Considering 4:3, but have some questions about IQ
Started Jun 17, 2016 | Discussions
EarthQuake Veteran Member • Posts: 3,240
Re: Hmmm
Nirurin wrote:
If your goal is too shoot mirrorless with a couple of slow zooms, no need to switch. Stay right where you are and save your money. You'll only gain size reduction with m43.
Mind if I ask what areas other than size reduction would have gains if I changed to m43? I also plan to do a fair bit of macro work, as well as astrophotography. (My plan was to get a samyang 12mm f2 one day, dont know if there is an m43 equivalent yet)
DXO lens "scores" are for camera+lens score. The A6000 has 24mp vs 16mp for most M43 bodies. The difference in MP is the main reason for the difference in score. Doesn't mean the Sony lenses are significantly better, just that the system with more MP will probably resolve more detail (not surprising).
A Nikon 85/1.4 has a better "score" on a D800 than on a D4 as well, 44 vs 33. That should tell you all you need to know about using DXO lens scores to compare lenses shot on different bodies.
Size and weight are the primary reason to switch, but there's also IBIS, which if you're not trying to freeze motion, will allow you to shoot at much lower shutter speeds, and consequently much lower ISO with much better image quality, compared to APS-C with primes which are often not stabilized. Other differences like ergonomics, controls, video, etc but this really varies by the body.
OP Nirurin Senior Member • Posts: 1,152
Re: DXO numbers do not work cross platform
DXO sharpness numbers do not, in any way work cross platform. The only way you can even come close to determining how one lens/camera combo could fare against the other is if both systems have the EXACT same lens that you can normalize the results to.
Luckily for you, you have an A6000. And there is a lens on that system that is the EXACT same lens on m43's: the Sigma 60mm f2.8. The lens is literally a carbon copy of itself for both systems, the difference is the mount alone. Now look at the DXO sharpness numbers for both systems and then see how the lenses for each system compare to the sharpness of the Sigma 60mm on each of their respective systems. You will find plenty of m43's lenses come close and beat the Sigma 60mm. On Sony's side, you won't find any that beat it, and very few that actually get close to the sharpness of that lens.
I tend to use it as a reference, as it has a lot of the lenses all tabled up for easy referencing, seeing what is available and roughly the quality etc. However I don't use it as a definite result, just a guideline...
HOWEVER I didn't realise the results they use weren't standardised. Your example of the sigma 60mm is a brilliant one, and something I wouldn't have thought of to check. From that, it does seem that the M43 lenses do have some extra sharpness/quality, though obviously this is then mitigated by the smaller sensor etc when it comes to low light and such.
Still, it's given me a bit more of a positive spin on my potential choices. The GX85 is looking tempting right now, as I could basically exchange my current sony setup for the equivalent m43 camera and lenses, and only have to spend maybe £100 or so.
Bhima78 Senior Member • Posts: 2,850
Yep, you got it! Yes, there is an advantage to a larger sensor in DR and noise at higher ISOs. You just have to figure out of the difference between say, APS-C and m43's potential IQ is worth any of the other sacrifices, and you have to weigh the fact that the Sony lenses (the ones that aren't super expensive FF ones) do a complete disservice to their sensor, and in many ways can give results that end up being worse... even with the larger sensor.
I was originally looking into the A6000 and the Fuji XE-2 to replace my Nikon DSLR a few years ago. Went to a camera store tried them out, and decided to check out the super little E-M10 on the shelf as well. The XE-2 had very sluggish AF, the A6000 and I just never got along ergonomically (it also feels like its price) and neither had a touchscreen. Then I used the E-M10 and just felt right at home with its ergonomics. Sure, the Fuji would offer more potential IQ, but at the end of the day, I want to also enjoy the camera I'm shooting with moreso than worrying about squeezing every last drop of IQ I can from an image. That's why I went home with the E-M10. Everyone is different though, and the best thing to do is actually try out the m43's camera you are interested in and see if it jives with you.
 Bhima78's gear list:Bhima78's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS +12 more
curiosifly Senior Member • Posts: 1,219
So, is it true that  pan 14 140 with gx85 will yield image with  finer detail than sel 18 200 with a6000? After resolution difference is taken into consideration ? Thanks.
ciao
At the very least they would be VERY close.
That Sony lens is sort of a dog... 7MP sharpness on an A6000 is pretty poor... not even 50% the performance of the Sigma 60mm f2.8 on the A6000. The Panasonic scores the same 7MP... but on a 16MP EPL5 haha! Looks to be 70% the performance of the Sigma 60mm f2.8.
Re: At the very least they would be VERY close.
