Perils of Infrared Photography
Started Jun 24, 2016 | Discussions
Vorchek Regular Member • Posts: 118
A brief introduction: since December I've been using my new E-M5 II with enormous pleasure. I haven't had this much fun with a camera since film days (which weren't really all that long ago for me). I didn't make the customary announcement before because I've been too busy hacking my way through the complexities of this little beast. Suffice to say that all the hype is true, and I now consider myself entrenched in the m43 camp. In addition to the camera I possess a Panasonic 14-42 kit zoom, a Voigtlander 25, and a bunch of adapted Minolta MC/MD lenses, all of which treat me very well.
I wish to ask questions concerning employing this camera for infrared photography. I do so in this forum because A) there doesn't seem to be a forum dedicated to the general topic, and B) as I'll only be using the E-M5 II for the time being, I wondered if there might be camera specific tips. So, bear with me, even if my questions and observations sound like the usual stuff.
I'm not accomplishing a great deal with IR. An unconverted camera, mated to a Hoyer R72 filter, creates odd enough images, some of them quite good in black in white, but attempts to do color inevitably fail to a greater or lesser extent. I'm perfectly willing to accept that I'm doing it wrong--will take that as a given--but what exactly?
Internet information, some of it most authoritative sounding, is full of statements like "Simply do this," "simply do that," only in my case simply apparently doesn't cut it. Among other things, I'm not getting the separations of stark whites and blues that IR fans seek and so many of them attain. I'm not a total novice: work in Raw, got it; custom white balance in camera or in post-processing, got it; swap blue and red channels, got it; tinker with contrast and such, got it; what I don't get, seldom even approach, is the classic IR imagery.
Perhaps the lens is a relevant factor. I'm using the Voigtlander 25, which isn't rated tops for IR (I have lately learned), yet I understood that to mainly be a hotspot issue, which I know how to handle, albeit laboriously. That aside, am I beating my head against the wall because of the lens?
Whatever dominant color I begin with, depending on the white balance, when I swap channels I typically just replace that with another dominant color: overall red becomes overall blue, beige turns orange or whatever. I'm definitely missing something when it comes to color separation, but the source of the problem stumps me.
A few on-line sources say that many photo editors can't create the necessary white balance because of their inherent 2000k limit. This dreaded restriction, they claim, severely weakens the desired effect. How important is this? Many sources--most--make no mention of it. In my absolute best shots (very few) I get light pink foliage, with everything else shrouded in a kind of dull pastel blue; interesting to be sure, and in appears on the proper track, but hardly the goal. Have I a WB problem? Obviously lots of photographers sail through this phase of processing without difficulty.
My main software is Zoner Studio Pro. I toyed with Olympus Viewer 3, found it unedifying. I just downloaded Raw Therapee, but I haven't gotten into it yet. Perhaps certain software is mandatory for worthy results? That doesn't seem right, but if it is, so be it.
There I stand at present. While prepared for heavy post-processing, I find myself blocked at every turn. Does something in the foregoing cut through the darkness? It wouldn't surprise me if somebody can pick it out right away. Thus far it isn't me.
--Vorchek
 Vorchek's gear list:Vorchek's gear list
Samsung NX20 Olympus E-M5 II Panasonic Lumix DC-G9 Sigma 4.5mm F2.8 EX DC HSM Circular Fisheye Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
Olympus E-M5 II Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS Voigtlander Nokton 25mm F0.95 Type II
Skeeterbytes Forum Pro • Posts: 23,186
Re: Perils of Infrared Photography
Glad to hear you're enjoying your new E-M5ii. Is it IR converted (IR filter removed from the sensor stack) are you trying to achieve the look with a cutoff filter and post-processing?
A few folks here have converted cameras and achieve good results so hopefully they will chime in. I see many posts on the difficulty of infinity focus with certain lenses.
I hope you find some answers.
