Four Thirds lenses vs Micro Four Thirds lenses IQ
Started Jun 29, 2016 | Discussions
rodriguezPhoto
rodriguezPhoto Veteran Member • Posts: 4,260
Re: Four Thirds lenses vs Micro Four Thirds lenses IQ
Skeeterbytes wrote:
Ah, my error then, thought all the later SG lenses had CDAF magic sauce.
Oh how I wish they did!  I only have two that do, and they perform well accordingly on my G3.
In any case the 35 macro isn't a speed demon on an E5 so nobody should expect miracles on an m4/3. Still razor sharp, though.
Agreed.  Depending on the use, speed may not matter at all.
Rick
~~~ Kim
 rodriguezPhoto's gear list:rodriguezPhoto's gear list
Olympus E-1 Olympus E-3 Canon EOS 6D Olympus E-M1 Olympus E-M1 II +55 more
nebulla Senior Member • Posts: 1,528
I am not sure how well these ft lenses work on Panasonic bodies, but theses lenses was my reason for getting into  mft cameras . I currently have the Olympus E-M1 and the only mft lenses that I own are the 75-300mm, the 40-150 ( cheap one) and the Panasonic 25mm 1.7.
My collection of ft lenses are the 12-60, 35mm macro, 9-18mm. These lenses are bitingly sharp, and just as fast on the E-M1 as any mft lenses that I have used.  I am not conversant with Panasonic's bodies, so I am not sure if the GX7 or any has PDAF in which case should work just as good as on the E-M1. As for cheap adapters, Viltrox makes an adapter which I found to be as good as the Olympus ones. I use the MMF3, but only because it is water and dust resistant.
 nebulla's gear list:nebulla's gear list
Sony a7 III Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 400mm f/5.6L USM Tamron SP AF 90mm F/2.8 Di Macro +4 more