I am a little confused, sorry. Does that 7 mp mean the final image's effective resolution after combining lens and sensor? If that's the case, it means the two systems are equivalent in final result? Sorry if my question is too naive. Just started to understand lens metrics.
ciao
TBH, I'm not sure exactly what the metric means, but I am assuming it means: when shooting an MTF chart, this lens can make out fine lines up to 7MP using this specific camera. But even that doesn't really square with reality. As I have posted numerous examples of higher DXO sharpness numbers not resulting in actual real world sharpness increases over other lenses for different formats. Its why I've given up trying to use DXO to compare lenses and cameras of different formats and just stick to using it to determine how good a lens is within a format, but also buttress that assumption with real world examples.
Pixnat2
Pixnat2 Veteran Member • Posts: 5,767
Best thing to do before switching
Before you swtich, it would be a good thing to download RAW files from some websites (dpreview, photography blog,...) and play with them in your favorite RAW converter.
It will prevent you to have too high expectations and be dissapointed if your new camera don't meet them.
If IQ is up to your personal standards, then go with m4/3. It's a great and mature system where you can find all the lenses you need and even more. Especially compared to Sony APS-C.
Good luck.
 Pixnat2's gear list:Pixnat2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Fujifilm X-T2 Nikon Z6
Serguei Palto Senior Member • Posts: 1,015
Re: Considering 4:3, but have some questions about IQ
TN Args wrote:
Nirurin wrote:
...today I spent some time on DXOMark to look through the 'best' lenses... Here are some of the scores -
Sony 55-210 = 13
Sony 18-200 = 13
Panasonic 14-140 = 9
Olympus 14-150 = 10
The sony 55210 and the panasonic are both very cheap, with the Olympus being the same price as the sony 18-200 (twice the price of the others...) and yet the sony lenses are leaps and bounds better image quality?
You will find the DxO lens scores go up and down when you select a body with more or less MP. Try it. The Panasonic in your list as a 9, scores 13 on an Olympus E-PL5 body. So it is not the lenses that are being scored alone. So you can only really compare lens vs lens on the same body.
Unfortunately DxO have still not got any lenses tested on the new 20MP micro four thirds bodies, which would up their scores still further.
Personally I ignore DxO like the plague for a number of reasons, and I advise you do the same unless you want to get very technical.
Totally agree with you.
The correctly measured properties of a lens can not depend on a camera body or the other equipment used with the lens.
I also have a filling that many of the "testers" are FF-biased. For ungrounded reasons they consider FF sensor as a kind of etalon. Unfortunately, the DXO is not the exception. At first time I introduced to DXO they measured the resolution in absolute units like lp/mm (line pairs per millimeter). These absolute units for the resolution are well accepted by scientists, because  they provide  a comprehensive information on the lens performance independently on what registration media (sensors) are used with the lens. The only point is that the measurements must be accurate.
However, very soon, after I made my own tests using  some reliable methods, I had realized that  the absolute values from the DXO are more than TWO TIMES  lower compared to what I measured!! I was unable to explain this difference even on account of possible different criteria used for getting the resolution values, because the contrast between the resolved line pairs of the highest spatial frequency was quite high. I also compared some m43 lenses with one of very good FF-lenses which on the optical bench provides very high resolution (~100 lp/mm). From the comparison it became evident for me how bad are many of FF lenses compared to the m43 lenses in terms of the absolute optical resolution. The DXO inaccuracy (this is my very soft characterization for their activity)  became  evident for me.
Later the DXO had changed (again for ungrounded reasons) the system of units they used.  Now they use Mps, which, to my mind, simply allows further "foolishing" (I believe that they do this not for special reasons) the people. For example, according to DXO P 20 f/1.7 provides ~12 Mp resolution. One can think that 12 Mp  is just  highest number of pixels for the optimal sensor  to be used with this lens. But now everybody, who can use HR mode in Olympus camera, can check that the 10-12Mp number for P20 f/1.7 lens is just an incorrect value. P20 f/1.7 can resolve more than 50 Mp  according to my tests.
I do not recommend DXO when somebody is thinking on choosing a camera system or lenses.
I am not against the Lab tests, - just opposite. The lens tests are very useful if they are based on a reliable methodology which excludes the dependence of the measured characteristics on a camera body or sensor properties.
alcelc
alcelc Forum Pro • Posts: 19,003
Re: APSC 18-200 = ?
No, it is an out of the camera jpeg.
Albert
alcelc
Re: A Panny 12 f/1.4 is coming, but 'll cost some money (nt)
Nirurin wrote:
lescrane wrote:
My goal was to lighten the weight from my 1.6x canons. I bought a Sony a6000 a normal and tele kit lens at great price new. Gave it a year. Hated how the camera handled. Not happy w the lenses or even the very expensive 18 to 135 power zoom. Sold it all at a loss.
Now I'm trying m43. I found both the panny gx8 and g85 easier to handle than Sony. I found the 14 to 140 ii panny sharper than my 2 Sony lenses.
