Terrible coma on Canon 50mm. Do I have any options? Would servicing be worth it?
Started Jun 17, 2016 | Questions
J Fisher New Member • Posts: 5
My Canon EF 50mm f1.4 USM has always had really bad coma. I assumed these lenses were just bad like that and for the most part stopped using it, but I recently learned they're normally better than this.
Is there any cost-effective way to get a normal-quality lens instead of this dud?
I bought it two years ago so the warranty has expired.
I've contacted Canon and got a boilerplate-sounding recommendation to send it in for service. There was no indication that this is something they can fix and no cost estimate. I have no experience with their servicing and I'm concerned that this could be weeks of hassle only to find out that they'd like $200 to repair a $300 lens that they should not have sold to me in the first place, or charge for a repair that when I finally get it back, hasn't improved the coma very much.
Does service sound like a route I should take? Are there any other options that make sense? Any tips or recommendations?
Thanks!
Canon EF 50mm F1.4 USM
diness Veteran Member • Posts: 3,758
Re: Terrible coma on Canon 50mm. Do I have any options? Would servicing be worth it?
Thanks!
Are you sure the lens is normally better?  I thought 50mm 1.4's had bad coma pretty often.  To be honest with you, if you don't like it, I would consider selling it and getting the 50mm 1.8 stm.   I think it's a better lens especially for the money.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
OP J Fisher New Member • Posts: 5
With you mentioning that you thought they were often bad, I went back and did some double checking, and... some of the examples I thought were shot with the 1.4 lens were actually shot with the 1.8 you mention. So now I think you may be right; mine might not be out of the ordinary. I'll keep digging, but assuming you're right then that certainly answers the question of whether servicing is worth pursuing!
KENTGA Veteran Member • Posts: 8,733
Re: It's normal
The Canon 50 1.4 has never gotten good press. I bought a Sigma 50 1.4 instead but rarely use it or my other primes except for 100L macro. Guess I'm just a zoom guy.
Kent
 KENTGA's gear list:KENTGA's gear list
Canon EOS 7D Canon EOS 6D Canon EOS Rebel SL1 Canon EOS 80D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO +14 more
