12-35 2.8 vs 14-140 II - how much better?
Started Jun 27, 2016 | Discussions
akjos
akjos Veteran Member • Posts: 4,595
I got G7 and chose 14-140 lens as a kit.
It is great considering size weight and the price bundled with the G7
But i wonder how much better is the 12-35. Is it much sharper and and does it have the nano coating wow contrast?
If i got it i would still keep the 14-140 II likely (3.5-5.6) for certain situations.
I do have fx nikon and lot of lenses but using them less and less.
I have 25 1.7( which is ok but no super impressed with it. ) and 42.5 1.7 which is excellent. Maybe i will also get the 25 1.4 leica eventually but time will tell...
I tried 15 1.7 and liked it a lot but it was visibly decentered so it went back. Not sure if to try it again or get the 12-35 (i like the 12mm end although not essential and ois)
Panasonic Lumix DMC-G7 Panasonic Lumix G 42.5mm F1.7
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Re: 12-35 2.8 vs 14-140 II - how much better?
Way better.
12-35 f/2.8 replaced my very sharp 14-45 f/3.5 on my Panny GX7, and recently acquired Oly Pen F.   For travel, 12-35 is my "go to" lens fitted on the camera.
Good luck.
Lena
Like others here, I suffer from chronic GAS.
Gear Acquisition Syndrome.
a few hundred nautical miles SW : 17º 52S, 149º 56W
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
richj20 Forum Pro • Posts: 10,181
Theoretically, It should be, because it is ideal optically with a 3x zoom ratio, so it's not really a fair comparison with the 14-140mm, a general purpose superzoom. Also, the 12-35mm doesn't have the longer focal lengths of the 14-140mm, so there is nothing to compare in that regard.
Nonetheless, you might be surprised at how well the 14-140mm at 14-35mm compares to the 12-35mm. So, what are you gaining? 12mm, constant f/2.8.
Read here:
http://shop.panasonic.com/cameras-and-camcorders/lumix-camera-lenses/H-HS12035.html
It is a nice all around lens for sure. It gets a great review here:
http://naturalexposures.com/panasonic-lumix-14-140mm-lens-review/
I assume you have specific uses in mind for both lenses, should you get the 12-35mm.
- Richard
akjos
OP akjos Veteran Member • Posts: 4,595
Re: thanks everyone ( nt)
Robiro Veteran Member • Posts: 6,813
If money is no problem
It is sharper. But not THAT much.
At 25mm f4, the Pana 12-35mm equals or betters any prime lens in terms of resolution. It is that good.
On the other hand, 14-140mmII is very good as well.
There is definitely a difference between 12mm and 14mm. I can get shots with my 12-35 that I can not get with 14-140mm because it is not a 12mm lens at the wide end.
If money is no problem, get a 12-35mm. It is close to immune to shutter shock, unlike 14-140mmII which rattles like crazy.
You will be satisfied with 12-35. But do not expect a drastic increase in sharpness. There is not THAT much of a difference.
 Robiro's gear list:Robiro's gear list
Panasonic Lumix DC-G9 Panasonic 12-35mm F2.8 Olympus 40-150mm F2.8 Pro Sigma 30mm F1.4 for Micro Four Thirds Olympus 100-400mm F5.0-6.3 IS
Fredrik Glckner Veteran Member • Posts: 3,894
Both lenses are very good.
The 12-35mm is fantastic at 12mm, and very good at 35mm. See my review here:
http://m43photo.blogspot.com/2013/01/lumix-x-12-35mm-f28-review.html
It is a bit annoying that it suffers from zoom creep, otherwise, it is a pure pleasure to use.
The 14-140mm II is also very good, considering the zoom range and the size/weight:
http://m43photo.blogspot.com/2015/06/lumix-kit-zoom-lenses-compared.html
No zoom creep with the 14-140mm II lens.
I have used both for years and years (since they were released), and I have used the 14-140mm II the most. It is very versatile.
Andreas Voigt Regular Member • Posts: 179
I got the 14-140 as kit with the GH4.
Based on the positive opinions in this thread, I must have gotten a really bad sample.
It is nowhere close to the 12-35 f2.8 and it gets even worse on the longer end when compared to the 35-100 f2.8  and the Oly 40-150 f2.8 respectively.
