Panasonic 14-42mm ii with a hood and a polarizer?
Started Jun 8, 2016 | Questions
assaft
assaft Senior Member • Posts: 1,483
Hi,
A question to owners of the P 14-42 ii . I'm interested in buying this lens for general outdoor shooting and I would like to use it with a hood and a polarizing filter attached at the same time. This lens has a relatively deep bayonet hood, see here, so I'm trying to understand if it would be convenient to rotate and fine tune the polarizing filter when the hood is attached.
I'm also trying to figure out if the hood would fit when the lens is used with a 52mm filter attached to a 46->52mm step-up ring (the lens filter thread is 46mm), and whether it would be convenient to play with the filter in that case.
Thank you.
 assaft's gear list:assaft's gear list
Olympus PEN E-PL2 Olympus OM-D E-M10 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +6 more
Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS
Terminal Boy Senior Member • Posts: 1,292
Re: Panasonic 14-42mm ii with a hood and a polarizer?
I've never fitted a filter to my 14-42mm MK2, but judging by how many times I've fumbled the lens cap while trying to put it on with the hood fitted, I don't think you're going to have much luck adjusting the filter without removing the hood.
The step-up configuration you mention might make it do-able using thumb and forefinger, but it's still going to be somewhat fiddly.
 Terminal Boy's gear list:Terminal Boy's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
greenjp Regular Member • Posts: 143
I have a 52mm, 3 position collapsible rubber hood with a polarizer on the front that I use with all my lenses via step up rings - a Panasonic 20 1.7, Olympus 45 1.8, Panasonic 45-150, and the 14-42 v2 same as yours.  I find this works pretty well but it does render the other hoods redundant. I still use them when I don't want the polarizer.  Here it is on the 20mm.
If I remember tonight I'll try putting the polarizer on the step up rig and mount to the 14-42 with the bayonet hood attached and see if I can answer your question more directly.
jeff
Astrotripper Veteran Member • Posts: 8,676
Convenient? No. Possible? Yes. I use hoya fusion cpl wil that lens and a lens hood. It's a bit if a hassle and annoying, but doable. Will depend on your hands, though. Sausage fingers would make it rather hard to pull off.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
TonyBologna
TonyBologna Contributing Member • Posts: 700
Depending on your level of handiness - and your willingness to experiment, I would consider taking the hood and cutting a small slot in the bottom center of the hood to allow you to rotate the polarizer.  Might take a bit of engineering but not too much.  A spare hood and a dremel tool would do the trick.
I have had hoods that had this "hatch" in them in the past - I just can't think of who, although Pentax comes to mind with some of their larger hoods.
Tony A.
 TonyBologna's gear list:TonyBologna's gear list
Olympus OM-D E-M10 IV Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Panasonic 20mm F1.7 II Panasonic Lumix G 42.5mm F1.7 +3 more
cameron2 Veteran Member • Posts: 4,142
The issue with the polarizer (or any other filter) is that you want to keep it close to the lens, so Jeff is definitely on the right track here with a 3rd party hood that can attach to the front of the filter!
Note that some polarizers (including a really good one that I use) don't have threads on the front, so be very careful when you are looking for one. (This is bad for two reasons. The first is that you can't put a hood on the front like we're talking about here. The other reason is that you can't put a reversing ring on and use a second polarizer as a 10x ND filter!!!)
Lastly, go through all of your lenses and figure out what size filter will work best for your lenses. I ended up with 58mm and step up rings as necessary to get there. The reason is that you generally want 1 really good filter, not 10 cheap filters of various sizes. A good polarizer runs about $200 or more, so getting the right size the first time is important.
 cameron2's gear list:cameron2's gear list
Sony RX100 Panasonic Lumix DMC-GX8 Hasselblad X1D
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
The Hoya Fusion antistatic filter is a fantastic performer especially given it reasonable price point. As a victim of the large sausage fingers curse I agree it is a bit of a footer
The rose of all the world is not for me. I want for my part
Only the little white rose of Scotland
That smells sharp and sweet—and breaks the heart.
:Hugh MacDiarmid
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
assaft
OP assaft Senior Member • Posts: 1,483
Thanks for the suggestion. Actually I have the same hood, but for a 46mm filter thread, and I'm using it with the 20mm and 45mm too. I still don't have the P 14-42 ii. Yeah, it's a doable configuration. I remember using it with a CPL attached to the lens, and the hood on top of that. So the hood rotates when the filter rotates. I was curious about the OEM Panasonic hood since it looks more effective (the petal design) and more robust
Thanks, I'll appreciate that.
jeff
assaft
Thanks for the suggestions. Which filter do you have in mind that costs 200$? I was thinking of getting this one, which costs 129$ for the 46mm/52mm version. It seems to be double threaded but I need to verify that. The Hoya Fusion that ended 1st place in the last LensTip comparison is about half the price and I consider it as well.
All my lenses are in the range of 37-52mm, so I was thinking of sticking to 52mm. It looks like using a step-up to 52mm, a filter or two, and then a 3-state hood will be the easiest configuration that covers all my lenses. I hope it won't vignette.
assaft
Thanks for the inputs.
assaft
Thanks. Sounds like a cool idea. If I can get a spare hood I'll give it a try. I just noticed that JJC make some after market hoods with a sliding window as you describe (example). They don't seem to produce something like that for Panasonic, but I need to search more.
assaft
Thanks for the information.
58mm - I have the top-of-the-line polarizers from both Heliopan and B+W (but unfortunately only one takes filters on the front ...)
You'll get vignetting at the wider extremes, but just pretend you did it on purpose using Instagram
Alright I put the 14-42 on my GX7 and tried putting on both the bayonet petal hood and the 46-52mm step up ring - can't do it. Doesn't work either way - hood or step up ring first. So that's out, at least with my particular items. I did put the step up ring and rubber hood on:
In the fully collapsed (first picture) and halfway out (second) positions there is no vignetting. In the fully extended position (third) it vignettes to about 20mm, after that it's clear.
jeff
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
assaft wrote:
Hi,
Thank you.
No.   It may not work on your lens.
Maybe it might work using an ultra slim polarizer without lens hood ,
Lens hood + polarizer may cause vignette at the widest focal length.   You can always try using polarizer without lens hood.   Test by shooting  at widest focal length and smallest aperture to see if you get vignette.  YMMV.
Good luck.  And report back your findings.
Lena
Like others here, I suffer from chronic GAS.
Gear Acquisition Syndrome.
a few hundred nautical miles SW : 17º 52S, 149º 56W
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
assaft
Summary
Thanks for all the inputs in this thread. To summarize:
1. OEM hood + 46mm filter - hard to use. a small hunch in the hood can help, as suggested by Anthony Alongi.
2. OEM hood + 46->52 step up ring + 52mm filter - no go, as verified kindly by greenjp.
3. filter + threaded 3-section hood - works but might vignette at wide angles and wide apertures.