Rick
elmanhansen Regular Member • Posts: 114
I  do quite a lot IR work with M43 cameras. I have a Pana G1 and a Pana GH2 both converted to IR. I have not used IR filters on 'normal' M43 cameras.
The 2000 Kelvin problem is no problem. I have made camera profiles for both cameras using Adobes Profile Editor. And I also use a 'manual' white point in the cameras. Just choose a green subject as 'white'.
I do my processing in Lightroom. When the pictures are imported their color temperature is about  20K Kelvin. So I can do the changes needed.
I mainly make BW pictures - buy sometimes I do false color processing. I use Photoshop for that - and then sometimes again Lightroom for the final processing.
My main lens for IR is the Pana 14-45 kit zoom. It is very good for IR work as it pruduces no hot spots. Other lenses (like tha Pana 7 - 14 mm) can produce hot spots on the pictures. They can be removed - but it is extra work.
gpb11 Veteran Member • Posts: 5,035
@Vorchek -- I also started out using an R72 filter. I shared your frustration and actually gave up on it for a period of time, later deciding to suck it up and get an EPM2 converted. I've had pretty decent results with the Olympus 14-42 EZ pancake lens. I'd suggest selecting lenses that don't generate any hotspots as IMHO that's just setting yourself up for more hassle than it's worth.
Beyond that I'm not sure how much help I can offer as I've only dabbled in IR a little bit so far, and generally have stuck with black & white output as that's my preference.
Still, can you share any examples of what you're talking about?
Can you talk about this more, or point me somewhere? I've struggled with LR not handling IR well, but since DxO OpticsPro works fine I've not worried about it. Still would like to fix LR if it's feasible.
Yes, custom WB is necessary as camera's autoWB doesn't usually work very well.
I've used a gray card to set custom whitebalance on my IR converted EPM2 and it's worked well. Any thoughts on that vs. setting whitepoint off of something green?
Images are about emotion. Technical perfection is nice, but does not stand by itself.
OP Vorchek Regular Member • Posts: 118
The camera is not converted.  I'm using a Hoya R72 filter.  So far I haven't noticed a focusing problem; the lens is bright enough that, wide open, I can focus through the filter.
--Vorchek
Good black and white
My very best color
All too typical color
Ditto
That's the kind of stuff I've been getting, with a lot more of the latter two types when I'm trying for color.
--Vorchek
Lew the software to overcome this problem is called 'DNG Profile editor'.
It is an unsupported program from Adobe. However you can still download it and 'tweek'  a profile for your camera that overcomes the 2000 K problem. The limit of 2000 Kelvin  seems seems to be an Adobe restriction only.  Capture One goes lower than that. I once asked Thomas Knoll why Adobes programs do not go lower than 2000 Kelvin - but did not get a proper answer.
I can make a 'User manuel' on how to do it if you need that. It is fairly simple.
However this is mainly/only a problem if you want to make false color pictures.
If you are going for BW it really does not matter. Then you just have to note what the dominant colors are in your IR picture when entering the BW conversion.  I use NIK Silver Efex Pro II and On1 Photo 10 BW conversion. Both are very good.
I notice that the person who started this thread uses a program called Zoner Studio Pro. Never heard of it.  And I do not know how to do it in that program.
But in LR and ACR I do know how to do it.
Thanks, that should be enough to get me started. I usually just need to find the end of the string and I can go from there.
Good to know.  I've downloaded the Nik plugins but not played with them.  I've been pleased with the DxO OpticsPro B&W treatment, and have also enjoyed MacPhun's Tonality application.
LMNCT Veteran Member • Posts: 4,908
Nice one Lew.  That is the frosty white that I like a lot.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
northcoastgreg Regular Member • Posts: 139
6
I've been using AWB on an IR converted EPL-1 without any issues. I get IR raw files that are fine for conversion to false color images in Photoshop. After tweaking the exposure and contrast and adding a fair measure of sharpening (~60) in Lightroom, I send a copy to Photoshop. In PS I add adjustment layers, via an action, for swapping red and blue channels, color balance, and hue/saturation. Then I go into the color balance adjustment layer and tweak the image to my liking. I flatten the image and send it to Perfect Effects, where I add dynamic contrast.
