's gear list
Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS Fujifilm XF 16mm F1.4 R WR +2 more
darinb Contributing Member • Posts: 941
The 90, as others have pointed out, is not listed as compatible with two TCs.
However, several posts are listing only the two zooms as compatible. In addition, the 80mm Macro is also listed as working with both TCs.
I just happened to be looking at the 80 before I came to this thread.
Darin
Darin Boville
My photo site: http://www.darinboville.com
Instagram: http://www.instagram.com/darinboville
 darinb's gear list:darinb's gear list
Apple iPhone 12 Pro Max
Guigui2890 New Member • Posts: 2
Exact. And just to be sure : I just tried my TC 1.4 and my 90 F2. The connection is not possible.
 Guigui2890's gear list:Guigui2890's gear list
Fujifilm X-H1 Fujifilm XF 35mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +4 more
bowportes Veteran Member • Posts: 4,337
The teleconverters work well with the 80mm. You might consider that as an alternative to the 90mm.
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
a_c_skinner Forum Pro • Posts: 13,047
An expensive way of getting 160mm f4.  The 55-200 would be a better buy.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Peter3579 Contributing Member • Posts: 759
Styp hasn't been seen on here for over 12 months.
 Peter3579's gear list:Peter3579's gear list
Ricoh GR IIIx Nikon Z7 Nikon Z50 Nikkor AF-S 300mm f/4E PF ED VR Nikon AP-F 70-300mm F4.5-5.6E +10 more
