Best macro lens for Canon EOS M10
Started Jun 17, 2016 | Questions
whoami911 New Member • Posts: 9
What is the best macro lens for Canon EOS M10?
I mean real macro (1:1 ratio or better)
 whoami911's gear list:whoami911's gear list
Sony Cyber-shot DSC-HX90V Canon PowerShot ELPH 360 HS
Canon EOS M10
Microcosmik New Member • Posts: 23
Re: Best macro lens for Canon EOS M10
I don't think there is a simple answer to that question.
There is one EF-M macro lens, a 28mm which has just been released (or will be very shortly).
The EF-M 11-22mm offers close focusing at the 22mm end, but not enough to reach 1:1 I believe.
Outside of the M range you have a choice of pretty much any macro lens going. With an adapter you can use EF lenses and retain electronic communications with them - Canon's latest round of macro lenses are all very good as, indeed, are their earlier FD mount lenses (which you can also use with a suitable adapter - although manual only).
You could also use the highly acclaimed Canon MP-E 65mm although it will be difficult to use outside of a studio setup as the M10 lacks a flash hot shoe, and light becomes more of an issue at magnifications greater than 1:1.
Furthermore there are a tonne of options to provide macro capabilities without using a dedicated macro lens (and for very little cost).  Reverse lens adapters, front mounted adaptors or extension tubes can all be used to achieve higher magnification on your existing lens set.
If you can expand on the type of subjects you intend to shoot and what kind of budget you are working with I might be able to offer some more specific advice. Other than that a ~100mm focal length macro lens is a good start if you can find one within your price range, or have a look at the EF-M 28mm macro lens if size and weight are important factors.
koenkooi Contributing Member • Posts: 919
5
Since you can't use a decent flash on the M10, the new EF-M 28mm f/3.5 Macro IS STM is you best bet.
Sample picture of that combo: https://www.flickr.com/photos/koenkooi/27113920314/in/dateposted-public/
On my 'classic' M I use the MP-E 65mm + MT24-EX flash, which is an awesome combo, but as I said, no way to use a decent flash with the M10. And with macro work you will always needs more light than you have
 koenkooi's gear list:koenkooi's gear list
Canon EOS 7D Canon EOS M Canon EOS M6 II Canon EOS R5 Canon EF 85mm F1.8 USM +20 more
OzarkAggie Senior Member • Posts: 2,153
Sigma makes some excellent macros, but in any case you'll need extension tones or a bellows if you want something greater than a 1:1 ratio. Try Sigma's 50 mm ex.
It's not the camera...
 OzarkAggie's gear list:OzarkAggie's gear list
Canon PowerShot A590 IS Canon PowerShot G1 Canon PowerShot Pro1 Canon EOS 10D Canon EOS M +11 more
Gesture Forum Pro • Posts: 10,236
Good suggestions.  Don't discount applying older technology like a Minolta Auto-Bellows III plus 100mm Minolta macro lens.  In my experience, the film era macro lenses do well with digital sensors, but some trial is obviously involved.
Jefenator
Jefenator Senior Member • Posts: 2,866
I'd look at Canon's EF-S 60/2.8 macro prime on the OEM Canon adapter.
If you can wait a bit longer and don't mind getting in real close, the new 28mm should be dandy.
Legacy / full-frame stuff is all fine and well for some things but can be a bit clunky to work with and you might experience more issues caused by stray light from the oversized projection area, bouncing around the camera innards. (This might still be the way to go on a shoestring budget - most legacy macros are nice & sharp by reputation. Most older ones will require an extension tube to get to 1:1. Like I said: clunky...)
 Jefenator's gear list:Jefenator's gear list
Sony a7 Canon EF-M 11-22mm f/4-5.6 IS STM Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony Alpha NEX-7 +8 more
richro Regular Member • Posts: 244
8
 richro's gear list:richro's gear list
Canon EOS 6D Canon EOS M5 Tamron SP 24-70mm F2.8 Di VC USD Canon EOS M Canon EF 85mm F1.8 USM +11 more
OP whoami911 New Member • Posts: 9
I found on ebay Meking Manual Macro Lens 62mm 2:1 Prime Lens For Canon EOS EF Mount.
This lens doesn't exist in www.dpreview,com
Does anybody have this lens and can share his/her experience with this lens ?
Looks like it may be a rebranding or even copy of the Laowa 2:1 macro:
http://www.venuslens.net/product/venus-v-dx-60mm-f2-8-ultra-macro-lens/
I can't say what quality the Meking one is (and looking on ebay there seem to be several "copies" of the lens now with different branding) but the original Laowa/Venus lens is quite well regarded,  I don't own one, but know a few who do and they like the range it gives them.  It's manual only, but sharp enough.  It does seem to have a signature warm colour cast in many images, but most either don't notice or don't mind; and the colour can be tweaked in post anyway.
adrian1988
adrian1988 Regular Member • Posts: 128
The Meking one is a faked one as informed by Venus Optics. The faked copies have a different structure in the lens front and in the focusing ring. The optical quality, of course is worse than the Laowa one.
 adrian1988's gear list:adrian1988's gear list
Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Voigtlander 35mm F1.4 Nokton
beagle1 Forum Pro • Posts: 11,740
best value -   Canon 100mm 2.8 macro non-L  ----  $ 250 used
Vixky New Member • Posts: 1
Hi, I appreciate this thread was a while ago.
But I also want to know if I can add a Macro lens to Canon EOS M10? It would need to be comparable to an DSLR sigma macro lens 60mm. It’s for Dental Photography. Is this possible? I’m looking alternatively at a Canon 350D, with a 60mm lens and Meike flash second hand probably.
Theres no seating for a ring flash, how is this possible in a simple practical way?
I’m not technical AT ALL and have just been told these specs are required. Any help is grateful.
Sittatunga Veteran Member • Posts: 5,406
You can mount any EF mount macro lens or extension tubes if you use the Mount Adapter EF-EOS M.  That Sigma lens would be fine, if it's an EF mount version.  Personally, I use a PENTAX-M macro 100mm f/4 on a K&F Concept PK - EOS M adapter, but that's because I got it ridiculously cheap second-hand.
The actual ring flash tube will mount to the front of the macro lens in the normal way.  It should have a selection of adapter rings which screw into the filter thread at the front of the lens. You would need to mount the body of the flashgun to a hotshoe mount flashlight trigger, much like m100 did here; https://www.dpreview.com/forums/post/60994126.
You can either use a camera cage like m100 did, or a much simpler flashbar which screws into the camera's tripod bush and has an accessory shoe on its end.
Under the red camera menu 3, Flash Control, make sure that Red-eye reduc. is Off so as not to confuse the flashlight trigger.  Under the Built-in flash settings set the Flash Mode to Manual flash, the Shutter Synch. to 1st curtain and the flash output to Minimum in order not to overwhelm the ring flash.  (Minimum intensity is probably not that important for dental photography, as the camera's flash won't be in line with the patient's mouth, but the trigger will need a good view of where the camera flash falls on the patient's cheek.)