I'm not really interested in creating the "classic" false color IR look. I'm just looking for something that pleases my aesthetic sensibility.
A couple of examples:
 northcoastgreg's gear list:northcoastgreg's gear list
Pentax K200D Olympus PEN E-PL1 Olympus OM-D E-M5 Pentax K-5 IIs Pentax smc DA 15mm F4 ED AL Limited +28 more
At first glance, it seems you're underexposing a stop or so; I'd bump it up a bit.  The foliage should be bright white; a fully sunlit lawn shot in IR is not that different IMHO from a white beach or snowy field.
Also I suspect you're losing a fair bit of dynamic range going to high ISO, so that may be compressing the curve.  Take with a grain of salt, I've not opened these up in an editor so can't see the histogram.
My first suggestion is to look at the exposure and maybe tweak that with a little bit of curves adjustment to "pop" the images.  Then work on them from there.
Big Ga Forum Pro • Posts: 18,627
Are you sure the cutoff frequency of this filter isn't too high to allow false colour?
Isn't the 72 for 720nm cutoff?
I thought the false colour cameras had a filter somewhere in the 6xx nm region.
This is off the top of my head though so I may be mistaken.
I am using a 700 nm cut off in my Pana G1. You can still make false color pictures with this wavelenght. If you go lower like 670 or 620 you have more room for adjustments however. But according to the company that converted my cameras  then  other problems arises. So I stick to 670 - 700 nm for my cameras.
Examples of different frequency cutoffs can be seen at http://kolarivision.com/articles/choosing-a-filter/
The R72 should be fine.
Just for kicks, I grabbed one of my IR shots and did a quick and dirty false color. DxO OpticsPro for RAW conversion, then Affinity Photo for the red/blue channel swap and a couple minor tweaks. This is with a 750nm filter.
I'd have some time later tonight or tomorrow to have a go with one of your IR images if you want to PM me.  It might at least solve the question of whether it's a software matter or camera/filter matter.
RBrianTaylor Forum Member • Posts: 84
While I'm certainly no expert, I did find this website to be particularly useful when I was starting out in IR photography:
https://photographylife.com/introduction-to-infrared-photography
I chose to have a camera IR converted, mainly so that i could experiment with IR photography indoors or in areas where there wasn't a lot of ambient light (most cameras have a pretty severe IR blocking filter in front of the sensor, and I wanted to remove that to "open up" the color spectrum into the IR region.
Here is a useful thread over at mu-43.com that may help you choose lenses for IR photography (some of the best visible light lenses end up being the worst for IR photography, I've found):
https://www.mu-43.com/threads/native-m4-3-lens-infrared-performance-ir-hotspots.32081/
I hope this helps.
 RBrianTaylor's gear list:RBrianTaylor's gear list
Nikon D800 Olympus E-M5 II Olympus E-M1 II Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Nikkor 50mm f/1.8D +14 more
These picture samples happened to have high ISO, but shooting at base ISO made no practical difference.
--Vorchek
I suppose I could e-mail a Raw file, if that is what you had in mind.
--Vorchek
Fredrik Glckner Veteran Member • Posts: 3,894
If you are resourceful, it is not difficult to full-spectrum-convert a digital camera. I've done it with the inexpensive Nikon 1 S1:
http://nikon1user.blogspot.com/2015/08/infrared-conversion-of-nikon-1-s1.html
I disagree. At least with the use of the word 'fine'.
The R72 will allow SOME colouration, but I suspect the OP is after the typical false colour look that's fairly popular and you will get a MUCH better result with the 665nm filter, and even that isn't 'good' enough for those people wanting a more intense effect, which is why they also offer the 590nm as well.
more examples here
https://www.lifepixel.com/infrared-filters-choices
