Which cheap prime for general use in lowlight?
Started Jun 14, 2016 | Discussions
sgaray New Member • Posts: 4
Hi guys,
I recently purchased an EM-10 with the 14-42 IIR kit lens. I also have a few of my father's old OM lenses which are really fun to use: 50mm f1.4 50mm 3.5 macro, 28mm 3.5 and a 75-150 f4.
I'm quite happy with the lenses and the camera and I feel that what I really need is to practice and study to improve my skills.
However, I feel that I don't have a decent lens that can handle lowlight: the 50 f1.4 feels too long for me indoors and the kit lens and 28mm f3.5 are too slow.
Since I got my birthday coming in I'd like to buy a cheap prime that I can use in lowlight (mostly indoors). It's going to be a long time til I get another lens. What would you recommend?
I'm from Argentina and lenses are really expensive here, 500 us dollars for a used panasonic 20mm f1.7 so you can get an idea. Luckily, a relative of mine will travel to the US in august so he can get it for me.
Budget is around Us$250, I don't want to buy used because he won't be able to test the lens and time is tight because he'll only be there for a week.
So far I have seen 3 lenses:
I've been testing with the kit lens and 25mm seems a bit tight though I'm sure I could get used to it. The 20mm I like for being small and it seems to me the focal length would work better indoors but I'm a bit concerned about the AF speed and banding issues I've read about here.
So what do you guys think? Are these fine choices? would you recommend anything else?
Thanks!
Olympus M.Zuiko Digital 25mm F1.8 Olympus OM-D E-M10 Panasonic 20mm F1.7 II Panasonic Lumix G 25mm F1.7 ASPH
Coaster95 Regular Member • Posts: 173
Re: Which cheap prime for general use in lowlight?
I've used the 20mm f1.7 for some time now on both EM10 mk1 and EM10 mk2 and experienced no banding issues. Focus is reasonably fast just not as fast as some. I think you would be very happy with that option. There is the Panasonic 14mm f2.5 for a similar price if that focal length suits you better. The Sigma 19mm f2.8 is a lower budget option worth considering as it has had some quite good reviews. Also the Olympus 17mm f2.8 although this does not seem to be particularly well regarded.
 Coaster95's gear list:Coaster95's gear list
Sony RX100 VI
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the 25 mm 1.7 works fine and fast so I would recommend that one.
I don't think you will go wrong with any of these  three.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Sa7724473 Senior Member • Posts: 2,029
What sort of use exactly will you have? With the 25mm on the GM5 for example sitting in a restaurant at a small table I can take a head-and-shoulders of two people sitting side by side in landscape mode, with no proble,. If I want to capture the whole table, I'd stand up and take a single step back.
If you are wanting much wider angles you should probably look at the Olympus 17mm f 1.8. You could go even cheaper with the Olympus 17mm f 2.8 that should be dirt cheap. But there you'll need to bump up ISO a bit more. With these cameras you're fine up to about ISO 3200 as long as you dont mind a bit of grain/character in the image.
Also the Panasonic 14mm f 2.5 has been around for a long time, so that should be cheaper on the used market or refurbs,
Or hell, use flash - you paid for it and its on the camera. There are ways to make that work more naturally as well eg diffusers/bounce etc.
Club44 Regular Member • Posts: 129
Here is one from 17mm f1.8.
pkc55 Regular Member • Posts: 184
There are 2 choices for the used one if you want to purchase from ebay. Of course, you may need to pay more for shipping. Also, i'm not sure if there will be any custom fee.
  1. The Panasonic 14mm f2.5 mk1. around $150 used
  2. The Panasonic 20mm f1.7 mk1 around $230 used
The 14mm AF is very fast and the 20mm AF is one of the slowest. However, the 20mm may provide better IQ too.
 pkc55's gear list:pkc55's gear list
Sony a6000 Panasonic Lumix DMC-GX85 Sony E 55-210mm F4.5-6.3 OSS Sigma 30mm F2.8 EX DN Sony E 20mm F2.8 +1 more
Bear in mind that there is an image-stabilised 12-32 f 3.5-5.6 zoom that, in many cases gets you to the same place as the unstabiliized 14mm f 2.5. And gives you much more than just 14mm.. And probably costs the same or less used, as it is a standard kit lens on Panasonics.
OP sgaray New Member • Posts: 4
Thanks for all the replies guys. I think I'm gonna give the 20mm a try.
