Panasonic old and new versions of lenses
Started Jun 14, 2016 | Discussions
Ron Zamir Senior Member • Posts: 1,421
Panasonic 14mm. F-2.5 and Panasonic 20mm. F-1.7 - old and new versions.
What are the differences between the older and new version?
Which is better, if at all.
Samples to compare?
 Ron Zamir's gear list:Ron Zamir's gear list
Olympus E-1 Olympus OM-D E-M10 Olympus E-PL8
Panasonic Lumix G 14mm F2.5 II ASPH
RedDog Steve
RedDog Steve Senior Member • Posts: 1,972
Re: Panasonic old and new versions of lenses
Samples to compare?
Here's the DXO test results for the 20mm.
The older lens appears to do better by just a whisker.
rd
 RedDog Steve's gear list:RedDog Steve's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH Panasonic 8-18mm F2.8-4 +17 more
ThePalindrome Regular Member • Posts: 477
Samples to compare?
That tells you something about the manufacturing tolerances and the measuring tolerances. Unless they tested a dozen lenses or so, you really shouldn't interpret these results so that the old model is better than the new model.
Which brings up an interesting point, has someone done a comparative study that is sensitive and large enough to have an idea about manufacturing variation?
 ThePalindrome's gear list:ThePalindrome's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus XZ-1 Olympus M.Zuiko Digital 45mm F1.8 +1 more
LMNCT Veteran Member • Posts: 4,908
It may be the way the wind blew on that day .  I have read that the new lens is sharper...I own both and see no difference.
 LMNCT's gear list:LMNCT's gear list
Panasonic LX100 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +23 more
cameron2 Veteran Member • Posts: 4,142
I have both the 20mm and the 14mm, so I tend to read any thread (e.g. here in this forum) about either, and I've never seen any evidence that the mark-i and mark-ii have any IQ difference. Someone once claimed that the 20mm mark-ii was somehow faster than the mark-i, but there was no evidence provided, and the innards of the old and new versions appear to be identical from what I've seen, and other users claimed no difference in speed.
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
uRebel Rob Senior Member • Posts: 1,537
Re: variance
Roger Cicala from LensRentals did a few tests on lens variance last year (link 1, link 2). He tested 10 copies of many different models, but only goes into 24mm and 50mm models in the above links.
About number of copies to test, he says:
Ten copies of each lens is the most we have the resources to do right now. That’s not enough to do rigid statistical analysis, but it does give us a reasonable idea. In testing 10 copies of nearly 50 different lenses so far, the variation number changes very little between 5 and 10 copies and really doesn’t change much at all after 10 copies.
 uRebel Rob's gear list:uRebel Rob's gear list
Pentax K-1 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Pentax FA 28-105mm F3.5-5.6 Nikon D5100 +21 more
RCicala
RCicala Contributing Member • Posts: 820
Re: variance
We've actually run that number up to 60 copies of several lenses now and found really no change in any of our numbers after 10 copies.
