cheap, nice little camera - beware of higher ISO
Started Jun 12, 2016 | User reviews
beaverpond Regular Member • Posts: 213
5
Nice little camera which I use quite often.
Bad lowlight performance, and limited dynamic range not sooo much better than Sigma Foveon Cameras.   ISO200 is visibly worse than ISO100, and ISO1600 just that noisy You rather won't use this setting, if not nessecary.
Best was the price! The EOS-body was sold new for +-150EUR in Germany two years ago.   For this money, You get a very nice camera and there is nothing to complain about.
 beaverpond's gear list:beaverpond's gear list
Sigma DP1 Sigma DP1s Sigma DP1x Sigma DP2s Sigma SD9 +4 more
Canon EOS M
18 megapixels • 3 screen • APS-C sensor
Announced: Jul 23, 2012
beaverpond's score
3.0
Average community score
4.1
bad for good for
Kids / pets
unrated
Action / sports
unrated
Landscapes / scenery
acceptable
Portraits
good
Low light (without flash)
poor
Flash photography (social)
unrated
Studio / still life
good
= community average
brenig12 Junior Member • Posts: 44
Re: cheap, nice little camera - beware of higher ISO
Calis Beach, Fethiye, Turkey 2016.
Example at 12800, I don't think its too bad..
 brenig12's gear list:brenig12's gear list
Canon EOS 550D Canon EOS M Canon EOS 6D Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +4 more
beagle1 Forum Pro • Posts: 11,740
Re: ----I use ISO 6400 and iso 12800 .... whaaaa ?
LOL !
I use ISO 6400 on the original M !
ISO 6400 Canon M
www.flickr.com/photos/mmirrorless
where did all the noise go?
Markintosh
Markintosh Senior Member • Posts: 1,970
Are you serious? ISO 3200 is very usable if you need it. ISO 1600 is great.
If you not shooting macro for jewellery catalog with ISO 3200, you will be ok to capture special moments with good enough quality.  Just my 2 cents.
ISO 3200
ISO 3200
Thanks,
Markintosh.
 Markintosh's gear list:Markintosh's gear list
Canon EOS 5D Mark II Canon EOS M Voigtlander 40mm F2 Ultron SL II Canon EF-M 22mm f/2 STM Sigma 30mm F1.4 DC HSM Art +8 more
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
Beware of higher ISO? Seriously... WHAT? (PICS)
8
"Bad lowlight performance"  Really?  This camera has excellent low-light performance because it has a large APS-C sized sensor.  I must disagree.  Are you SURE you used an actual EOS-M?
I also disagree with the comments describing noise over 200 being poor... or that ISO 1600 is too noisy.  The ISO used by the camera is possibly dependent on the lens used.  The faster lenses can work with lower ISO because they let more light in.  On the other hand, I shoot with a variety of lenses... some are EF lenses and some are EF-M lenses.
Like the others replying with examples from their own cameras, I feel compelled to do the same.  I'm using the original EOS-M.  I'm including ISO samples from ISO 500 to ISO 6400.  I processed my images in Lightroom 4  which has a noise-reduction option and this has been gently (!) applied to some of my images.  As you can see below, the EOS-M does an admirable job with producing usable images in low light with higher ISO settings.  Many of my best shots are taken at ISO 1600... or higher!
EOS-M - ISO 500
EOS-M - ISO 640
EOS-M - ISO 800
EOS-M - ISO 1600
EOS-M - ISO 1600
EOS-M - ISO 1250
EOS-M - ISO 1600
EOS-M - ISO 2000
EOS-M - ISO 3200
EOS-M - ISO 4000
EOS-M - ISO 5000
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
(unknown member) Forum Pro • Posts: 11,521
6
what the heck did you do to the poor camera to #$(*&#$ it up that much that ISO 1600 isn't usable?
Jefenator
Jefenator Senior Member • Posts: 2,866
"Beware" might be too strong a word
IME the original EOS M is a bit less prone to "banding" at higher ISOs than its contemporary Sony counterpart - about a stop better by my reckoning.
Obviously if you really need low noise at moderately high ISO or extreme settings that are usable, there will be better choices for a lot more $$$.
Since I don't object to some visible noise in dim conditions, I am more than satisfied with the $50 body that came with my 22mm pancake lens.
ISO 3200
 Jefenator's gear list:Jefenator's gear list
Sony a7 Canon EF-M 11-22mm f/4-5.6 IS STM Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro Sony Alpha NEX-7 +8 more
whakapu Senior Member • Posts: 1,051
Re: "Beware" might be too strong a word
This is bewildering. I thought maybe OP has come from a full frame and expected the same ISO performance but no, other cams are Sigmas which really are for base ISO only. Maybe OP expected moving to a Bayer sensor would mean no noise penalty at all for ISO?
M is not the best in class but it's certainly in the class of modern APS-C sensors.
Halina123 Senior Member • Posts: 1,632
I find that difficult to belive.
