This and that with K1
Started Jun 27, 2016 | Discussions
(unknown member) Veteran Member • Posts: 9,549
Still experimenting with highlights and shadows at low iso and liking the results... processed in Lightroom...
I do wish the camera had different aspect ratios, especially if the lines could show up in the viewfinder. Seems like an odd omission.
Amity Creek in Lester Park. I waited for a long time for a little bit more sun to appear. It finally sort of did.
Black and white looks very promising to me, the way I can push things around. I missed the focus by a hair on this tree. With my m43 camera I will often focus a little behind the main object and get everything in focus. With full frame I need to stop down more if I want to do that, at least at this focal length.
Bright sun and a shaded background...
This is just an experiment in single exposure shadow and highlight manipulation, to the point where it looks a little hdr-ish.
Pentax K-1 Pentax K-r
LaRee Forum Pro • Posts: 19,945
Re: This and that with K1
I like the  "Bright sun and shaded background" quite a bit John. I hope to have more time to give the k-1 a better run than I have so far. I am currently having an issue where I set up all the settings the way I like it and the camera is not remembering my settings. I have the option to remember all of this checked but it isn't happening. Even the wheel set up (which I like exactly backward to what Pentax default is) won't stick. It is strange. But like I said, I haven't had a whole bunch of time to work with the k-1 and I hope to change that.
 LaRee's gear list:LaRee's gear list
Fujifilm X100S Pentax K20D Pentax K-x Pentax K-5 Pentax K-1 +29 more
OP (unknown member) Veteran Member • Posts: 9,549
That does sound strange. One of the first things I did was switch the wheels, but it has stuck. It seems like it would take telling the K1 to return to default settings to do what you describe.
grunde New Member • Posts: 13
Hello all
Always interesting to follow up pentax news on dp review.
One question related to K1 though!
Have anyone tried pixel shift with crop mode (DA 15 ltd)?
It is a very useful lens for landscape
Grunde
