Another question on M4/3 Oly colors
Started Jun 30, 2016 | Questions
MaciekPruski Regular Member • Posts: 288
Hi there,
I have been using the Olympus XZ-1 for a few years now and I love the colors of jpegs it produces. I have a very good DSLR but I keep coming back to XZ-1 because of the colors and nice jpegs.
And recently I'm thinking about buying either the Olympus E-PL7 or E-PL6. there is about 25% price difference where I live so this would be important ( if they would have similar jpegs I'd probably get the PL-6) Could anyone tell me how the jpeg output looks in these two cameras? There is a different image processor but are the colors generally similar? And how would they compare to the XZ1 small CCD sensor?
thanks,
Maciek
 MaciekPruski's gear list:MaciekPruski's gear list
Pentax K-1 Pentax KP Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA 17-70mm F4.0 AL (IF) SDM +6 more
Olympus E-PL7 Olympus PEN E-PL6 Olympus XZ-1
Pikme Senior Member • Posts: 2,176
Re: Another question on M4/3 Oly colors
I don't have either of those cameras but i have been using various Olympus cameras since 2003 - the color signature doesn't change much between cameras, but often the default settings for such things as sharpness, saturation and contrast do change.  Those can be adjusted if needed.
I had the XZ-1 until recently and loved it.  It has a very nice lens and made excellent images for non pixel peepers, but the larger size of the m4/3 sensor will give you more dynamic range,  better high iso quality, more room for processing and better file quality in general.  Of course, the particular lens used will also affect image quality.
Roberto M.
RezaTravilla
RezaTravilla Regular Member • Posts: 347
The colour will be less saturated but not that much. EPL7 is a good upgrade.
 RezaTravilla's gear list:RezaTravilla's gear list
Olympus XZ-1 Nikon D300S Olympus PEN-F Nikon AF-S Nikkor 24-70mm f/2.8G ED Panasonic Leica Summilux DG 25mm F1.4 +1 more
G Rash Senior Member • Posts: 2,890
If your choice is a PL7 or a PL6, you should keep in mind that the shutter shock issue is addressed in the PL7 with the 0 second anti-shock setting, which I don't think is available in the PL6.  The PL7 also has WIFI and a much higher resolution screen.  I don't really care about image transfer via WIFI, but I do like being able to use my cell phone as a remote control for the camera and being able to pick a focus point on my phone screen.  The PL7 also has focus peaking.
G
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
True. The E-PL5/6 (basically the same camera) do not have 0 second anti-shock, and that is needed to help avoid shutter shock problems that can happen in the maybe 1/30 to 1/320 sec range.
Also possibly more importantly the E-PL5/6 use the old 2 axis IBIS, the E-PL7 3 axis IBIS is way better. Also features like the next generation image processing chip (TruePic VII) that allow neat features like Live Composite on the E-PL7 make that a more interesting camera to use. The E-PL7 is worth the difference.
Yes, WiFi with a tablet or with phone adds some new ways to use the camera. There is also a free Windows program to do WiFi control. https://rebs.biz/cc/en/index.html
As for image quality, all the 16MP Pens and OM-D are much the same with the advantage that the later TruePic VII image chip of the E-PL7 does do better with available lens corrections and adds CA correction to the mix.
Regards......Guy
Loga Senior Member • Posts: 1,981
MaciekPruski wrote:
Hi there,
thanks,
Maciek
Hi Maciek,
if you are after the best Oly colors, then I suggest you to try an older m43 model like the E-P1, E-P2, E-P3, or E-PL1/2, E-PM1. To my expereince, this 12MP sensor and processing engine (including, but not only jpeg at the end) produces better colors and nicer overall IQ near base ISO (100-400) than the new ones. I had an OM-D, which has similar sensor that the new E-PLs, and I obviously prefer the IQ from my E-P1 to it.
Usability is an other question. While E-P1 is not bad after a firmware upgrade, it can't come close to the new series in some regards like AF speed.
Since a used old model costs close to nothing, you may buy both, and decide it for yourself, which colours do you prefer.
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Panasonic Leica Summilux DG 25mm F1.4 +6 more
Guy made some great points.  The IBIS improvement and Live Composite were worth the additional cost to buy the PL7 for me.
G
Paulmorgan Veteran Member • Posts: 9,499
You need to be seeing beyond colour.
Robert Evagelista
Robert Evagelista Veteran Member • Posts: 3,448
MaciekPruski wrote:
Hi there,
thanks,
Maciek
I have the XZ-1 and I have the E-M1. (Same Sensor as E-PL7)
Trust me you won't be disappointed about the colors.
