Metabone EF to M43
Started Jun 16, 2016 | Discussions
rronald Forum Member • Posts: 93
Metabone EF to M43
I am using Olympus EPL6 and wnat to purchase Metabone EF to M43 adapter with AF to join the old EF400mm f5.6L.
Does any one have this experience and is the AF speed is good for this combination?  Does it support CAF?
Olympus PEN E-PL6
VBester
VBester Regular Member • Posts: 131
Re: Metabone EF to M43
Used the Smart adaptor on my 100-400II and it worked very well on SAF. CAF does not work at all. IQ was very, very good.
I used the Canon IS system on the 100-400 (you can choose to use Canon's IS or IBIS). I am not sure how well IBIS will cope on the 400L.
All politicians are scum
 VBester's gear list:VBester's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 12mm 1:2 +1 more
Pete Berry Veteran Member • Posts: 4,322
I've used my GH4 extensively with the 400/5.6. The AF-S is quite good - definitely faster than my adapted 4/3 PanaLeica 14-150, which is contrast-AF enabled.
The biggest problems with the GH4/400 are lack of OIS, negating hand-holding as is possible with the Canon 100-400 (tho the EPL6 probably compensates this well), and difficulty finding the birdie at 800mm EFL The IQ is very good, but the 100-400 IS v.1 I used was superior at 400mm - and zoomed out, no problem finding the subject.
Pete
OP rronald Forum Member • Posts: 93
thanks for the reply. Still thinking to purchase the metabone or not.
