FingerPainter wrote:
DXO numbers do work in cross-platform comparisons.
Assuming you are right (I'm not gonna argue either way), I think that puts the Sony system in a bad light. As in, poor value for money, and just simply unrealised potential.
An a6000 with a Sigma 60mm lens costs $790 at B&H today. It gets 60% better PMP than an E-M1 with the Sigma 60mm, a combnation which costs $1140. so I'm not seeing the poor value you claim in the Sony combination.
It's highly unlikely that someone would only get that single lens for their a6000. Although I bet the new Sigma 30/1.4 will join the ranks at the top. Still, that's a very limited selection of lenses that can utilize the advantage of larger, higher res sensor.
I mean, it looks like the only way to get sharper photos with A6000, is to use primes. Because scores for Sony zooms are pretty much the same as for E-M1 with Panasonic and Olympus zooms. That kinda sucks, considering larger, higher resolution APS-C sensor.
Really? The FE 70-200mm f/4 gets similar results on an a6000 as the 40-150mm f/2.8 PRO on an E-M1, and the Sony combination costs $350 less.
Sure, but why buy an APS-C camera if you need to buy large and expensive FE glass to utilize it's full potential?
The Sony 18-200m on a6000 is sharper, faster and less expensive than M.Zuiko 14-150 II on E-M1.
The difference in marginal. And the Olympus on the other hand, is weather sealed. And Panasonic 14-140 is better. No matter how you slice it, zooms on a6000 don't look good compared to Micro 4/3.
Panasonic 7-14 > Sony E 10-18
Olympus 12-40/2.8 > Sony E 16-70/4
Olympus 14-42 kit lens = Sony 16-70 kit lens
The above should not be true, considering the difference in sensor size and resolution.
Where is this 5-6 P-Mpix advantage that a6000 should have over 16mp MFT camera? It's nowhere to be found. The scores are mostly within 1 P-Mpix of each other, which I don't think is enough to declare one a definitive winner.
However, I d agree that most of the earlier Sony E-mount zooms were underwhelming
And the problem is that it's almost all there is. Sony stopped making lenses for APS-C E-mount almost three years ago. All you can hope for now is more (and better) FE lenses.
And even with primes, the advantage is not as big as one would hope. Just look at scores for lenses on Nikon D5300. Why is there such a big difference in scores between two APS-C cameras with almost identical sensor?
Sony's original design goal was small and light-weight, not high IQ. Their latest FE lenses have changed that direction.
And that's the thing, you need to buy FE glass to get the most out of your APS-C camera. Kinda defeats the purpose of a compact system that delivers high IQ. Why not just go for A7? The first generation was not much bigger than a6000. And now you will truly have an advantage in image quality. And there are some lenses that make it a very nice, compact kit, even by APS-C standards.
Sony's APS-C seems like an unnecessary compromise that you take because you can't afford to go for FE. It makes up for it by being cheap and offering nice feature set and good AF system. But it doesn't offer the IQ advantage that one would expect to get. That's my whole argument.
So if those scores can be trusted, then the take away is that there's very little advantage, if any at all, with going the A6000 route.
There actually seems to be a price advantage going the a6000 route.
Of course, mid-level camera will always be cheaper than high-end model. And sorry, but robust AF does not make a6000 a competitor for cameras like E-M1, GH4 or GX8. Not the same league.
A bit more DoF control and maybe half a stop or so on sensor performance side, that's it.
And the cost of bodies.
Only if you accept that E-M1 and a6000 are the only bodies on the market. A6300 is very expensive and doesn't seem to be as feature packed as MFT cameras of similar price. And you can get cheaper MFT bodies that are more capable by a lot of metrics than the cheapo a6000.
But yeah, there isn't a very big IQ advantage to an a6000 over m43.
Both easily negated by using better lenses on MFT side,
Well, I'm not sure that is true. Which m43 lenses do you have in mind for a budget-conscious purchaser, that perform better on m43 bodies as their E-mount counterparts on an a6000.
Usually not on a budget, really fast glass is usually very expensive. Chasing IQ is unfortunately costly, regardless of how you go on about it. From what I see, within reason, there's 35/1.8 vs 25/1.4, 16-70/4 vs 12-40/2.8 or 12-35/2.8, 70-200/4 vs 40-150/2.8.
or possibly by future cameras with higher res sensors.
We're just beginning to see 20MP m43 sensors. It is goinh to be a while before we see 24MP.
Yep, my bet is at least three years before we see any moves in this regard. Unless Panasonic will try to push 8K into consumer cameras, which I do not believe will happen. Too bad DxO did not test any lenses on PEN-F yet, it would be interesting to see if there is any difference. I kinda have a hunch that we're entering a territory of diminishing returns.
My bet is that in the mean time, Olympus will try to improve the High Res mode, making it usable in more scenarios.
In the mean time, I wouldn't be surprised to see 28MP and maybe 30-32MP APS-C sensors.
I don't think those will show up in Sony E bodies anytime soon, either. When will we see next prosumer APS-C E-mount body? 2-3 years from now? And I doubt Sony would put such a sensor in entry-level model. But it's Sony, anything can happen, so I guess we'll see.
I think one would expect to get more when going with a larger format (that's still possible if you go with Nikon DX for example, at least according to DxO).
Both a Nikon DX camer or an a6000 give you more. It's just differenr types of "more". The Sony gives you a smaller size than an E-M1, sometimes with that 1/2 stop advantage you mentioned, and usually sharper images, at a lower price but with worse handling. The Nikon DX cameras more fully realize the potential of APS-C in a larger, more expensive package.
Not sure about the expensive part. Bigger competition in lens market usually means more affordable lenses. And there's a nice selection of decently priced Nikon bodies as well. But DX has the same problem as Sony E, you are usually forced to use larger, more expensive FF lenses, at least when you want a dedicated prime.
