FingerPainter wrote:
The Sony 18-200m on a6000 is sharper, faster and less expensive than M.Zuiko 14-150 II on E-M1.
The difference in marginal. And the Olympus on the other hand, is weather sealed. And Panasonic 14-140 is better. No matter how you slice it, zooms on a6000 don't look good compared to Micro 4/3.
Panasonic 7-14 > Sony E 10-18
E-M5II + 7-14 f/2.8 PRO: $2,100. GX8 + Pany 7-14 f/4: $1,900. a6000 + 10-18 f/4: $$1,300
Sure, but for that extra money you get:
- weather-sealing (not with Panny 7-14, though)
- IBIS
- solid magnesium alloy body
- better EVF
- higher flash-sync
- higher max shutter speed
- electronic shutter mode
- Mic input
- 4K video (Panasonic)
- High res mode (Olympus)
Olympus 12-40/2.8 > Sony E 16-70/4
E-M1 + Olympus 12-40 f/2.8 PRO: $1,800. GX8 + 12-35mm f/2.8: $2,000. a6000 + Sony 16-70: $1,550.
Sure, but E-M10 II + 12-40 is ~$1,450 and a6300 + 16-70 is $2,000. The former is more of a competitor to a6000, and the latter is more of a competition to GX8 and E-M1. Although a6300 is probably more of a competitor to GH4, as both are heavily video centric.
Olympus 14-42 kit lens = Sony 16-70 kit lens
E-M10II + 14-42: $700. G7+14-42: $600. a6000 + 16-50: $700.
And GX80/85 + 12-32 is $800. And this is the comparison that makes sense, as all those cameras are roughly in the same league.
The above should not be true, considering the difference in sensor size and resolution.
Most camera makers have lenses at different quality levels. This is true for Oly, Pany and Sony. You are comparing top quality Oly and Pany lenses to less-than-top quality Sony lenses.
The problem is that apart from some FE lenses, there appears to be nothing other than "less-than-top" quality from Sony. Sigma showed us what kind of quality can be achieved on a6000. And at a reasonable price at that. None of the Sony lenses tested by DxO approach that level of quality (still talking in terms of DxO scores). I find this weird.
As you can see, from the price comparisons for the lenses you cited, to get higher sharpness on an m43 body, you need to pay a higher price
Sure, that's because you made sure to choose more expensive bodies The lens prices by themselves don't vary that greatly
, and whe you get similar quality you pay a simialr price. I didn't bother to check weights, but I wouldn't be surprised to see that the better m43 lenses weighed more than the poorer Sony lenses.
I'm sure they are, especially Olympus ones. They go all out with their PRO line and don't seem to care about things like that. Different design priorities, I guess. It's one of the reasons I'm not really interested in them.
Where is this 5-6 P-Mpix advantage that a6000 should have over 16mp MFT camera? It's nowhere to be found.
You shouldn't expect to see consumer grade lenses perform as well as "PRO" lenses.
Sure, but Sigma 60/2.8 is not exactly a "pro" lens. I'm not familiar with Sony's marketing, can any of their APS-C designed lenses be considered "pro"? To be honest, I would hesitate to use this term at all when talking about those systems, prosumer maybe fits better (when I write PRO in relation to Olympus lenses, I only mean their official designation, as means to distinguish that line of products).
The real issue here is that Sony has fewer top-grade lenses for the wider focal lengths on APS-C.
The scores are mostly within 1 P-Mpix of each other, which I don't think is enough to declare one a definitive winner.
If they score about the same, but the Sony is several hundred dollars less expensive, isn't the Sony a value winner?
No, because for more money, you get added value in other areas, as pointed out above. If you choose the top Sony body, you will not pay less.
However, I d agree that most of the earlier Sony E-mount zooms were underwhelming
And the problem is that it's almost all there is. Sony stopped making lenses for APS-C E-mount almost three years ago. All you can hope for now is more (and better) FE lenses.
You see almost the same thing in Canikon. Mearly all of their best lenses are made to fit the FF mount.
Yes, that's why I think Fuji is the only serious APS-C system on the market. Everything else is just an afterthought.
However, this is not a problem, in that you can use these lenses on the APS-C bodies if yo want to.
Sure. The problem here is the prices for FE lenses. Most are really expensive. Looking at B&H, there are only 3 FE lenses below $700 mark. And that includes the kit lens. So yeah, you can do that, but that's a weird argument for someone who just tried to make price the major advantage of going that route.
Who said the purpose of Sony APS-C system was "a compact system that delivers high IQ". I don't think that was ever its purpose. It was a smaller, lighter system than the (dSLR) competition.
Isn't that the same? DSLR like performance in smaller, maybe even cheaper package? Sure, you get smaller kit, you get DSLR level performance, but you don't get DSLR level image quality (again, still talking DxO).
Why not just go for A7? The first generation was not much bigger than a6000. And now you will truly have an advantage in image quality. And there are some lenses that make it a very nice, compact kit, even by APS-C standards.
Price?
Sony's APS-C seems like an unnecessary compromise that you take because you can't afford to go for FE.
Perhaps it is. Or perhaps it is a system that is small and inexpensive.
Micro 4/3 can be even smaller and less expensive, so...
It makes up for it by being cheap and offering nice feature set and good AF system. But it doesn't offer the IQ advantage that one would expect to get. That's my whole argument.
Your expectations seem to be based on sensor difference without reference to size and price.
Because that's the main argument against MFT. That bigger, higher res sensor automatically means major advantage over smaller MFT cameras. Because equivalence. If DxO is any indication of reality, than that is not the case here.
And sorry, but robust AF does not make a6000 a competitor for cameras like E-M1, GH4 or GX8. Not the same league.
If they are not in the same league, why would expect the lower league camera to provide better IQ?
You know very well that it's not about IQ. Older, entry level E-PL5 delivers the same image quality as the newest E-M5 II or E-M1, why didn't you use it in your price comparisons? Do they play in the same league? Is Nikon D3300 in the same league as D7200? IQ is almost identical after all.
