Fuji macro extension tubes - MCEX-11 or MCEX-16?
Started Jul 1, 2016 | Discussions
Vikdaddy Junior Member • Posts: 35
Hi
Want to get one of the official Fuji extension tubes. Any advice on which to go for? If it helps, I intend to use them on either the 35mm f2 or the 56mm f1.2. I also own the 14mm and the 55-200mm but it's unlikely I'll be using those?
Any advice appreciated. I'd like to pick up one or the other for shooting with this Sunday.
Fujifilm XF 35mm F2 R WR
Cheezr
Cheezr Senior Member • Posts: 1,358
Re: Fuji macro extension tubes - MCEX-11 or MCEX-16?
Vikdaddy wrote:
Hi
Well, the longer the focal length the more extension you will need. Personally, I would get them both.
CZR
If the images are crap, it’s the camera
If the images are good, it’s the photographer, not the equipment
dincz Regular Member • Posts: 439
You could save a lot of money and get both:
http://www.ebay.co.uk/itm/Automatic-Macro-Extension-Tube-Set-for-FujiFilm-Fuji-X-Pro1-X-E1-X-T1-X-A1-DC670-/272212926612?hash=item3f6127a094:g:WjkAAOSwXSJXOWKM
They're only tubes after all so no need to pay premium price for Fuji ones.
OP Vikdaddy Junior Member • Posts: 35
Thanks. I'll just add that I'm loathe to buy the second rate ones and am set on the official tubes. Does anybody have experience of both?
KVI08106
KVI08106 Regular Member • Posts: 100
Here is a link to Fuji's magnification chart. It might help to determine which you need, or both. Fuji recommends not to stack them, but I have read on this forum, that people do without a problem.
http://www.fujifilm.com/products/digital_cameras/accessories/pdf/mcex_01.pdf
Notice the mecx-16 is not compatible with the xf14; even though you don't intend to use it on that lens.
I only have the mech-11 and I really like it. It kind of addicting on the xf35 (1.4). I have tried it briefly on the xf60 but I was too lazy for to breakout my tripod to get the best from it. Seemed quite good, though.
The mcex-11 was underwhelming on the xf55-200. Again, not your intention.
This is the 11 on the xf35 @F10
 KVI08106's gear list:KVI08106's gear list
Fujifilm X-E2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
boinkphoto
boinkphoto Senior Member • Posts: 1,007
I would avoid the Fotodiox ones. I have a pair I am about to return where the plastic is about the same quality as the toys you'd find at the checkout at the local mini-mart. The Fuji ones are an entirely different beast.
 boinkphoto's gear list:boinkphoto's gear list
Fujifilm X-Pro2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R Fujifilm X-E1 Fujifilm X-E4
Toilet Roll
Toilet Roll Regular Member • Posts: 281
 Toilet Roll's gear list:Toilet Roll's gear list
Fujifilm X100V Canon EOS 5D Mark III Canon EOS R
georgehudetz Veteran Member • Posts: 6,299
I'm starting to experiment with the 11.  FWIW, it seems that the 18-55, @55mm, mounted on the MCEX-11 gives only slightly less magnification than the 60/2.4 (note that this is not true of the 56 - it's MFD is such that it cannot achieve that level of magnification).  So, I'm going to give that combo a try at a botanical garden in Puerto Vallarta next week, with the logic that the OIS will make hand-held shots easier.  Not sure how that will turn out, and I know the 18-55 isn't as sharp as the 60, particularly at 55mm, but I'm not looking to crop or print large so I'm hoping the results will be acceptable.
 georgehudetz's gear list:georgehudetz's gear list
Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Sigma 14-24mm F2.8 DG DN Panasonic Lumix S Pro 16-35mm F4 +4 more
nixda Veteran Member • Posts: 5,515
The 18-55mm lens has a maximum aperture of 4.0 at 55mm. It's MFD is 219mm (sensor to subject) with the MCEX-11. This gives a DoF of 2mm. If you intend to get that close, you will need a very, very steady hand to focus and shoot. I would recommend a tripod.
I just ordered the same tube and was very close to getting a dedicated macro rail along with it. But I need to do some research first. I have plenty of rails to play around with. We'll see.
 nixda's gear list:nixda's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +1 more
win39 Veteran Member • Posts: 5,560
Your instincts are good. The Fuji tubes have contacts so you can use autofocus and metering. Third party items are very different. They are not all just empty tubes.
Thank you for your considered response
Thanks for all the tips guys. It seems that people have erred towards the mcex-11, I wonder why not the mcex-16?
The MCEX-16 provides higher magnification and shallower DoF than the MCEX-11. It is quite tricky to focus without special gear. If we take the 35mm F2 as an example, the DoF would be 1mm at MFD and F2!
Not having much experience with macro, I personally decided to start out with the MCEX-11. That looks daunting enough to me.
There is also another, very important aspect you haven't mentioned yet, I think: what is it that you want to take pictures of, and what is it you expect?
Good question; flowers probably, and other things from nature. I don't have a set idea of what though. At that price point I figure I'll just get one for sporadic use.
Sounds good.
I was asking, because, if you intend to take pictures of compound eyes, for example, one would need a completely different setup. Flowers and other reasonable large things are fine.
Photos-Mike Veteran Member • Posts: 4,066
I have both.
The 11 is much easier to use than the 16. As others have pointed out the DOF is quite narrow.
It needs a steady hand, and I use the 50-140 F/2.8 with it, since the stabilisation helps a lot.
The first 40 shots in this gallery are shot with the 11 on the 50-140:
https://mikekatz.smugmug.com/Mikes-Photos/2016/2016-06-07EdwardGardens/
Here's one of them:
Vic Chapman Forum Pro • Posts: 10,694
55-200 works really well for closeups from a distance with ext tubes (support it it with left hand if using the cheap ext tubes).
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
Photos-Mike wrote:
I have both.
Here's one of them:
Nice set Mike! This has tipped me over the edge. I am going for the MCEX-11.
Here are a few shots with the 18-55/MCEX-11 combo, hand-held. Shot at F8 (no need to shoot wide-open when you have OIS working for you). I'm pretty happy with the results. No doubt the 60 would do better if mounted on a tripod, but the 18-55+MCEX-11 makes for a pretty nice combination in scenarios where you don't want to use a tripod, or simply don't want to carry an extra lens, IMO.
Rod McD Veteran Member • Posts: 8,589
Hi George,
Thanks.  They look good.
I usually prefer using a Canon 250D on the 18-55 and 55-200 simply because you don't get the effect that if you zoom to alter the reach or framing, you immediately lose focus and have to refocus.  Close-up lenses just seem more compatible with the zooming function than tubes, and the achromatic ones are so good these days that I doubt most viewers could discern which was used.   You don't lose any light with them, which is another advantage if you're trying to maintain shutter speed, but there's no free lunch - you lose focal length and therefore reach.  Horses for courses, I suppose......
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +13 more