This is all subjective. You may find the opposite. I am foi going by my results not any published tests.
For me the switch is motivated only by size and weight esp w the 100 400PL now available. If I was a 25 y.o. weight lifter I'd shoot ot full frame.
What do you think of the gx8 vs the gx85? These are the cameras I am looking at, leaning towards the GX85.
After my wife took away GX7 from me (a perfect match with her 14-140II on e-shutter) and leaving me with the good old GX1 (  ), I had long waited to upgrade it. G7 (no IBIS, and I prefer range finder style more than mini-dslr) and later GX8 were once on my wishing list. However, the size of GX8 was always my problem on using M43. During the time passing without new model in sight, the size and weight issue of GX8 was fading. Just before my final decision to go for GX8, launching of GX85, indeed the GX7 Mark II, had been my final goal.
Not to mention the small and lighter weight, GX85 has most features GX8 has, but absent from GX7 (Dual IS, DFD, Post Focus, 4K video and Photo). In fact, GX85 has better IBIS than GX8, which also support video as well. GX85's new shutter does minimize shutter shock. I suppose it might be the best solution recently in M43 land towards shutter shock (if it bother you).
Unless you need the weatherproof feature of GX8 (you need the limited weatherproof lenses for the effect), IMHO there is not much point to go for GX8. Or if you can wait, may be GX9....
Albert
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
A lens test in isolation is pretty useless , as far as I am aware we all use a lens mounted on a camera to take our photos . So the only test that makes any sense is indeed a "system" test. Lenses for m43 need to have double the resolution just to compete with a FF cameras assuming the same MP count , given that we are stuck at 16/20mp and FF has had 36mp for a number of years and more recently 42 and 50mp the comparative results are hardly surprising , well except to some members of the m43 fan club.
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
Peter Del Veteran Member • Posts: 7,988
See this picture
http://www.dpreview.com/forums/post/57931298
and camera and lens choice depends on how big a print you want to produce, perhaps.
I only print A3 and hardly ever crop as I use zoom lenses.
Peter Del
 Peter Del's gear list:Peter Del's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +5 more
Invalid point of view.
If you know true properties of a lens then you know the best possible performance on any camera including that which will be produced in future.
The true properties of the lens are like a passport of a human. The data in the passport do not depend on a policemen who checks them, but provide a valuable information on a human.
With true data in the lens "passport" you can easily compare the optical quality of a lens independently on a camera platform it is produced for. One can also easily predict the best performance of an arbitrary system (camera+lens) with an arbitrary number of Mps on a sensor.
There is a concept of the ideal lens (which, of course, is independent on a system platform), and the true optical quality of a lens must be estimated on the basis of how large is the difference between the ideal and a real lens.
Contrary, if you measured just a performance of a particular system (body+lens) you can tell nothing on the true lens performance. As soon as a new camera bodies will be produced, all the data you measured for a particular body-lens system become just a garbage. A bright example are the data measured on the camera with the shutter shock.
The power of the concept of the interchangeable lens cameras is that lenses you bought can be used in future cameras. It is why only the true lens properties are valuable.
Astrotripper Veteran Member • Posts: 8,676
I don't think anyone truly knows. It's just a score. They have their own criteria and a formula for calculating it, and you get this number as a result. Without matching it with actual real world photos, it's hard to tell what the number actually means. And it looks like smaller sensors always have smaller scores, even if the sensor resolution is the same.
I think that is the claim DxO makes. Does it actually reflect reality is another matter. You can read up on the idea behind those scores on their website .
Don't get too caught up with those numbers. They can be useful sometimes, but in reality, don't tell you much about the lens.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
Re: Hmmm
Well, if you venturing beyond the slow zooms, then it's a different story.
Sony does have some cheap primes, but the main advantage of m43 is the selection of native glass is bigger and still growing. you have to mostly rely on FF lenses for new releases on Sony which means bigger and usually more expensive.
The macro area is well covered in m43. 3 prime lenses already. One more out in a few weeks/months. Many Pro zooms and standard primes also have respectable pseudo macro capabilities. Only thing missing is a telephoto macro prime (like the old Sigma 150mm f2.8).
If you go wider than 24mm in 35mm terms (12mm with m43), it's more slim pickings with m43. Only zooms and fisheyes exist, with I think the ultra fast Voightlander lens (10,5mm f0.95). There has been consistent requests for a true, non-fisheye, ultra wide prime on m43 but still nothing yet. One of the few areas where there is a glaring omission with m43.
There's the Kowa Prominar 8.5mm f2.8. Supposedly excellent.