 Andreas Voigt's gear list:Andreas Voigt's gear list
Sony RX100 Panasonic GH5
akjos
so the 12-35 creeps and 14-140ii doesnt? That is disappointing . I just ordered it since it went on sale again plus i had 100$ gift card from previous purchase. So for 597 total . Hopefully it IS better
http://www.pbase.com/jps1979/galleries
akjos
Well... mine is good but not mindblowing which is to be expected for 28-280mm lens. I would say it is comparable to nikon 18-105 and 18-140 lenses. With the advantage of much longer reach.
Good thing i just ordered the 12-35 then  😂
akjos
Nice and informative blog btw
Thanks for sharing
Keep the shutter at 1/400s or  faster to avoid shutter shock with 14-140mm.
That is not true. Very sharp at 140mm even wide open.
secretworld Senior Member • Posts: 1,734
Agreed, since I have cameras with electronic shutters, all lenses I own got better .
Before that my 20mm f1.7 (which doesn't suffer from SS) was really better then my 14-45mm, but now the are equal.
Only prime that is a little sharper then the 14-45 is my Oly 45mm f1.8. But only when stopped down to f8. I tested a 12-35 f2.8 against my 14-45 but could not see any meaningful difference except of course the f stop.
I don't own a 14-140 but did use it a few times, from a friend and it is indeed a sharp lens when used with electronic shutter. It is a kittle less sharp then the 14-45 45-150 combo but not by much and only visible with 1:1 viewing.
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
I posted about this a while back after I got a 14-140II to complement my 12-35/2.8 and 35-100/2.8. I got it for hiking & travel, and keep my 2.8s for low light event work & portraiture. Test shot comparisons convinced me I wasn't giving up much. The 2.8s ARE a bit sharper, but you'd be hard-pressed to see a difference in a properly sharpened print at 16"x21".
http://www.dpreview.com/forums/post/57096621
The way to make a friend is to act like one.
http://jacquescornell.photography
http://happening.photos
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
KarlSalt Junior Member • Posts: 42
I had both but to be honest there isn't that much in it if the light is good, indoors or low light then the 2.8 is a massive improvement. I ended up selling the 12-35 and got the 12-32 pancake (great little lens) to make a nice light weight kit and the 25 1.4 which I use when the light isn't so good.
cptobvious Contributing Member • Posts: 850
Maybe I had a bad copy of the 14-140 II but it was significantly worse than the 12-35 I owned. The center throughout the range never got truly sharp and the corners were mush. Plus the build and materials quality was disappointing for a lens retailing at $700 (I had the new matte black version - it felt like just a larger version of the matte black 14-42 II).
woof woof
woof woof Senior Member • Posts: 1,897
I bought a 12-35mm f2.8 and G7 to use as a package and I think that it's a very good lens and one advantage is that I can get a very similar look from the combination that I'd get from a ff camera and lens.
With ff I'd probably be mostly shooting between f4 and f11 (at the most) and with the MFT combination I can shoot at f2.8 to f5 (or smaller aperture if I wish) and when using the f2.8 to f5 type range I get the sort of ff look that a f3.5 to 5.6 zoom just can't match.
brianric Veteran Member • Posts: 8,980
First 265 pictures shot with 14-140mm. Switch to 12-60mm for next 302 pictures as I needed the extra 2 mm at the wide end for some shots. Last 18 pictures were with Nikon D5. M43 camera was GX-8.
http://www.brianric.com/Relay-for-Life-Events/2016-Relay-for-Life-Events/2016-Fairless-Hills-Relay-for/
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
john isaacs Veteran Member • Posts: 8,444
It is silly to convert the m43 lens to FF equivalent and not the Nikon DX lenses.
Of course, no doubt, the 14-140 produces acceptable results. Otherwise I would not use that lens. But the question was "compared to the 12-25".
And for video it is my lens of choice.
akjos
That is very true. When i got D700 and 24-70 like 5 years ago as my first FX setup i kept stopping down to at least F4 or 5.6 especially at 70mm just to get SOME background
12-35 is coming though and I can't wait to test it out and compare to the 14-140II.