It was true on old tiny sensor p&s
But a modern APS-C size sensor  should be fine up to at least iso 1600.
fotophool Veteran Member • Posts: 4,340
OP is blowing smoke...
fotophool
My Flickr Pics
EOSM3 ISO 1600
Gesture Forum Pro • Posts: 10,236
Re: Beware of higher ISO? Seriously... WHAT? (PICS)
A. You are a great photographer; or B. Your EOS-M was built on a Wednesday, as we say in the auto industry.
I like my EOS-M, but in my experience, dynamic range is poor, as this reviewer found.
pev70 Junior Member • Posts: 43
Some excellent images you got there!  It really shows how capable this little camera with BIG sensor really is..
007peter
007peter Forum Pro • Posts: 12,933
Agree, Flash is NECESSARY or Low-Light protrait can be ruin by noise
5
There are numerous EOS-M defender posting there high-iso photo with software noise reduction applied.  So I'll defend you viewpoint instead.  I can relate to your frustration:
Before I bought into EOS-M + 22mm f/2 prime, my old walk-about was a Sony NEX C3 + Sigma 30/2.8 DN without flash (broken external flash attachment, horrible design).  The noise handling @high iso 1600/3200 is good enough that I never feel I need a flash.  In fact, I much prefer low-light image without flash as it preserve the facial skin-tone without annoying blue cast from flash.
I figure I don't need to spend the extra money for a EX-90 external flash when I bought my EOS-M.  I was happy with my Sony NEX C3 with a slower f/2.8 lens, therefore, I should be happier with my new EOS-M with a lens that is also 1 stop faster.
But Reality Bites....the results was terrible without flash.  Majority of my family photo were in low-light surroundings (dim restaurants, clubs, etc...), and without flash, the shadow noise is horrible.  FACES were ruin by numerous mosquito noise.  ISO 1600 is barely tolerable, ISO 2000 (available under auto-iso) is the maximum I'm willing to go.  Any low-light iso3200 portrait look like they were "sandblasted" with noise across the face.  I came home and order a Canon EX-90 external flash immediately.
Satisfaction with EOS-M really depends if you're a Landscape Shooter (on tripod) using long exposure to compensate for the noise, or a spontaneous family portrait photographer who cannot rely on tripod or long-exposure.  If you're the latter kind like me, you need to invest in an external flash.  If you want Natural Light photography on human facial portraits, you're better off looking elsewhere.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
nnowak Veteran Member • Posts: 9,075
Re: Agree, Flash is NECESSARY or Low-Light protrait can be ruin by noise
You need to gel your flash to match the ambient light.  When done correctly, it won't be immediately apparent that a flash was used in your photos.
007peter
@nnowak - how do you "GEL" a flash???
nnowak wrote:
007peter......Before I bought into EOS-M + 22mm f/2 prime, my old walk-about was a Sony NEX C3 + Sigma 30/2.8 DN without flash (broken external flash attachment, horrible design). The noise handling @high iso 1600/3200 is good enough that I never feel I need a flash. In fact, I much prefer low-light image without flash as it preserve the facial skin-tone without annoying blue cast from flash.
How do you do that, can you show me.  What do you mean by "GEL"?  Is that like an aftermarket yellow filter?
Re: @nnowak - how do you "GEL" a flash???
The best cameras I've ever had at this are Olympus compacts: you can throttle down the flash 1:2, 1:4, 1:8, 1:16 all the way down to 1:64th power.
Flashes have that "blue" look because they are balanced for daylight around 5500K to 6500K.  To match incandescent light, you need to gel the flash to match the orangish 2700K to 3000K range.
Bigger and higher end flashes often come with an orange gel, or they are available as an accessory. My 430EX III-RT came with this orange clip on filter...
For my little 270EX II, I had to improvise. I purchased a giant sheet of gel material in the correct color...http://www.bhphotovideo.com/c/product/163130-REG/Rosco_102302042124_E_Colour_204_Full_CT.html
With a little origami and gaffer tape I fashioned a crude box that slips over the head of the flash.
If you were shooting under fluorescent light, you would gel with a different color.
The other key thing is to get out of the full auto modes when using flash as they lead to blown out subjects and black backgrounds.  Most importantly, you need to bump ISO and get your exposure close to correct without the flash.  By default, your camera will use ISO 400 when shooting flash.  I will often shoot at ISO 1600 or 3200 with flash.
Ed_arizona Senior Member • Posts: 1,996
Proof enough for me..nt
No text.
 Ed_arizona's gear list:Ed_arizona's gear list
Fujifilm X-T30 Fujifilm XF 35mm F2 R WR 7artisans 55mm F1.4 Fujifilm XF 16-80mm F4 +1 more
007peter
Re: @nnowak - Thank You for the photo
Thank you for taking time showing me how it is done.
brightcolours Forum Pro • Posts: 15,885
beware of higher ISO?? and ??
Not really...
Actually quite a bit better than Foveon. I wonder how you came to this conclusion.
ISO200 is visibly
a little
That is not really true. ISO 6400 may start to be too noisy, but ISO 1600 is fine. You can use NR easily, with these files.