M4/3 also has two excellent ultra-wide 7-14mm zooms; the Olympus f2.8 and Panasonic f4. I think these have helped quiet the grumbling about the lack ultra-wide rectilinear primes. I thought about getting a Kowa 8.5mm, but couldn't really justify it because I have the 7-14mm f4.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
tokumeino Veteran Member • Posts: 3,175
I used to own the Sony big grey
Sony 18-200 = 13
I used to be a big fan of the big grey Sony 18-200 (not the small LE one) : very decent IQ and impressive stab. I used it on a NEX 5R and really loved it.
Recently I bought a 14-140 in kit with my new GX80 and I'm shocked : it's twice lighter than the big grey, faster as well, and better IQ-wise. No contest.
I don't know how DXO concludes to a 13 vs a 9 and I don't care : the 14-140 is way better.
Dash29 Senior Member • Posts: 1,448
I have found that the Tamron 14-150 to be sharper and give a more accurate colour rendition than the Olympus 14-150
samtheman2014
Again I take photos by mounting lens on camera as I suspect do you , DXO updates all it's lens tests to new bodies in each format { eventually } so you can see how a given lens will work on your respective camera. Photography is camera + lens
The rose of all the world is not for me. I want for my part
Only the little white rose of Scotland
That smells sharp and sweet—and breaks the heart.
:Hugh MacDiarmid
samtheman2014
Bhima78 wrote:
Nirurin wrote:
So at the moment I have my toe dipped into the sony APSC ecosystem, with an a6000 and the kit lens + the 55-210 zoom. I've had a few issues with it though, and I have the opportunity to sell it all and exchange for another system.
Figured it would be better to do it now, before I buy any more lenses!
One issue I had with the sony system is that there are very few lenses, and a lot of the ones I like have compromises. For example, they have some fairly decent zooms, but they're all pretty slow in aperture. And the only macro is 30mm, though it's also very cheap.
I had been under the impression that micro 4:3 had more lenses at better prices, with the downside being the smaller sensor size. However today I spent some time on DXOMark to look through the 'best' lenses... Here are some of the scores -
Sony 55-210 = 13
Sony 18-200 = 13
Olympus 14-150 = 10
Though saying this, the 'kit' lenses for panasonic seem to get marginally higher marks compared to sony's, so maybe it evens out on average over the line...
This is turning into some kind of 4/3 bashing, which isn't my intention. I'm partly wondering if I am misinterpreting the results of these tests somehow. I really want the 4:3 lineup to be worth the hassle of changing systems haha.
Both systems are small, I guess I want to be able to get good image quality for my money.
Any tips or thoughts are welcome, sorry for the ramble, late night
Here are a few real world examples as to why you cannot use DXO sharpness numbers across platforms.
Real world scenario 1: Canon 6D with Canon 17-40mm F4: Sharpness score: 14MP /// Olympus E-M1 with Olympus 12-40mm f2.8: Sharpness score: 9MP
Now, here are actual real world photos with those setups:
http://www.43rumors.com/full-frame-vs-micro-43-revisited-with-pro-olympus-lens-guest-post-by-chris-corradino/
That test is comically badly done , the fact that you need to post such poor examples as "proof" rather says it all
Now some real world corner performance at infinity (really important for landscape lenses): Nikon performance in the corners at f2.0 (scroll to the bottom of the link to see the Nikon 24mm f1.4 at f2.0): http://www.cameralabs.com/reviews/Nikon_Nikkor_AF-S_24mm_f1-8G_ED/sharpness.shtml
Panasonic 12mm f1.4 corner performance at near infinity:http://www.cameralabs.com/reviews/Panasonic_Leica_DG_Summilux_12mm_f1-4_H-X012/sharpness.shtml
A FF lens at F/2.0 is the same as shooting a 12mm F/1.0 lens on m43 , same AOV, same DOF and same total light gathered . Speaking as FF and m43 system user I would love to see an example where the very extreme corners of an 24mm @ F/2 on FF or 12mm @ F/1.0 is really important for landscape" do post one I would love to see it
Just for a visual aid this is the area being considered on the 24mm at F1.8 , I darkened the rest of the image so that the " really important" part of the image could be easier seen Perhaps you could show me a m43 12mm at f/0.9 with better results.
I do not think that there is a 12mm F/0.9 lens available though if the extreme corner performance of the voightlander 10.5mm F/0.95 wide open are anything to go by I would not hold out much hope
http://www.lenstip.com/445.11-Lens_review-Voigtlander_Nokton_10.5_mm_f_0.95_Summary.html
  • weak image quality on the edge of the field of view,
  • huge vignetting,
  • monstrous coma,
  • high astigmatism,
  • visible spherical aberration,
  • significant field curvature,
  • ugly out of focus areas,
  • field of view over two degrees narrower than stated in the specifications,
  • weak price/optics quality ratio.
We hereby inform that an experiment entitled “ultra fast ultra wide-angle lens” ended with a failure. Nothing to add…
:Hugh MacDiarmid