E-M1
XZ-1
if your doing what everyone else is doing, your doing it wrong
- Casey Neistat
http://robertevangelista.blogspot.com/
https://www.flickr.com/photos/robert_evangelista/sets/72157647543027710/show
 Robert Evagelista's gear list:Robert Evagelista's gear list
Olympus E-M1 Samyang 85mm F1.4 Aspherical IF Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Canon Pixma Pro-100 +11 more
OP MaciekPruski Regular Member • Posts: 288
That is very interesting, exactly the kind of answer I was loking for. For the type of photographs I do no fast af or great high iso is needed. But the jpeg inage quality and colors are extremely important. Could you post some examples?
Hmmm... i know this is very subjective but i much prefer the colors from xz1 from the two images you posted.
Do you have more examples?
Robert Evagelista
- Casey Neistat
Guy Parsons
What kind of screen are you using to look at images?
My feeling is that the default jpeg Olympus images are made to pop on the common awful TN type panels in most notebooks and desktops.
Use a calibrated IPS type screen and suddenly it's a new world of colour and saturation.
As for 12MP to 16MP differences, none seen by me that are of importance except for the way better high ISO and better dynamic range and noise performance at base ISO of the 16MP sensor. Colours and saturation are all adjustable to taste with any camera, particularly if you use the raw files and a good raw conversion program, like Capture One or DxO.
Regards..... Guy
RSSrsvp Veteran Member • Posts: 3,251
Regards..... Guy
Guy, that is an excellent point that many people forget about. A few years ago I replaced a basic Dell TN panel with a HP Pro monitor that had IPS  glass and I definitely noticed a difference. Since then I took that IPS monitor to my office and now I am viewing images at home on my 5k 27" iMac which is also wonderful!
 RSSrsvp's gear list:RSSrsvp's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +1 more
Guy Parsons
Screens
My desktop PC has an Asus 24 inch IPS 10 bit monitor hung off it. Nice.
The little notebook I am using now, for emails and some forum fiddling, has a cheapo Philips 19 inch monitor that actually must be some simple version of IPS as it calibrates to very near 100% sRGB colour gamut display.
The notebook screen itself and the screens on the other notebooks  and netbooks in the house only calibrate to about a bit above 60% of the sRGB colour gamut, those TN panels are way behind IPS in colour ability and your head must be locked in one position as the colour and contrast varies as you move your head around.
On TN screens I used to see rather large differences between all the jpeg possibilities from the camera, then I got the IPS screen and those differences are now not so great, much more subtle and harder to choose between jpeg settings.
Regards.... Guy
wolfie
wolfie Veteran Member • Posts: 3,955
MaciekPruski wrote:
Hi there,
thanks,
Maciek
I'd say go for E-PL6 as the 7 AFAIK only offers a wifi capability, the same sensor and image processing. Unless wifi is important to you.
I've had E-1,E-300, E-P3,E-PL6 and E-M5 and Olympus colours are very consistent - (very good) . Out of the all my cameras the E-1 photos stand out as a bit different (but in a nice way).
Shoot the Light fantastic
https://aucklandswoffer.wordpress.com
 wolfie's gear list:wolfie's gear list
Canon G7 X II Nikon 1 AW1 Olympus E-M5 II Olympus E-M1 II Olympus 12-40mm F2.8 Pro +2 more
Guy Parsons
It's the 0 second anti-shock and the much better stabilisation that makes the E-PL7 the pick of the two.
The E-PL5/6 two axis IBIS actually adds a tiny amount of blur so it best to be kept off most of the time. Also the lack of true 0 second anti-shock does make shutter shock rear its ugly head occasionally.
The WiFi is handy for a neat remote release via touch screen shooting on a tablet or phone, but is not essential of course.
The later Truepic VII image processing chip and the Live Composite feature also tick the box for the E-PL7 as the better choice.
Regards..... Guy
Guy Parsons
More....
Another thought... the rear screen on the E-PL5/6 is 16:9 shape and does annoy some if they use the 4:3 ratio as the image is small in the screen. The E-PL7 has a 3:2 screen so is better with 4:3 images.
Another thing is the age, the E-PL6 (may 2013) is only a slightly updated E-PL5 which was announced in September 2012. The E-PL7 was announced in August 2014 and two years is a long time in camera development terms. My timeline helps sort out some dates and features. http://homepages.ihug.com.au/~parsog/olyepl1/80-Oly-timeline.html
Regards....... Guy
(unknown member) Forum Pro • Posts: 19,317
The colours from the xz1 are very good and hard to beat . its all about the lens quality .
Cheers don
Olympus xz1, e-pL5 , EM5 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9.
